Hallo Juergen O. sorry dass ich den Thread (Beitrag "EMS > ESP8266-12 WLAN-Modul") nochmal ausgrabe. Irgendwie bekomme ich den ESP8266 nicht ans Laufen. Ich wollte die SW erst mal an einem D1 mini Board testen. Scheinbar hängt der Controller in einer Boot-Schleife; es wiederholt sich immer wieder (Ausgabe Seriell): ets Jan 8 2013,rst cause:2, boot mode:(3,6) load 0x40100000, len 1396, room 16 tail 4 chksum 0x89 load 0x3ffe8000, len 776, room 4 tail 4 chksum 0xe8 load 0x3ffe8308, len 540, room 4 tail 8 chksum 0xc0 csum 0xc0 2nd boot version : 1.4(b1) SPI Speed : 40MHz SPI Mode : QIO SPI Flash Size & Map: 4Mbit(256KB+256KB) jump to run user1 @ 1000 Geflasht habe ich den Inhalt von ems-esp-link-stable, ems-esp-link-stable\ems-link.tgz: C:\Users\andreas\AppData\Roaming\Python\Python39\Scripts>esptool.py.exe --port COM4 write_flash 0x00000 C:\Temp\ems\boot_v1.4(b1).bin 0x01000 C:\Temp\ems\user1.bin 0x3FE000 C:\Temp\ems\blank.bin 0x7FE000 C:\Temp\ems\blank.bin esptool.py v3.2 Serial port COM4 Connecting.... Detecting chip type... Unsupported detection protocol, switching and trying again... Connecting.... Detecting chip type... ESP8266 Chip is ESP8266EX Features: WiFi Crystal is 26MHz MAC: cc:50:e3:17:8f:86 Uploading stub... Running stub... Stub running... Configuring flash size... Flash will be erased from 0x00000000 to 0x00000fff... Flash will be erased from 0x00001000 to 0x0003afff... Flash will be erased from 0x003fe000 to 0x003fefff... Flash will be erased from 0x007fe000 to 0x007fefff... Compressed 2752 bytes to 2007... Wrote 2752 bytes (2007 compressed) at 0x00000000 in 0.2 seconds (effective 92.5 kbit/s)... Hash of data verified. Compressed 235076 bytes to 176420... Wrote 235076 bytes (176420 compressed) at 0x00001000 in 15.6 seconds (effective 120.2 kbit/s)... Hash of data verified. Compressed 4096 bytes to 26... Wrote 4096 bytes (26 compressed) at 0x003fe000 in 0.0 seconds (effective 819.7 kbit/s)... Hash of data verified. Compressed 4096 bytes to 26... Wrote 4096 bytes (26 compressed) at 0x007fe000 in 0.0 seconds (effective 825.4 kbit/s)... Hash of data verified. Leaving... Hard resetting via RTS pin... @Juergen O. (strolch): Hast du eine Ahnung warum der Controller immer wieder neu bootet? Es wird auch kein WLAN-Netz aufgespannt. Viele Grüße, Andreas
Hallo Andreas, meist taucht dieses Problem auf wenn in der IDE die Parameter nicht stimmen, sprich das Binary ab $1000 nicht für $1000 kompiliert wurde oder die Libs nicht zur IDE passen. Da ich a) nicht weiss wie du zu diesem Binary gekommen bist b) mit Windows absolut nix am Hut habe c) das Repo schon mumifiziert ist empfehle ich dir auf EMS-ESP zu gehen, da die Jungs auch ein sauber gepflegtes Wiki / Doc haben. https://github.com/emsesp/EMS-ESP Ich selbst verwende EMS-ESP - habe da vor Jahren mitgebastelt - und kann es nur empfehlen. Beste Grüße Jürgen
Hallo Jürgen, danke für die Antwort, leider komme ich erst jetzt zum Lesen :-( Ist die SW auch für einen Buderus Logamax GB12 aus dem Jahre 2002 geeignet? Als Bus-Koppler habe ich diese HW: Beitrag "EMS > ESP8266-12 WLAN-Modul" Viele Grüße und ein frohes neues Jahr, Andreas
