1 | #include <avr/io.h>
2 |
3 | #define uint unsigned int
4 | #define uchar unsigned char
5 |
6 | void twi_init(void);
7 | void writebyte(uchar temp);
8 | uchar TWI_Write(uchar addr,uchar dat);
9 | uchar TWI_Read(uchar addr);
10 | uchar Decimal_to_BCD(uchar temp);
11 | uchar BCD_to_Decimal(uchar temp);
12 | void delay_2(uint z);
13 | void delay_1(void);
14 | void write_ds1307(void);
15 | void read_ds1307(void);
16 |
17 |
18 | //sda=PD1;//;TWI Data transmission bit
19 | //scl=PD0;//;TWI Clock control state flag
20 | //RS=PC0;//define the I / O hardware interface of LCD1602
21 | //RW=PC1;//define the I / O hardware interface 0f LCD1602
22 | //E=PC2; //define the I / O hardware interface 0f LCD1602
23 | uchar count;
24 | uchar Hours=16;//Definition of hours
25 | uchar Minutes=21;//Definition of minutes
26 | uchar Seconds=0;//Definition of seconds
27 |
28 | uint Year=12;//Definition of year
29 | uchar Month=7;//Definition of month
30 | uchar Date=27;//Definition of date
31 | uchar Weeks=5;//Definition of weeks
32 |
33 |
34 | #define START 0X08 //start() has been successfully sent
35 | #define RESTART 0X10 //The restart() has been successfully sent
36 | #define MT_SLA_ACK 0X18 //Load data has been sent ack()
37 | #define MT_SLA_NACK 0X20 //Load data has been sent nack()
38 | #define MT_DAT_ACK 0X28 //Data has been sent ack()
39 | #define MT_DAT_NACK 0X30 //Data has been sent nack()
40 | #define SL_SLA_ACK 0X40 //Data has been loaded from the machine to send ack()
41 | #define SL_SLA_NACK 0X48 //Data has been loaded from the machine to send nack()
42 | #define SL_DAT_ACK 0X50 //Slave data has been sent ack()
43 | #define SL_DAT_NACK 0X58 //Slave data has been sent nack()
44 |
45 | #define start() TWCR=((1<<TWINT)|(1<<TWSTA)|(1<<TWEN)) //Send start signal
46 | #define restart() TWCR=((1<<TWINT)|(1<<TWEN)|(1<<TWSTA)) //Sent to re-start signal
47 | #define wait() while(!(TWCR & (1<<TWINT))) //Waiting for the signal
48 | #define state() (TWSR&0XF8) //The register TWSR state extraction
49 | #define stop() TWCR=((1<<TWEN)|(1<<TWINT)|(1<<TWSTO)) //Stop signal
50 | #define twi() (TWCR=(1<<TWINT)|(1<<TWEN)) //Open the TWI function
51 | #define setnoAck() (TWCR&=~(1<<TWEA)) //Make Not Ack response
52 |
53 | #define r_direction 0xD1 //Read the device address
54 | #define w_direction 0xD0 //Write device address
55 |
56 | void twi_init(void) //TWI initialization
57 | {
58 | TWCR |=(1<<TWEN); //Start twi function
59 | TWBR=0X20; //Set the baud rate for the host mode
60 | TWSR=0; //Clear Status Register
61 | }
62 |
63 | void writebyte(uchar temp)//A byte data write to the TWI
64 | {
65 | TWDR=temp;
66 | TWCR=((1<<TWINT)|(1<<TWEN));
67 | }
68 | uchar TWI_Write(uchar addr,uchar dat) //Write data to TWI
69 | {
70 | start();//start signal
71 | wait();//Start TWI function
72 | if(state()!=START)//Wait for the nack/ack() signal
73 | return 1;
74 |
75 | writebyte(w_direction);//write Device address
76 | wait();
77 | if(state()!=MT_SLA_ACK)
78 | return 1;
79 |
80 | writebyte(addr);//write Byte address
81 | wait();
82 | if(state()!=MT_DAT_ACK)
83 | return 1;
84 |
85 | writebyte(dat);//write data
86 | wait();
87 | if(state()!=MT_DAT_ACK)
88 | return 1;
89 |
90 | stop();//stop signal
91 | return 0;
92 | }
93 |
94 | uchar TWI_Read(uchar addr) //Read data from TWI
95 | {
96 | uchar temp=0;
97 | start();//
98 | wait();
99 | if(state()!=START)
100 | return 1; //ACK*/
101 |
102 | writebyte(w_direction); //Write TWI slave address and write
103 | wait();
104 | if(state()!=MT_SLA_ACK)
105 | return 1; //ACK*/
106 |
