1 | #include <Wire.h>
2 | #include <SparkFun_APDS9960.h>
3 |
4 | // Pins on wemos D1 mini
5 | #define APDS9960_INT D6 //AKA GPIO12 -- Interupt pin
6 | #define APDS9960_SDA D3 //AKA GPIO0
7 | #define APDS9960_SCL D1 //AKA GPIO5
8 | #define LED_PIN D7 //AKA GPIO13 -- LED for showing interrupt
9 |
10 | // Constants
11 | #define PROX_INT_HIGH 255 // Proximity level for interrupt
12 | #define PROX_INT_LOW 0 // No far interrupt
13 |
14 | // Global variables
15 | SparkFun_APDS9960 apds = SparkFun_APDS9960();
16 | uint8_t proximity_data = 0;
17 | volatile bool isr_flag = 0;
18 |
19 | void setup() {
20 |
21 | //Start I2C with pins defined above
22 | Wire.begin(APDS9960_SDA,APDS9960_SCL);
23 |
24 | // Set LED as output
25 | pinMode(LED_PIN, OUTPUT);
26 | pinMode(APDS9960_INT, INPUT);
27 |
28 | // Initialize Serial port
29 | Serial.begin(115200);
30 | Serial.println();
31 | Serial.println(F("---------------------------------------"));
32 | Serial.println(F("SparkFun APDS-9960 - ProximityInterrupt"));
33 | Serial.println(F("---------------------------------------"));
34 |
35 | // Initialize interrupt service routine
36 | attachInterrupt(APDS9960_INT, interruptRoutine, FALLING);
37 |
38 | // Initialize APDS-9960 (configure I2C and initial values)
39 | if ( apds.init() ) {
40 | Serial.println(F("APDS-9960 initialization complete"));
41 | } else {
42 | Serial.println(F("Something went wrong during APDS-9960 init!"));
43 | }
44 |
45 | // Adjust the Proximity sensor gain
46 | if ( !apds.setProximityGain(PGAIN_8X) ) {
47 | Serial.println(F("Something went wrong trying to set PGAIN"));
48 | }
49 |
50 | // Set proximity interrupt thresholds
51 | if ( !apds.setProximityIntLowThreshold(PROX_INT_LOW) ) {
52 | Serial.println(F("Error writing low threshold"));
53 | }
54 | if ( !apds.setProximityIntHighThreshold(PROX_INT_HIGH) ) {
55 | Serial.println(F("Error writing high threshold"));
56 | }
57 |
58 | // Start running the APDS-9960 proximity sensor (interrupts)
59 | if ( apds.enableProximitySensor(true) ) {
60 | Serial.println(F("Proximity sensor is now running"));
61 | } else {
62 | Serial.println(F("Something went wrong during sensor init!"));
63 | }
64 | }
65 |
66 | void loop() {
67 |
68 | // If interrupt occurs, print out the proximity level
69 | if ( isr_flag == 1 ) {
70 |
71 | // Read proximity level and print it out
72 | if ( !apds.readProximity(proximity_data) ) {
73 | Serial.println("Error reading proximity value");
74 | } else {
75 | Serial.print("Proximity detected! Level: ");
76 | Serial.println(proximity_data);
77 | }
78 |
79 | // Turn on LED for a half a second
80 | digitalWrite(LED_PIN, HIGH);
81 | delay(500);
82 | digitalWrite(LED_PIN, LOW);
83 |
84 | // Reset flag and clear APDS-9960 interrupt (IMPORTANT!)
85 | isr_flag = 0;
86 | if ( !apds.clearProximityInt() ) {
87 | Serial.println("Error clearing interrupt");
88 | }
89 |
90 | }
91 | }
92 |
93 | ICACHE_RAM_ATTR void interruptRoutine() {
94 | isr_flag = 1;
95 | //Serial.println("Interrupt");
96 | }
