1 |
2 | #define BLYNK_PRINT Serial // Comment this out to disable prints and save space
3 | #include <SimpleTimer.h>
4 | #include <ESP8266WiFi.h>
5 | #include <Adafruit_Sensor.h>
6 | #include <Adafruit_BME280.h>
7 | #include <BlynkSimpleEsp8266.h>
8 | #include <Ticker.h> //watchdog
9 |
10 | Ticker secondTick; //watchdog
11 | volatile int watchdogCount = 0; //watchdog
12 | volatile int zaehler = 0; //Zähler Benachrichtigung
13 |
14 | SimpleTimer timer;
15 | Adafruit_BME280 bme; // I2C
16 |
17 | char auth[] = "***";
18 | char ssid[] = "***";
19 | char pass[] = "***";
20 |
21 | int connectTimer;
22 |
23 | // Messwertvariablen
24 | float h, t, p, pin, dp, tc;
25 | char temperatureFString[6];
26 | char dpString[6];
27 | char humidityString[6];
28 | char pressureString[7];
29 | char pressureInchString[6];
30 |
31 | void ISRwatchdog() { //ISR = Interrupt Service Routine
32 | watchdogCount++;
33 | if (watchdogCount >= 8) { // Einheit in Sekunden [s]!!!
34 | ESP.reset();
35 | }
36 | }
37 |
38 | void WLANconnect() {
39 |
40 | if (WiFi.status() != WL_CONNECTED) {
41 | yield();
42 | Serial.println("keine Verbindung vorhanden - Reset");
43 | watchdogCount = 8; // Einheit [s]!!!
44 |
45 | } else {
46 | Serial.println("verbunden");
47 |
48 | h = bme.readHumidity(); //Berechnung Messwert
49 | tc = bme.readTemperature();
50 | t = tc * 1.8 + 32.0;
51 | dp = t - 0.36 * (100.0 - h);
52 | yield();
53 |
54 | p = bme.readPressure() / 100.0F;
55 | //t = (t-32)*5/9; //[°C]
56 | pin = 0.02953 * p;
57 | dtostrf(tc, 5, 1, temperatureFString);
58 | dtostrf(h, 5, 1, humidityString);
59 | dtostrf(p, 6, 1, pressureString);
60 | dtostrf(pin, 5, 2, pressureInchString);
61 | dtostrf(dp, 5, 1, dpString);
62 | yield();
63 |
64 | Blynk.virtualWrite(V0, temperatureFString); //Senden Messwert an BlynkApp
65 | Blynk.virtualWrite(V1, humidityString);
66 | Blynk.virtualWrite(V2, pressureString);
67 | Serial.print(temperatureFString);
68 | Serial.println(" °C");
69 | Serial.print(humidityString);
70 | Serial.println(" %");
71 | Serial.print(pressureString);
72 | Serial.println(" hPA");
73 | Serial.println();
74 |
75 | if (tc > 27 && h > 30){
76 | zaehler = zaehler +1;
77 | }
78 | watchdogCount = 0; // Einheit [s]!!!
79 | }
80 | }
81 |
82 |
83 | void setup()
84 | {
85 | Serial.begin(115200);
86 | Blynk.begin(auth, ssid, pass);
87 | Wire.begin(D3, D4); //Sensor
88 | Wire.setClock(115200);
89 |
90 | bme.begin();
91 | if (!bme.begin()) {
92 | Serial.println("Could not find a valid BME280 sensor, check wiring!");
93 | while (1); //(dient als Wachtdog!, falls Verkabelung defekt - Notfalls Kabel tauschen!)
94 |
95 | WiFi.begin(auth, ssid); //WiFi Verbindung
96 | Serial.print("Connecting");
97 | while (WiFi.status() != WL_CONNECTED)
98 | {
99 | delay(500);
100 | Serial.print(".");
101 | }
102 | Serial.println();
103 | Serial.print("Connected, IP address: ");
104 | Serial.println(WiFi.localIP());
105 |
106 | }
107 |
108 | connectTimer = timer.setInterval(1000L, WLANconnect); //Aurfur alle x Sekunden
109 | yield();
110 | secondTick.attach(1, ISRwatchdog);
111 | yield();
112 | delay(10);
113 | }
114 |
115 | void loop() {
116 | Blynk.run();
117 | timer.run();
118 | }
