1 | #include "display_utils.h"
2 | #include <LiquidCrystal_I2C.h>
3 | #include <LCDMenuLib2.h> //https://github.com/Jomelo/LCDMenuLib2
4 |
5 | //LCDMenuLib2_menu LCDML_0 (255, 0, 0, NULL, NULL); // root menu element (do not change)
6 | //extern LCDMenuLib2 LCDML(LCDML_0, _LCDML_DISP_rows, _LCDML_DISP_cols, lcdml_menu_display, lcdml_menu_clear, lcdml_menu_control);
7 | LiquidCrystal_I2C lcd(0x27,_LCDML_DISP_cols,_LCDML_DISP_rows);
8 | //extern LCDML;
9 | displayUtils::displayUtils(){
10 | }
11 |
12 | // =====================================================================
13 | //
14 | // Output function
15 | //
16 | // =====================================================================
17 |
18 | void lcdml_menu_control(void)
19 | {
20 | // If something must init, put in in the setup condition
21 | if(LCDML.BT_setup()) {
22 | // runs only once
23 | }
24 |
25 | // check if new serial input is available
26 | if (Serial.available()) {
27 | // read one char from input buffer
28 | /*switch (Serial.read())
29 | {
30 | case _LCDML_CONTROL_serial_enter: LCDML.BT_enter(); break;
31 | case _LCDML_CONTROL_serial_up: LCDML.BT_up(); break;
32 | case _LCDML_CONTROL_serial_down: LCDML.BT_down(); break;
33 | case _LCDML_CONTROL_serial_left: LCDML.BT_left(); break;
34 | case _LCDML_CONTROL_serial_right: LCDML.BT_right(); break;
35 | case _LCDML_CONTROL_serial_quit: LCDML.BT_quit(); break;
36 | default: break;
37 | }*/
38 | }
39 | }
40 |
41 | /* ******************************************************************** */
42 | void lcdml_menu_clear()
43 | /* ******************************************************************** */
44 | {
45 | lcd.clear();
46 | lcd.setCursor(0, 0);
47 | }
48 |
49 | /* ******************************************************************** */
50 | void lcdml_menu_display()
51 | /* ******************************************************************** */
52 | {
53 | // update content
54 | // ***************
55 | if (LCDML.DISP_checkMenuUpdate()) {
56 | // clear menu
57 | // ***************
58 | LCDML.DISP_clear();
59 |
60 | // declaration of some variables
61 | // ***************
62 | // content variable
63 | char content_text[_LCDML_DISP_cols]; // save the content text of every menu element
64 | // menu element object
65 | LCDMenuLib2_menu *tmp;
66 | // some limit values
67 | uint8_t i = LCDML.MENU_getScroll();
68 | uint8_t maxi = _LCDML_DISP_rows + i;
69 | uint8_t n = 0;
70 |
71 | // check if this element has children
72 | if ((tmp = LCDML.MENU_getDisplayedObj()) != NULL)
73 | {
74 | // loop to display lines
75 | do
76 | {
77 | // check if a menu element has a condition and if the condition be true
78 | if (tmp->checkCondition())
79 | {
80 | // check the type off a menu element
81 | if(tmp->checkType_menu() == true)
82 | {
83 | // display normal content
84 | LCDML_getContent(content_text, tmp->getID());
85 | lcd.setCursor(1, n);
86 | lcd.print(content_text);
87 | }
88 | else
89 | {
90 | if(tmp->checkType_dynParam()) {
91 | tmp->callback(n);
92 | }
93 | }
94 | // increment some values
95 | i++;
96 | n++;
97 | }
98 | // try to go to the next sibling and check the number of displayed rows
99 | } while (((tmp = tmp->getSibling(1)) != NULL) && (i < maxi));
100 | }
101 | }
102 |
103 | if(LCDML.DISP_checkMenuCursorUpdate())
104 | {
105 | // init vars
106 | uint8_t n_max = (LCDML.MENU_getChilds() >= _LCDML_DISP_rows) ? _LCDML_DISP_rows : (LCDML.MENU_getChilds());
107 | uint8_t scrollbar_min = 0;
108 | uint8_t scrollbar_max = LCDML.MENU_getChilds();
109 | uint8_t scrollbar_cur_pos = LCDML.MENU_getCursorPosAbs();
110 | uint8_t scroll_pos = ((1.*n_max * _LCDML_DISP_rows) / (scrollbar_max - 1) * scrollbar_cur_pos);
111 |
112 |
113 | // display rows
114 | for (uint8_t n = 0; n < n_max; n++)
115 | {
116 | //set cursor
117 | lcd.setCursor(0, n);
118 |
119 | //set cursor char
120 | if (n == LCDML.MENU_getCursorPos()) {
121 | lcd.write(_LCDML_DISP_cfg_cursor);
122 | } else {
123 | lcd.write(' ');
124 | }
125 |
126 | // delete or reset scrollbar
127 | if (_LCDML_DISP_cfg_scrollbar == 1) {
128 | if (scrollbar_max > n_max) {
129 | lcd.setCursor((_LCDML_DISP_cols - 1), n);
130 | lcd.write((uint8_t)0);
131 | }
132 | else {
133 | lcd.setCursor((_LCDML_DISP_cols - 1), n);
134 | lcd.print(' ');
135 | }
136 | }
137 | }
138 |
139 | // display scrollbar
140 | if (_LCDML_DISP_cfg_scrollbar == 1) {
141 | if (scrollbar_max > n_max) {
142 | //set scroll position
143 | if (scrollbar_cur_pos == scrollbar_min) {
144 | // min pos
145 | lcd.setCursor((_LCDML_DISP_cols - 1), 0);
146 | lcd.write((uint8_t)1);
147 | } else if (scrollbar_cur_pos == (scrollbar_max - 1)) {
148 | // max pos
149 | lcd.setCursor((_LCDML_DISP_cols - 1), (n_max - 1));
150 | lcd.write((uint8_t)4);
151 | } else {
152 | // between
153 | lcd.setCursor((_LCDML_DISP_cols - 1), scroll_pos / n_max);
154 | lcd.write((uint8_t)(scroll_pos % n_max) + 1);
155 | }
156 | }
157 | }
158 | }
159 | }
