1 | #include <ESP8266WiFi.h>
2 | #include <PubSubClient.h>
3 |
4 | // Update these with values suitable for your network.
5 |
6 | const char* ssid = "ssid";
7 | const char* password = "wlanpasswort";
8 | const char* mqtt_server = "192.168.xxx.xxx";
9 |
10 | WiFiClient espClient;
11 | PubSubClient client(espClient);
12 | long lastMsg = 0;
13 | char msg[50];
14 | int value = 0;
15 |
16 | void setup_wifi() {
17 |
18 | delay(10);
19 | // We start by connecting to a WiFi network
20 | Serial.println();
21 | Serial.print("Connecting to ");
22 | Serial.println(ssid);
23 |
24 | WiFi.begin(ssid, password);
25 |
26 | while (WiFi.status() != WL_CONNECTED) {
27 | for(int i = 0; i<500; i++){
28 | delay(1);
29 | }
30 | Serial.print(".");
31 | }
32 |
33 | Serial.println("");
34 | Serial.println("WiFi connected");
35 | Serial.println("IP address: ");
36 | Serial.println(WiFi.localIP());
37 | }
38 |
39 | void callback(char* topic, byte* payload, unsigned int length) {
40 | Serial.print("Message arrived [");
41 | Serial.print(topic);
42 | Serial.print("] ");
43 | for (int i = 0; i < length; i++) {
44 | Serial.print((char)payload[i]);
45 | }
46 | Serial.println();
47 | // Switch on the LED if an 1 was received as first character
48 | if ((char)payload[0] == '1') {
49 | digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
50 | // but actually the LED is on; this is because
51 | // it is acive low on the ESP-01)
52 | } else {
53 | digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
54 |
55 | }
56 |
57 | }
58 |
59 | void reconnect() {
60 | // Loop until we're reconnected
61 | while (!client.connected()) {
62 | Serial.print("Attempting MQTT connection...");
63 | // Attempt to connect
64 | if (client.connect("ESP8266_Taster")) {
65 | Serial.println("connected");
66 | // Once connected, publish an announcement...
67 | client.publish("(outTopic)debug","ESP8266 subscriber connected.");
68 | // ... and resubscribe
69 | client.subscribe("(inTopic)Variable der Led");
70 | }
71 | else {
72 | Serial.print("failed, rc=");
73 | Serial.print(client.state());
74 | Serial.println(" versuche nochmal in 5 seconds");
75 | // Wait 5 seconds before retrying
76 | for(int i = 0; i<5000; i++){
77 | delay(1);
78 | }
79 | }
80 | }
81 | }
82 |
83 |
84 | void setup() {
85 | pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
86 | Serial.begin(115200);
87 | setup_wifi();
88 | client.setServer(mqtt_server, 1883);
89 | client.setCallback(callback);
90 | }
91 | void loop() {
92 |
93 | if (!client.connected()) {
94 | reconnect();
95 | }
96 | client.loop();
97 | long now = millis();
98 | if (now - lastMsg > 2000) {
99 | lastMsg = now;
100 | ++value;
101 | snprintf (msg, 75, "hello world#%ld", value);
102 | //Serial.print("Publish message: ");
103 | // Serial.println(msg);
104 | //client.publish("Led ist an", msg);
105 | }
106 |
107 | }
