Hay, I have a CC1101 wireless module but even after several resuch i can't get it to work. Does anyone have some hints? Thanks a lot!
Some send on wrong frequency (wrong in the sense that there is a small offset) Suggestion was in the end, that the 2 capacitors near the crystal are wrong, either swap them or do a correction in software Do you have a SDR stick and a working sender, so that you could compare the frequency?
