1 | rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
2 | configsip: 0, SPIWP:0xee
3 | clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
4 | mode:DIO, clock div:2
5 | load:0x3fff0030,len:4
6 | load:0x3fff0034,len:7056
7 | ho 0 tail 12 room 4
8 | load:0x40078000,len:13212
9 | load:0x40080400,len:4568
10 | entry 0x400806f4
11 | I (30) boot: ESP-IDF v4.2-dirty 2nd stage bootloader
12 | I (30) boot: compile time 10:15:36
13 | I (31) boot: chip revision: 1
14 | I (34) boot_comm: chip revision: 1, min. bootloader chip revision: 0
15 | I (41) boot.esp32: SPI Speed : 40MHz
16 | I (45) boot.esp32: SPI Mode : DIO
17 | I (50) boot.esp32: SPI Flash Size : 2MB
18 | I (54) boot: Enabling RNG early entropy source...
19 | I (60) boot: Partition Table:
20 | I (63) boot: ## Label Usage Type ST Offset Length
21 | I (71) boot: 0 nvs WiFi data 01 02 00009000 00006000
22 | I (78) boot: 1 phy_init RF data 01 01 0000f000 00001000
23 | I (86) boot: 2 factory factory app 00 00 00010000 00100000
24 | I (93) boot: End of partition table
25 | I (97) boot_comm: chip revision: 1, min. application chip revision: 0
26 | I (104) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x097bc ( 38844) map
27 | I (128) esp_image: segment 1: paddr=0x000197e4 vaddr=0x3ffb0000 size=0x021e0 ( 8672) load
28 | I (132) esp_image: segment 2: paddr=0x0001b9cc vaddr=0x40080000 size=0x00404 ( 1028) load
29 | I (135) esp_image: segment 3: paddr=0x0001bdd8 vaddr=0x40080404 size=0x04240 ( 16960) load
30 | I (151) esp_image: segment 4: paddr=0x00020020 vaddr=0x400d0020 size=0x18970 (100720) map
31 | I (191) esp_image: segment 5: paddr=0x00038998 vaddr=0x40084644 size=0x067a0 ( 26528) load
32 | I (209) boot: Loaded app from partition at offset 0x10000
33 | I (209) boot: Disabling RNG early entropy source...
34 | I (210) cpu_start: Pro cpu up.
35 | I (213) cpu_start: Application information:
36 | I (218) cpu_start: Project name: empty
37 | I (223) cpu_start: App version: cf459c5-dirty
38 | I (228) cpu_start: Compile time: Mar 13 2022 11:15:43
39 | I (234) cpu_start: ELF file SHA256: 853443c441f6a1ce...
40 | I (240) cpu_start: ESP-IDF: v4.2-dirty
41 | I (246) cpu_start: Starting app cpu, entry point is 0x400816cc
42 | I (0) cpu_start: App cpu up.
43 | I (256) heap_init: Initializing. RAM available for dynamic allocation:
44 | I (263) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
45 | I (269) heap_init: At 3FFB3F70 len 0002C090 (176 KiB): DRAM
46 | I (275) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
47 | I (282) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
48 | I (288) heap_init: At 4008ADE4 len 0001521C (84 KiB): IRAM
49 | I (294) cpu_start: Pro cpu start user code
50 | I (313) spi_flash: detected chip: generic
51 | I (313) spi_flash: flash io: dio
52 | W (313) spi_flash: Detected size(4096k) larger than the size in the binary image header(2048k). Using the size in the binary image header.
53 | I (324) cpu_start: Starting scheduler on PRO CPU.
54 | I (0) cpu_start: Starting scheduler on APP CPU.
55 | I (334) system_api: Base MAC address is not set
56 | I (344) system_api: read default base MAC address from EFUSE
57 | I (344) WIFI_STA MAC: 0x8c, 0xaa, 0xb5, 0x8b, 0x25, 0x50
58 | I (354) main: Starting program
59 | I (394) main: Done nvs_flash_init
60 | I (394) main: Starting Tasks
61 | I (404) master: starting task
62 | I (404) master: esp_now_init()
63 | Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
64 |
65 | Core 0 register dump:
66 | PC : 0x400d74c0 PS : 0x00060030 A0 : 0x800d2f83 A1 : 0x3ffd06c0
67 | A2 : 0x00000000 A3 : 0x3ffb1428 A4 : 0x3ffb2a28 A5 : 0x00000194
68 | A6 : 0x3f403004 A7 : 0x00000000 A8 : 0x80088390 A9 : 0x3ffd0660
69 | A10 : 0x00000000 A11 : 0x00000005 A12 : 0x3f403068 A13 : 0x0000001f
70 | A14 : 0x00000001 A15 : 0x00000001 SAR : 0x00000004 EXCCAUSE: 0x0000001c
71 | EXCVADDR: 0x0000003c LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffe
72 |
73 | Backtrace:0x400d74bd:0x3ffd06c0 0x400d2f80:0x3ffd06e0 0x40084e01:0x3ffd0730
74 |
75 |
76 | ELF file SHA256: 853443c441f6a1ce
77 |
78 | Rebooting...
79 | ets Jun 8 2016 00:22:57
80 |
81 | rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
82 | configsip: 0, SPIWP:0xee
