1 | #include "../Includes/main.h"
2 |
3 | void GoSleep( void )
4 | {
5 | GIMSK |= _BV(INT0); // Enable Pin Change Interrupts
6 | ADCSRA &= ~_BV(ADEN); // ADC off
7 | set_sleep_mode(SLEEP_MODE_PWR_DOWN); // replaces above statement
8 | sleep_enable(); // Sets the Sleep Enable bit in the MCUCR Register (SE BIT)
9 | sei(); // Enable interrupts
10 | sleep_cpu(); // sleep
11 | cli(); // Disable interrupts
12 | sleep_disable(); // Clear SE bit
13 | ADCSRA |= _BV(ADEN); // ADC on
14 | sei(); // Enable interrupts
15 | }
16 |
17 | void ConfigInterrupt( void )
18 | {
19 | GIMSK |= ( 1 << INT0 );
20 | MCUCR |= 1<<ISC00;
21 | }
22 |
23 | void Timer100us ( void )
24 | {
25 | if ( sTime.uiMilli++ > 9999 )
26 | {
27 | sTime.uiMilli = 0;
28 | sTime.uiSecound++;
29 | }
30 |
31 | if ( uiDebounce++ > 25 )
32 | {
33 | uiDebounce = 0;
34 | SwitchRead( &sKey );
35 | }
36 |
37 |
38 | static uint8_t uiPwmCnt = 0;
39 | if ( uiPwmCnt++ > 50 )
40 | {
41 | uiPwmCnt = 0;
42 | }
43 |
44 | if ( uiPwmCnt >= uiPwmLed[0] )
45 | {
46 | ShiftRegClearBit(0);
47 | }
48 | else
49 | {
50 | ShiftRegSetBit(0);
51 | }
52 |
53 | if ( uiPwmCnt >= uiPwmLed[1] )
54 | {
55 | ShiftRegClearBit(1);
56 | }
57 | else
58 | {
59 | ShiftRegSetBit(1);
60 | }
61 |
62 | if ( uiPwmCnt >= uiPwmLed[2] )
63 | {
64 | ShiftRegClearBit(2);
65 | }
66 | else
67 | {
68 | ShiftRegSetBit(2);
69 | }
70 |
71 | if ( uiPwmCnt >= uiPwmLed[3] )
72 | {
73 | ShiftRegClearBit(3);
74 | }
75 | else
76 | {
77 | ShiftRegSetBit(3);
78 | }
79 |
80 | if ( uiPwmCnt >= uiPwmLed[4] )
81 | {
82 | ShiftRegClearBit(4);
83 | }
84 | else
85 | {
86 | ShiftRegSetBit(4);
87 | }
88 |
89 | if ( uiPwmCnt >= uiPwmLed[5] )
90 | {
91 | ShiftRegClearBit(5);
92 | }
93 | else
94 | {
95 | ShiftRegSetBit(5);
96 | }
97 |
98 | if ( uiPwmCnt >= uiPwmLed[6] )
99 | {
100 | ShiftRegClearBit(6);
101 | }
102 | else
103 | {
104 | ShiftRegSetBit(6);
105 | }
106 |
107 | if ( uiPwmCnt >= uiPwmLed[7] )
108 | {
109 | ShiftRegClearBit(7);
110 | }
111 | else
112 | {
113 | ShiftRegSetBit(7);
114 | }
115 |
116 | if ( uiPwmCnt >= uiPwmLed[8] )
117 | {
118 | ShiftRegClearBit(8);
119 | }
120 | else
121 | {
122 | ShiftRegSetBit(8);
123 | }
124 |
125 | ShiftRegUpdate();
126 | }
127 |
128 | ISR ( INT0_vect )
129 | {
130 | // nur zum aufwachen..
131 | }
132 |
133 | uint8_t uiMask = 0x01;
134 |
135 | int main(void)
136 | {
137 | ShiftRegInit();
138 |
139 | SwitchInit( &sKey , &KEY_PORT , 1<<KEY_BP , 1<<KEY_BP , 1<<KEY_BP );
140 |
141 | Timer0CompAInit( &sTimer0OcieSettings[1] , Timer100us );
142 |
143 | ConfigInterrupt();
144 |
145 | while (1)
146 | {
147 | static uint8_t uiMode = 0;
148 |
149 | if ( SwitchGet( &sKey , 1<<KEY_BP ) )
150 | {
151 | if ( uiMode++ > 3 )
152 | {
153 | uiMode = 0;
154 | }
155 | }
156 |
157 | switch ( uiMode )
158 | {
159 | case 0:
160 | for ( uint8_t x = 0 ; x < 50 ; x++ )
161 | {
162 | uiPwmLed[0] = x;
163 | uiPwmLed[1] = x;
164 | uiPwmLed[2] = x;
165 | uiPwmLed[3] = x;
166 | uiPwmLed[4] = x;
167 | uiPwmLed[5] = x;
168 | uiPwmLed[6] = x;
169 | uiPwmLed[7] = x;
170 | _delay_us( 25 );
171 | }
172 |
173 | for ( uint8_t x = 0 ; x < 50 ; x++ )
174 | {
175 | uiPwmLed[0] = 50 - x;
176 | uiPwmLed[1] = 50 - x;
177 | uiPwmLed[2] = 50 - x;
178 | uiPwmLed[3] = 50 - x;
179 | uiPwmLed[4] = 50 - x;
180 | uiPwmLed[5] = 50 - x;
181 | uiPwmLed[6] = 50 - x;
182 | uiPwmLed[7] = 50 - x;
183 | _delay_us( 25 );
184 | }
185 |
186 | break;
187 |
188 | case 1:
189 | for ( uint8_t x = 0 ; x < 8 ; x++ )
190 | {
191 | uiPwmLed[x] = 50;
192 | _delay_us(25);
193 | uiPwmLed[x] = 0;
194 | }
195 | break;
196 |
197 | case 2:
198 |
199 | for ( uint8_t y = 0 ; y < 3 ; y++ )
200 | {
201 | for ( uint8_t x = 0 ; x < 8 ; x++ )
202 | {
203 | uiPwmLed[x] = 50;
204 | }
205 |
206 | _delay_us( 10 );
207 |
208 | for ( uint8_t x = 0 ; x < 8 ; x++ )
209 | {
210 | uiPwmLed[x] = 0;
211 | }
212 |
213 | _delay_us( 100 );
214 | }
215 |
216 | _delay_us( 1500 );
217 |
218 | break;
219 |
220 | case 3:
221 | uiMode = 0;
222 | //GoSleep();
223 | break;
224 | }
225 | }
226 | }
