1 | xadc_wiz_0: xadc_wiz@43c00000 {
2 | clock-names = "ref_clk";
3 | clocks = <&clkc 0>;
4 | compatible = "xlnx,axi-xadc-1.00.a";
5 | reg = <0x43c00000 0x10000>;
6 | xlnx,alarm-limit-r0 = <0xb5ed>;
7 | xlnx,alarm-limit-r1 = <0x57e4>;
8 | xlnx,alarm-limit-r10 = <0x5555>;
9 | xlnx,alarm-limit-r11 = <0x5111>;
10 | xlnx,alarm-limit-r12 = <0x9999>;
11 | xlnx,alarm-limit-r13 = <0x91eb>;
12 | xlnx,alarm-limit-r14 = <0x6aaa>;
13 | xlnx,alarm-limit-r15 = <0x6666>;
14 | xlnx,alarm-limit-r2 = <0xa147>;
15 | xlnx,alarm-limit-r3 = <0xca33>;
16 | xlnx,alarm-limit-r4 = <0xa93a>;
17 | xlnx,alarm-limit-r5 = <0x52c6>;
18 | xlnx,alarm-limit-r6 = <0x9555>;
19 | xlnx,alarm-limit-r7 = <0xae4e>;
20 | xlnx,alarm-limit-r8 = <0x5999>;
21 | xlnx,alarm-limit-r9 = <0x5111>;
22 | xlnx,configuration-r0 = <0x0>;
23 | xlnx,configuration-r1 = <0x21af>;
24 | xlnx,configuration-r2 = <0x400>;
25 | xlnx,dclk-frequency = <0x64>;
26 | xlnx,external-mux = "none";
27 | xlnx,external-mux-channel = "VP_VN";
28 | xlnx,external-muxaddr-enable = <0x0>;
29 | xlnx,fifo-depth = <0x7>;
30 | xlnx,has-axi = <0x1>;
31 | xlnx,has-axi4stream = <0x0>;
32 | xlnx,has-busy = <0x1>;
33 | xlnx,has-channel = <0x1>;
34 | xlnx,has-convst = <0x0>;
35 | xlnx,has-convstclk = <0x0>;
36 | xlnx,has-dclk = <0x1>;
37 | xlnx,has-drp = <0x0>;
38 | xlnx,has-eoc = <0x1>;
39 | xlnx,has-eos = <0x1>;
40 | xlnx,has-external-mux = <0x0>;
41 | xlnx,has-jtagbusy = <0x0>;
42 | xlnx,has-jtaglocked = <0x0>;
43 | xlnx,has-jtagmodified = <0x0>;
44 | xlnx,has-ot-alarm = <0x0>;
45 | xlnx,has-reset = <0x0>;
46 | xlnx,has-temp-bus = <0x0>;
47 | xlnx,has-user-temp-alarm = <0x0>;
48 | xlnx,has-vbram-alarm = <0x0>;
49 | xlnx,has-vccaux-alarm = <0x0>;
50 | xlnx,has-vccddro-alarm = <0x0>;
51 | xlnx,has-vccint-alarm = <0x0>;
52 | xlnx,has-vccpaux-alarm = <0x0>;
53 | xlnx,has-vccpint-alarm = <0x0>;
54 | xlnx,has-vn = <0x1>;
55 | xlnx,has-vp = <0x1>;
56 | xlnx,include-intr = <0x1>;
57 | xlnx,sampling-rate = "961538.4615384615";
58 | xlnx,sequence-r0 = <0x3900>;
59 | xlnx,sequence-r1 = <0x4040>;
60 | xlnx,sequence-r2 = <0x0>;
61 | xlnx,sequence-r3 = <0x0>;
62 | xlnx,sequence-r4 = <0x0>;
63 | xlnx,sequence-r5 = <0x0>;
64 | xlnx,sequence-r6 = <0x0>;
65 | xlnx,sequence-r7 = <0x0>;
66 | xlnx,sim-file-name = "design";
67 | xlnx,sim-file-rel-path = "./";
68 | xlnx,sim-file-sel = "Default";
69 | xlnx,vaux0 = <0x0>;
70 | xlnx,vaux1 = <0x0>;
71 | xlnx,vaux10 = <0x0>;
72 | xlnx,vaux11 = <0x0>;
73 | xlnx,vaux12 = <0x0>;
74 | xlnx,vaux13 = <0x0>;
75 | xlnx,vaux14 = <0x1>;
76 | xlnx,vaux15 = <0x0>;
77 | xlnx,vaux2 = <0x0>;
78 | xlnx,vaux3 = <0x0>;
79 | xlnx,vaux4 = <0x0>;
80 | xlnx,vaux5 = <0x0>;
81 | xlnx,vaux6 = <0x1>;
82 | xlnx,vaux7 = <0x0>;
83 | xlnx,vaux8 = <0x0>;
84 | xlnx,vaux9 = <0x0>;
85 | };
