1 | #include <stdlib.h>
2 | #include <stdio.h>
3 | #include <string.h>
4 |
5 | #include "arduinoFFT.h"
6 | arduinoFFT FFT = arduinoFFT(); /* Create FFT object */
7 |
8 | #define DEBUG_INP (0)
9 | #define DEBUG_OUT (1)
10 |
11 | #define OUT_Canel (16)
12 | #define FFT_Samples (64)
13 | #define OPT_Half (2046)
14 |
15 | double vReal[FFT_Samples];
16 | double vImag[FFT_Samples];
17 |
18 | char sTemp[80];
19 |
20 | void setup()
21 | {
22 | Serial.begin(115200);
23 | while(!Serial);
24 | Serial.println("Ready");
25 | //--------------------------------------------
26 | // Init Register
27 | // setup mode register
28 | //analogReadResolution(12);
29 | ADC->ADC_MR = ADC_MR_FREERUN_ON | ADC_MR_SLEEP_NORMAL | ADC_MR_FWUP_OFF;
30 | ADC->ADC_MR |= ADC_MR_LOWRES_BITS_12;
31 | ADC->ADC_MR |= ADC_MR_STARTUP_SUT512; // startup time as per default
32 | ADC->ADC_MR |= ADC_MR_PRESCAL(168); // set clock prescalar to run as fast as possible
33 | ADC->ADC_MR |= ADC_MR_SETTLING_AST3; //settling time if the analog chanel is switched (dosn't mater if ANACH is not set)
34 | ADC->ADC_MR |= ADC_MR_ANACH_NONE;
35 | ADC->ADC_MR |= ADC_MR_TRACKTIM(0); // minimal tracking time
36 | ADC->ADC_MR |= ADC_MR_TRANSFER(0); // minimal transfer time
37 | // enable channel
38 | ADC->ADC_CHER = ADC_CHER_CH7 | ADC_CHER_CH6; //enable ADC on pin A0 (channel 7) + A1}
39 | delay(10); // wait for init adc
40 | }
41 |
42 | void loop() {
43 | #if DEBUG_INP
44 | Serial.print("InpData:");
45 | #endif
46 | int value = 0;
47 | while(ADC->ADC_ISR == ADC_ISR_EOC6); // warte bis Messung fertig
48 | for (int i = 0; i < FFT_Samples; i++) { // Alle Samples Messen
49 | #if DEBUG_INP
50 | if (i % 8 == 0)
51 | Serial.println("");
52 | #endif
53 | // Read ADC
54 | while(ADC->ADC_ISR == ADC_ISR_EOC6); // warte bis Messung fertig
55 | value = (int)ADC->ADC_CDR[6]; // Lese A1
56 | vReal[i] = ((value - OPT_Half) / 25.6f); // Copy to bins after compressing +-80.000
57 | vImag[i] = 0;
58 | #if DEBUG_INP
59 | sprintf(sTemp, "%++05ld,", (long)(vReal[i]));
60 | //sprintf(sTemp, "%++05ld,", value);
61 | Serial.print(sTemp);
62 | #endif
63 | }
64 | #if DEBUG_INP
65 | Serial.println("");
66 | #endif
67 | //--------------------------------------------
68 | // Calc FFT
69 | int iData[16];
70 | FFT.Windowing(vReal, FFT_Samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
71 | FFT.Windowing(vReal, FFT_Samples, FFT_WIN_TYP_HAMMING, FFT_FORWARD);
72 | FFT.Compute(vReal, vImag, FFT_Samples, FFT_FORWARD);
73 | FFT.ComplexToMagnitude(vReal, vImag, FFT_Samples);
74 | //double peak = FFT.MajorPeak(vReal, FFT_Samples, SAMPLING_FREQUENCY);
75 |
76 | int iStep = (FFT_Samples / 2) / OUT_Canel;
77 | for(int i = 0, j = 0; i < (FFT_Samples / 2); i += iStep) {
78 | iData[j] = 0;
79 | for (int k=0 ; k < iStep ; k++)
80 | iData[j] += vReal[i+k];
81 | iData[j] /= iStep;
82 | j++;
83 | }
84 |
85 | FFT.Windowing(vReal, FFT_Samples ,FFT_WIN_TYP_BLACKMAN_HARRIS, FFT_FORWARD); /* Weigh data */
86 | FFT.Compute(vReal, vImag, FFT_Samples , FFT_FORWARD); /* Compute FFT */
87 | FFT.ComplexToMagnitude(vReal, vImag, FFT_Samples ); /* Compute magnitudes */
88 | //FFT.MajorPeak(vReal, FFT_Samples , samplingFrequency, &x, &v);
89 |
90 | //--------------------------------------------
91 | // Werte Anzeigen
92 | #if DEBUG_OUT
93 | Serial.print("OutData:");
94 | for(int i = 0; i < OUT_Canel; i++) {
95 | sprintf(sTemp, "%+04d|", iData[i]);
96 | Serial.print(sTemp);
97 | }
98 | Serial.println("");
99 | #endif
100 | delay(100);
101 | }
