1 | /*
2 | * Ultrasonic sensor HC-05 interfacing with AVR ATmega16
3 | * http://www.electronicwings.com
4 | */
5 |
6 | #define F_CPU 16000000UL
7 | #include <Arduino.h>
8 | #include <avr/io.h>
9 | #include <avr/interrupt.h>
10 | #include <util/delay.h>
11 | #include <stdlib.h>
12 |
13 | #define Trigger_pin PA0 /* Trigger pin */
14 |
15 | int TimerOverflow = 0;
16 | double count = 0;
17 | double speed = 0;
18 | double distance = 0;
19 |
20 | double mittelwert = 0;
21 |
22 | uint8_t intterupt = 0;
23 | uint8_t logCounter = 0;
24 |
25 | ISR(INT0_vect)
26 | {
27 | intterupt = 1;
28 | }
29 |
30 | ISR(TIMER4_OVF_vect)
31 | {
32 | TimerOverflow++; /* Increment Timer Overflow count */
33 | }
34 |
35 | void interruptconfig()
36 | {
37 | EICRA |= (1 << ISC01) | (1 << ISC00);
38 | EIMSK |= (1 << INT0);
39 | // sei();
40 | }
41 |
42 | int main(void)
43 | {
44 | // char string[10];
45 | // long count;
46 | // double distance;
47 | interruptconfig();
48 | Serial.begin(9600);
49 |
50 | DDRA = (1 << Trigger_pin); /* Make trigger pin as output */
51 | PORTA = (1 << Trigger_pin); /* Turn on Pull-up */
52 |
53 | sei(); /* Enable global interrupt */
54 | TIMSK4 = (1 << TOIE4); /* Enable Timer1 overflow interrupts */
55 | TCCR4A = 0; /* Set all bit to zero Normal operation */
56 |
57 | while (1)
58 | {
59 | /* Give 10us trigger pulse on trig. pin to HC-SR04 */
60 | PORTA |= (1 << Trigger_pin);
61 | _delay_us(10);
62 | PORTA &= (~(1 << Trigger_pin));
63 |
64 | TCNT4 = 0; /* Clear Timer counter */
65 | TCCR4B = 0x41; /* Capture on rising edge, No prescaler*/
66 | TIFR4 = 1 << ICF4; /* Clear ICP flag (Input Capture flag) */
67 | TIFR4 = 1 << TOV4; /* Clear Timer Overflow flag */
68 | TimerOverflow = 0; /* Clear Timer overflow count */
69 | /*Calculate width of Echo by Input Capture (ICP) */
70 |
71 | while ((TIFR4 & (1 << ICF4)) == 0)
72 | ; /* Wait for rising edge */
73 | TCNT4 = 0; /* Clear Timer counter */
74 | TCCR4B = 0x01; /* Capture on falling edge, No prescaler */
75 | TIFR4 = 1 << ICF4; /* Clear ICP flag (Input Capture flag) */
76 | TIFR4 = 1 << TOV4; /* Clear Timer Overflow flag */
77 | // TimerOverflow = 0; /* Clear Timer overflow count */
78 |
79 | while ((TIFR4 & (1 << ICF4)) == 0)
80 | ; /* Wait for falling edge */
81 | count = ICR4 + (65535 * TimerOverflow); /* Take count */
82 | /* 8MHz Timer freq, sound speed =343 m/s */
83 | //54.88 cm *100 / (count * taktDauer / 100) =
84 | speed = distance / (((double)count * 62.5) / 100);
85 |
86 | if (intterupt == 1)
87 | {
88 | Serial.print("Distanz: ");
89 | intterupt = 0;
90 | distance = (double)count / 465.6;
91 | Serial.println(distance);
92 | }
93 |
94 | logCounter++;
95 |
96 | mittelwert = (double)(mittelwert + (((speed * 100000) - 343) * 1000));
97 |
98 | if (logCounter == 10)
99 | {
100 | logCounter = 0;
101 | Serial.println((double)(mittelwert / 1000) / 10);
102 | mittelwert = 0;
103 | }
104 |
105 | // distance = (double)count / 466.47;
106 | // Serial.println((speed * 100000) - 343);
107 | // Serial.println((speed * 100000));
108 | // Serial.println(distance);
109 | _delay_ms(200);
110 | }
111 | }
