1 | #include <ESP8266WiFi.h>
2 | #include <Wire.h>
3 | #include <PubSubClient.h>
4 | #include <SPI.h>
5 | #include <Adafruit_Sensor.h>
6 | #include <Adafruit_BME280.h>
7 | #include <Adafruit_NeoPixel.h>
8 |
9 | //PubSubClient
10 | #define wifi_ssid "xxxx"
11 | #define wifi_password "xxxx"
12 | #define mqtt_server "xxxx"
13 | const char* mqtt_user = "xxxx";
14 | const char* mqtt_password = "xxxx";
15 |
16 | //BME280
17 | #define SEALEVELPRESSURE_HPA (1013.25)
18 |
19 | //Subcribe Topics
20 | #define humidity_topic "Home/Weatherstation/Humidity"
21 | #define temperature_topic "Home/Weatherstation/Temperature"
22 | #define pressure_topic "Home/Weatherstation/Pressure"
23 | #define altitude_topic "Home/Weatherstation/Altitude"
24 | #define light_topic "Home/Weatherstation/Light"
25 |
26 | //Publish Topics
27 | #define ir_topic "/Home/Livingroom/IR"
28 | #define rf_topic "/Home/Livingroom/RF"
29 | #define main_topic "/Home/Livingroom/Light/Main"
30 | #define rgb_topic "/Home/Livingroom/Light/RGB"
31 | #define rgbfunc_topic "/Home/Livingroom/Light/RGBfunc"
32 |
33 | #define PIN D8
34 | Adafruit_NeoPixel pixels = Adafruit_NeoPixel(8, PIN, NEO_GRB + NEO_KHZ800);
35 |
36 | String strTopic;
37 | String strPayload;
38 |
39 | WiFiClient espClient;
40 | PubSubClient client(espClient);
41 |
42 | const int analogInPin = A0;
43 | Adafruit_BME280 bme; // configuring as I2C
44 |
45 |
46 | void setup() {
47 | Serial.begin(115200);
48 | setup_wifi();
49 | client.setServer(mqtt_server, 1883);
50 | client.setCallback(callback);
51 | //LED
52 | pinMode(BUILTIN_LED, OUTPUT);
53 | // Starting i2c;
54 | Wire.begin(SDA, SCL);
55 | pixels.begin();
56 |
57 | // Starting Sensor
58 | bool status;
59 |
60 | status = bme.begin();
61 | if (!status) {
62 | Serial.println("Could not find a valid BME280 sensor, check wiring!");
63 | while (1);
64 | }
65 | }
66 |
67 | void setup_wifi() {
68 | delay(10);
69 | // We start by connecting to a WiFi network
70 | Serial.println();
71 | Serial.print("Connecting to ");
72 | Serial.println(wifi_ssid);
73 |
74 | WiFi.begin(wifi_ssid, wifi_password);
75 | WiFi.mode(WIFI_STA);
76 |
77 | while (WiFi.status() != WL_CONNECTED) {
78 | delay(500);
79 | Serial.print(".");
80 | }
81 |
82 | Serial.println("");
83 | Serial.println("WiFi connected");
84 | Serial.println("IP address: ");
85 | Serial.println(WiFi.localIP());
86 | }
87 |
88 | void callback(char* topic, byte* payload, unsigned int length) {
89 | int led;
90 | Serial.print("Message arrived [");
91 | Serial.print(topic);
92 | Serial.print("] ");
93 | for (int i = 0; i < length; i++) {
94 | Serial.print((char)payload[i]);
95 | strPayload = String((char)payload[i]);
96 | }
97 | Serial.println();
98 | strTopic = String((char*)topic);
99 |
100 |
101 | if ((strTopic == main_topic) && ((char)payload[0] == '0')) {
102 | digitalWrite(BUILTIN_LED, LOW);
103 | }
104 | else if ((strTopic == main_topic) && ((char)payload[0] == '1')) {
105 | digitalWrite(BUILTIN_LED, HIGH);
106 | }
107 | else if ((strTopic == rgbfunc_topic) && ((char)payload[0] == '1')) {
108 | setColor(led,255,0,0,100);
109 | }
110 | else if ((strTopic == rgbfunc_topic) && ((char)payload[0] == '0')) {
111 | setColor(led,0,0,0,100);
112 | }
113 | else if (strTopic == rgb_topic) {
114 | String hexstring = strPayload;
115 | long number = strtol( &hexstring[1], NULL, 16);
116 | long r = number >> 16;
117 | long g = number >> 8 & 0xFF;
118 | long b = number & 0xFF;
119 |
