Hallo zusammen, Ich habe mir eine Umgebung über Platformio erstellt um die AVRmega0 Serie zu programmieren. Diese verwenden UPDI als Programmierschnittstelle. Ich verwende pyUPDI als Uploader. Leider habe ich ein paar Probleme, wenn ich den "UPLOAD" Button in Platformio benutze: Processing ATmega808 (platform: atmelmegaavr; board: ATmega808; framework: ) ------------------------------------------------------------------------ ------------------------------------------------------------------------ ----------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option CONFIGURATION: https://docs.platformio.org/page/boards/atmelmegaavr/ATmega808.html PLATFORM: Atmel megaAVR (1.5.0) > ATmega808 HARDWARE: ATMEGA808 16MHz, 1KB RAM, 8KB Flash PACKAGES: - tool-avrdude-megaavr 1.60300.191015 (6.3.0) - toolchain-atmelavr 1.70300.191015 (7.3.0) LDF: Library Dependency Finder -> LDF Modes: Finder ~ chain, Compatibility ~ soft Found 0 compatible libraries Scanning dependencies... No dependencies Building in release mode Checking size .pio\build\ATmega808\firmware.elf Advanced Memory Usage is available via "PlatformIO Home > Project Inspect" RAM: [ ] 0.0% (used 0 bytes from 1024 bytes) Flash: [ ] 1.5% (used 124 bytes from 8192 bytes) Configuring upload protocol... AVAILABLE: jtag2updi CURRENT: upload_protocol = jtag2updi Looking for upload port... Auto-detected: COM3 Forcing reset using 1200bps open/close on port COM3 Uploading .pio\build\ATmega808\firmware.hex Traceback (most recent call last): File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\Scripts\pyupd i-script.py", line 33, in <module> sys.exit(load_entry_point('pyupdi==0.0.0', 'console_scripts', 'pyupdi')()) File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\Scripts\pyupd i-script.py", line 25, in importlib_load_entry_point return next(matches).load() File "C:\Users\gigauser\.platformio\python3\lib\importlib\metadata.py", line 77, in load module = import_module(match.group('module')) File "C:\Users\gigauser\.platformio\python3\lib\importlib\__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "<frozen importlib._bootstrap>", line 1050, in _gcd_import File "<frozen importlib._bootstrap>", line 1027, in _find_and_load File "<frozen importlib._bootstrap>", line 1006, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 688, in _load_unlocked File "<frozen importlib._bootstrap_external>", line 883, in exec_module File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\__init__.py", line 1, in <module> from .pyupdi import _main File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\pyupdi.py", line 11, in <module> from updi.nvm import UpdiNvmProgrammer File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\nvm.py", line 6, in <module> from updi.application import UpdiApplication File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\application.py", line 7, in <module> from updi.link import UpdiDatalink File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\link.py", line 7, in <module> from updi.physical import UpdiPhysical File "C:\Users\gigauser\AppData\Local\Programs\Python\Python310\lib\site-pack ages\updi\physical.py", line 6, in <module> import serial File "C:\Users\gigauser\.platformio\penv\lib\site-packages\serial\__init__.py ", line 29, in <module> from serial.serialwin32 import Serial File "C:\Users\gigauser\.platformio\penv\lib\site-packages\serial\serialwin32 .py", line 15, in <module> import ctypes File "C:\Users\gigauser\.platformio\python3\lib\ctypes\__init__.py", line 8, in <module> from _ctypes import Union, Structure, Array ImportError: DLL load failed while importing _ctypes: The specified module could not be found. *** [upload] Error 1 ======================================================================== ================== [FAILED] Took 2.24 seconds ======================================================================== ==================The terminal process "C:\Users\gigauser\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload', '--environment', 'ATmega808'" terminated with exit code: 1. Rufe ich pyUPDI im Terminal auf, funktioniert alles wie gewollt: pyupdi -d mega808 -c COM3 -b 115200 -f .pio/build/ATmega808/firmware.hex Device info: {'family': 'megaAVR', 'nvm': 'P:0', 'ocd': 'D:1', 'osc': '3', 'device_id': '1E9326', 'device_rev': '0.0'} Programming successful Meine platformio.ini sieht wie folgt aus: [env:ATmega808] platform = atmelmegaavr board = ATmega808 framework = upload_speed = 115200 upload_flags = -d mega808 -c $UPLOAD_PORT -b $UPLOAD_SPEED upload_command = pyupdi $UPLOAD_FLAGS -f $SOURCE Ich bin mir sicher das ist nur ein kleines Problem, ich habe aber leider keine Ahnung von Python oder tiefgehender Konfiguration in Platformio. Bin für jede Hilfe dankbar!
gigauser schrieb: > Bin für jede Hilfe dankbar! Seltsam. Es soll Leute geben die sich damit auskennen. https://platformio.org/support Aber vielleicht wollen sie Geld von dir haben ....
Dort habe ich auch Hilfe bekommen, Danke! Nur habe ich darauf verzichtet überall sonst zu posten das mein Problem gelöst wurde. Seltsam....
Thomas F. schrieb: > Nur habe ich darauf verzichtet > überall sonst zu posten das mein Problem gelöst wurde. > > Seltsam Wirklich seltsam, wie waere es mit einem Link auf die Loesung? wendelsberg
