TCRT5000 und DHT mit einem ESP32 auslesen
OP #5449829
Hab hier folgenden Code verfasst:
#include <Basecamp.hpp>
#include <DHTesp.h>
#include <AsyncMqttClient.h>
Basecamp iot;
#define LED_pin 2
AsyncMqttClient mqttClient;
/** Initialize DHT sensor */
DHTesp dht;
/** Task handle for the light value read task */
TaskHandle_t tempTaskHandle = NULL;
/** Pin number for DHT11 data pin */
int dhtPin = 25;
char tempBuf[2]={0};
TempAndHumidity lastValues;
char feuchtBuf[2]={0};
hw_timer_t * timer = NULL;
volatile uint8_t ledstat = 0;
23
24
void IRAM_ATTR onTimer(){
25
 // ledstat=1-ledstat;
26
 // digitalWrite(16, ledstat);   // turn the LED on or off
27
  // lastValues = dht.getTempAndHumidity();
28
 Serial.println("*************************auslesen*********************");
29
30
31
void setup() {
32
  // put your setup code here, to run once:
33
34
35
  // Initialize temperature sensor
36
  dht.setup(dhtPin, DHTesp::DHT22);
37
38
  iot.begin();
39
  pinMode(LED_pin, OUTPUT);
40
  Serial.begin(115200);
41
  iot.mqtt.onConnect(mqttConnected);
42
  iot.mqtt.onMessage(mqttMessage);
43
44
 /*  Serial.println("start timer ");
45
  timer = timerBegin(0, 80, true);  // timer 0, MWDT clock period = 12.5 ns * TIMGn_Tx_WDT_CLK_PRESCALE -> 12.5 ns * 80 -> 1000 ns = 1 us, countUp
46
  timerAttachInterrupt(timer, &onTimer, true); // edge (not level) triggered
47
  timerAlarmWrite(timer, 2000000, true); // 1000000 * 1 us = 1 s, autoreload true
48
timerAlarmEnable(timer); // enable
49
50
51
void mqttConnected(bool sessionPresent) {
52
  iot.mqtt.subscribe("example1/led", 0);
53
  iot.mqtt.publish("stromzaehler/temp", 1, true,tempBuf );
54
  iot.mqtt.publish("stromzaehler/relFeucht", 1, true, feuchtBuf );
55
  Serial.print("*****************");
56
  Serial.println(tempBuf);
57
58
59
void mqttMessage(char* topic, char* payload, AsyncMqttClientMessageProperties properties, size_t len,
60
                 size_t index, size_t total) {
61
  payload[len] = '\0';
62
  String strTopic = String(topic);
63
  String strPayload = String((char * ) payload);
64
65
  if (strTopic == "example1/led") {
66
    if (strPayload == "off" || strPayload == "0" || strPayload == "false") {
67
      digitalWrite(LED_pin, LOW);
68
      Serial.println("Lampe aus");
69
70
    if (strPayload == "on" || strPayload == "1" || strPayload == "true") {
71
      digitalWrite(LED_pin, HIGH);
72
      Serial.println("Lampe an");
73
74
75
76
77
78
79
void loop() {
80
  // put your main code here, to run repeatedly:
81
  // Reading temperature and humidity takes about 250 milliseconds!
82
  // Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
83
84
85
  Serial.println("Temperature: " + String(lastValues.temperature, 0));
86
  Serial.println("Humidity: " + String(lastValues.humidity, 0));
87
  dtostrf((lastValues.humidity),2, 0, feuchtBuf);
88
  dtostrf((lastValues.temperature),2, 0, tempBuf);
89
 delay(1000);
90
ich möchte jetztnoch den Impuls (roteer Strich) an meinem Ferrarie
Zähler mit einem TCRT5000 ablesen. Hier kommt mir aber das Delay in die
quere. Ich hab schon versucht das Delay durch einen Timer zu ersetzen
was abe bisher noch nicht funktioniert hat. Wenn ich den Sensor DHT22 in
der Rutine nach der abgelaufenen Zeit auslese vermute ich das das zu
lange dauert (ca.250ms).
Wie kann ich das Problem angehen ohne gleich einen neues ESP für die
Aufgabe verwenden zu müssen?
MfG Fritz