120 | Serial.print("red is ");
121 | Serial.println(r);
122 | Serial.print("green is ");
123 | Serial.println(g);
124 | Serial.print("blue is ");
125 | Serial.println(b);
126 | Serial.print("");
127 | Serial.print(hexstring);
128 | }
129 |
130 |
131 | else {
132 | Serial.print("Subscribed but no function!");
133 | }
134 |
135 | }
136 |
137 | void reconnect() {
138 | // Loop until we're reconnected
139 | while (!client.connected()) {
140 | Serial.print("Attempting MQTT connection...");
141 | // Attempt to connect
142 | // If you do (not) want to use a username and password, change next line to
143 | // if (client.connect("ESP8266Client")) {
144 | // or (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
145 | if (client.connect("Wohnzimmer", mqtt_user, mqtt_password)) {
146 | Serial.println("connected");
147 | client.subscribe(ir_topic);
148 | client.subscribe(rf_topic);
149 | client.subscribe(main_topic);
150 | client.subscribe(rgb_topic);
151 | client.subscribe(rgbfunc_topic);
152 | }
153 | else {
154 | Serial.print("failed, rc=");
155 | Serial.print(client.state());
156 | Serial.println(" try again in 5 seconds");
157 | // Wait 5 seconds before retrying
158 | delay(5000);
159 | }
160 | }
161 | }
162 |
163 | void setColor(int led, int redValue, int greenValue, int blueValue, int delayValue)
164 | {
165 | pixels.setPixelColor(led, pixels.Color(redValue, greenValue, blueValue));
166 | pixels.show();
167 | }
168 |
169 | bool checkBound(float newValue, float prevValue, float maxDiff) {
170 | return !isnan(newValue) &&
171 | (newValue < prevValue - maxDiff || newValue > prevValue + maxDiff);
172 | }
173 |
174 | long lastMsg = 0;
175 | float temp = 0.0;
176 | float hum = 0.0;
177 | float pres = 0.0;
178 | float alti = 0.0;
179 | float light = 0.0;
180 | float diff = 0.3;
181 | float diff2 = 1;
182 | float diff3 = 2;
183 |
184 | void loop() {
185 | if (!client.connected()) {
186 | reconnect();
187 | }
188 | client.loop();
189 | long now = millis();
190 | if (now - lastMsg > 1000) {
191 | lastMsg = now;
192 |
193 | float newTemp = bme.readTemperature();
194 | float newHum = bme.readHumidity();
195 | float newPres = bme.readPressure() / 100.0F;
196 | float newAlti = bme.readAltitude(SEALEVELPRESSURE_HPA);
197 | float newLight = analogRead(analogInPin);
198 |
199 | if (checkBound(newTemp, temp, diff)) {
200 | temp = newTemp;
201 | Serial.print("Neue Temperatur:");
202 | Serial.println(String(temp).c_str());
203 | client.publish(temperature_topic, String(temp).c_str(), true);
204 | }
205 |
206 | if (checkBound(newHum, hum, diff)) {
207 | hum = newHum;
208 | Serial.print("Neue Luftfeuchtigkeit:");
209 | Serial.println(String(hum).c_str());
210 | client.publish(humidity_topic, String(hum).c_str(), true);
211 | }
212 |
213 | if (checkBound(newPres, pres, diff)) {
214 | pres = newPres;
215 | Serial.print("Neuer Druck:");
216 | Serial.println(String(pres).c_str());
217 | client.publish(pressure_topic, String(pres).c_str(), true);
218 | }
219 |
220 | if (checkBound(newAlti, alti, diff2)) {
221 | alti = newAlti;
222 | Serial.print("Neue Höhe:");
223 | Serial.println(String(alti).c_str());
224 | client.publish(altitude_topic, String(alti).c_str(), true);
225 | }
226 | if (checkBound(newLight, light, diff3)) {
227 | light = newLight;
228 | Serial.print("Neue Helligkeit:");
229 | Serial.println(String(light).c_str());
230 | client.publish(light_topic, String(light).c_str(), true);
231 | }
232 | }
233 | }
