Daten aus Response Nachricht auswerten CAPL CANoe (11)
Gast #5975706
ich sende in CAPL Diagnose Nachrichten und möchte die Antworten dann
auswerten.
// ReadEcuIdentification: IdCode                           //
// expected positive response with defined IdCode          //
testcase Testcase_ReadEcuIdentification_IdCode()
  DiagRequest KLineTester.IDCode req;
  DiagResponse KLineTester.IDCode resp;
  char buffer[100];
  long ret, ret2, ret3, ret4, ret5;
  byte idCode[62];
  byte counter;
  char step[5] = "1.0";
  testStep(0, step, "Read Ecu Identification: IdCode"); // Write the current teststep to the testreport
  diagGetObjectName(req, buffer, elCount(buffer)); // Get the name of the diagnostic object
  DiagSendRequest(req);
  ret = testWaitForDiagRequestSent(req, 2000); // Wait until the request has been completely sent
  if(ret==1) // Request sent
     TestReportWriteDiagObject(req); // Write the request-Object to the testreport
24
     write("Request has been successfully sent");
25
     ret2=TestWaitForDiagResponse(req, 5000); // Wait for a response, here for 5000ms. Note: This is no P2 timeout!
26
27
     if(ret2==1) // Response received
28
29
        ret3=DiagGetLastResponse(req,resp); // Get the receveived response
30
        if(ret3>=0)
31
32
           if(diagIsPositiveResponse(resp)) // Is it a positive response?
33
34
             DiagGetParameterRaw(resp, "IdCode", idCode, elCount(idCode));  // Retrieve the serial number from the response in raw format
35
             write("Current IdCode is:");
36
             for(counter=0; counter<elCount(idCode); counter++)
37
38
              write(" 0x%02X", idCode[counter]);
39
40
             TestReportWriteDiagObject(resp); // Write the response-Object to the testreport
41
             ret5 = memcmp(REI_ID_CODE, idCode, elCount(idCode)); // compare received IdCode with the expected IdCode
42
             if(ret5 == 0) // received IdCode and expected IdCode are same
43
44
               testStepPass(0, step, "IdCode has been successfully read"); // teststep accomplished
45
46
             else
47
48
               testStepFail(0, step, "The received IdCode does not match with the expected IdCode"); // teststep failed
49
50
51
           else // It is a negative Response
52
53
             ret4=diagGetResponseCode(resp);
54
             write("Negative Response, NRC: 0x%02X",(byte)ret4);
55
56
             testStepFail(0, step, "Negative Response. NRC: 0x%02X",(byte)ret4); // teststep failed
57
58
59
        else
60
61
          write("Could not retrieve response");
62
          testStepFail(0, step, "Could not retrieve response");
63
64
65
66
     if(ret2==0) // Timeout. No response received
67
68
        write("Timeout specified in TestWaitForDiagResponse expired");
69
        testStepFail(0, step, "Timeout specified in TestWaitForDiagResponse expired");
70
71
     if(ret2<0) // Error e.g. transport protocol level
72
73
        if(ret2==-92) // This is the error code for P2 or P2* timeouts
74
75
          write("TP level error %d, probably P2 or P2* timeout", ret2);
76
          testStepFail(0, step, "TP level error %d, probably P2 or P2* timeout", ret2);
77
78
        else
79
80
          write("Error %d in the diagnostic or transport layer", ret2);
81
          testStepFail(0, step, "Error %d in the diagnostic or transport layer", ret2);
82
83
84
85
   else
86
87
      if(ret==0)
88
89
        write("Timeout expired while trying to send request %s", buffer);
90
        testStepFail(0, step, "Timeout expired while trying to send request %s", buffer);
91
92
      if(ret<0)
93
94
        write("Internal error %d occured while trying to send request %s", ret, buffer);
95
        testStepFail(0, step, "Internal error %d occured while trying to send request %s", ret, buffer);
96
97
98
mein Problem liegt bei der Auswertung der empfangenen Nachricht
Hier bekomme ich einen Array, der mit 0x00 gefüllt ist. Im Trace sehe
ich aber, dass Daten vorhanden sind.
Mein Problem ist, dass ich nicht genau weiß was diese Funktion im Detail
macht.
In der Hilfe steht
long diagGetParameterRaw (diagResponse obj, char parameterName[], byte* buffer, DWORD buffersize)
was genau ist der parameterName?
In der Hilfe steht nur
parameterName: Parameter qualifier
Damit kann ich aber leider nicht so viel anfangen.
Oder kann ich irgendwie anders an die Daten kommen?
