Hallo zusammen, hat jemand irgendetwas Belastbares zum Einführungsdatum der DD-Serie (downsized DA/DB)? Danke.
Hallo, auf Github findet man nur folgendes Text eines Users. The DD-series is a smaller-pincount line; parts are available with 14-32 pins. They've got the MVIO (3 or 4 MVIO pins depending on pincount). The product brief claims 10 output pins, 11 input pins, on the 14-pin package. With VDD, VDDIO, and GND. That implies that there will be a way to configure the UPDI pin to act as an I/O pin, and Reset to act as an input only if configured appropirately in the fuses. We'll have to wait until more information is available, but it sounds like the reset pin on these parts will be the pin that needs the HV pulse (likely)
Die 28/32er sollen Mitte des Jahres erscheinen, die 14/20er am Ende des Jahres.