107 | writebyte(addr); //Write the corresponding device register address
108 | wait();
109 | if(state()!=MT_DAT_ACK)
110 | return 1;//*/
111 |
112 | start(); //TWI re-start
113 | wait();
114 | if (state()!=RESTART)
115 | return 1;//*/
116 |
117 | writebyte(r_direction); //Write TWI slave device address and read
118 | wait();
119 | if(state()!=SL_SLA_ACK)
120 | return 1; //ACK*/
121 |
122 | twi(); //Start the TWI read
123 | wait();
124 | if(state()!=SL_DAT_NACK)
125 | return 1; //ACK*/
126 |
127 | temp=TWDR;//Read the TWI of the receive data
128 | stop();//
129 | return temp;
130 |
131 |
132 | }
133 | /////////////////////////////////////////
134 | //////////////////////////////////////////
135 | uchar Decimal_to_BCD(uchar temp)//Decimal converted to BCD code
136 | {
137 | uchar a,b,c;
138 | a=temp;
139 | b=0x00;
140 | if(a>=10)
141 | {
142 | while(a>=10)
143 | {
144 | a=a-10;
145 | b=b+16;
146 | c=a+b;
147 | temp=c;
148 | }
149 | }
150 | return temp;
151 | }
152 |
153 | uchar BCD_to_Decimal(uchar temp)//BCD to decimal
154 | {
155 | uchar a,b,c;
156 | a=temp;
157 | b=0x00;
158 | if(a>=16)
159 | {
160 | while(a>=16)
161 | {
162 | a=a-16;
163 | b=b+10;
164 | c=a+b;
165 | temp=c;
166 | }
167 | }
168 | return temp;
169 | }
170 | ////////////////////////////////////////
171 | void delay_2(uint z)//0.1msDelay
172 | {
173 | uchar x,x1;
174 | for(x1=0;x1<z;x1++)
175 | {
176 | for(x=0;x<114;x++);
177 | }
178 | }
179 |
180 | void delay_1(void)//0.1msDelay
181 | {
182 | uchar x,x1;
183 | for(x1=0;x1<2;x1++)
184 | {
185 | for(x=0;x<100;x++);
186 | }
187 | }
188 |
189 | void write_ds1307(void)//write ds1307
190 | {
191 | //Write a data to the device: (0xd0 is device write address; 0x01 ~ 06 are seconds to years register; Seconds ~ Year, data to be written)//
192 | Seconds=Decimal_to_BCD(Seconds);//Decimal converted to BCD code
193 | Minutes=Decimal_to_BCD(Minutes);//
194 | Hours=Decimal_to_BCD(Hours);//
195 |
196 | Date=Decimal_to_BCD(Date);//
197 | Year=Decimal_to_BCD(Year);//
198 | Month=Decimal_to_BCD(Month);//
199 |
200 | TWI_Write(0x00,Seconds);//write Seconds
201 | TWI_Write(0x01,Minutes);//write Minutes
202 | TWI_Write(0x02,Hours);//write Hours
203 |
204 | TWI_Write(0x03,Weeks);//write Weeks
205 |
206 | TWI_Write(0x04,Date);//write Data
207 | TWI_Write(0x05,Month);//write Month
208 | TWI_Write(0x06,Year);//write Year
209 | }
210 |
211 | void read_ds1307(void)//read ds1307
212 | {
213 | //Read a data to the device: (0xd0 is the DS1307 device write address; 0x01 ~ 06 are seconds to years register; 0xd1 is DS1307 device read address)
214 | Seconds=TWI_Read(0x00);
215 | Seconds=BCD_to_Decimal(Seconds);//BCD code converted to decimal
216 |
217 | Minutes=TWI_Read(0x01);
218 | Minutes=BCD_to_Decimal(Minutes);//
219 |
220 | Hours=TWI_Read(0x02);
221 | Hours=BCD_to_Decimal(Hours);//
222 |
223 | Weeks=TWI_Read(0x03);//
224 |
225 | Date=TWI_Read(0x04);
226 | Date=BCD_to_Decimal(Date);//
227 |
228 | Month=TWI_Read(0x05);
229 | Month=BCD_to_Decimal(Month);//
230 |
231 | Year=TWI_Read(0x06);
232 | Year=BCD_to_Decimal(Year);//
233 | }
234 |
235 | int main(void)
236 | {
237 | DDRA = 0x77;
238 | DDRB = 0x77;
239 |
240 | DDRC = 0x00;
241 | PORTC = 0x03;
242 |
243 | twi_init();//TWI Initialization
244 |
245 | //write_ds1307();//Write the initial value on ds1307//(Modification time initial value when used)
246 | while(1)
247 | {
248 | read_ds1307();
249 |
250 | if(Seconds & 1)
251 | {
252 | PORTA = 0x07;
253 | }
254 | else
255 | {
256 | PORTA = 0x00;
257 | }
258 |
259 | for(uint16_t i = 0x0FFF; i; i--);
260 | }
261 | }
