Hallo liebes Forum, Um die "ramp-time" des LT8625S einzustellen, steht im Datenblatt des LT8652S folgendes: SS2 (Pin 2): Channel 2 Output Tracking and Soft-Start Pin. This pin allows user control of output voltage ramp rate during start-up. A SS2 voltage below 0.6V forces the LT8652S to regulate the FB2 pin to equal the SS2 pin voltage. When SS2 is above 0.6V, the internal reference resumes control of the error amplifier. An internal 2µA pull-up current from VCC on this pin allows a capacitor to program output voltage slew rate. This pin is pulled to ground with a 200O MOSFET during shutdown and fault conditions; use a series resistor if driving from a low impedance output. This pin may be left floating if the soft-start feature is not being used. Ich verstehe nicht, wie ich jetzt den benötigten Kondensator für z.B. eine ramp-time von 300µs berechne. Danke für eure Hilfe!
pull-up current...
delta U = delta Q / C = I * delta t / C => C= I * delta t / delta U
C= 2µA * 300µs (wirklich so klein?? warum nicht ~10ms?) / 0,6V = 1nF
