1 | #include <string.h>
2 | #include <freertos/FreeRTOS.h>
3 | #include <freertos/task.h>
4 | #include <freertos/event_groups.h>
5 | #include <esp_log.h>
6 | #include <esp_sleep.h>
7 |
8 | #include "pirSensor.h"
9 |
10 | #define PIR_SENSOR_PIN GPIO_NUM_2
11 |
12 | #define PIR_SENSOR_HIGH_BIT BIT0
13 | #define PIR_SENSOR_LOW_BIT BIT1
14 |
15 | static EventGroupHandle_t pirSensorEventGroup;
16 | static uint8_t pirSensorLevel;
17 |
18 | static void pirSensorTask(void* pvParameters);
19 |
20 | static void IRAM_ATTR pirSensorIsrHandler(void* arg)
21 | {
22 | static const char *TAG = "pirSensorIsrHandler";
23 | pirSensorLevel = gpio_get_level(PIR_SENSOR_PIN);
24 | ESP_LOGI(TAG, "Level: %d", pirSensorLevel);
25 | if(0 != pirSensorLevel) xEventGroupSetBits(pirSensorEventGroup, PIR_SENSOR_HIGH_BIT);
26 | else xEventGroupSetBits(pirSensorEventGroup, PIR_SENSOR_LOW_BIT);
27 | }
28 |
29 | static void pirSensorTask(void* pvParameters)
30 | {
31 | const char *TAG = "pirSensorTask";
32 | ESP_LOGI(TAG, "starting task");
33 |
34 | esp_err_t result;
35 |
36 | EventBits_t uxBits;
37 | pirSensorEventGroup = xEventGroupCreate();
38 |
39 | /* configure sensor */
40 | gpio_config_t sensorConfig;
41 | sensorConfig.intr_type = GPIO_INTR_ANYEDGE;
42 | sensorConfig.mode = GPIO_MODE_INPUT;
43 | sensorConfig.pull_up_en = GPIO_PULLUP_DISABLE;
44 | sensorConfig.pull_down_en = GPIO_PULLDOWN_ENABLE;
45 | sensorConfig.pin_bit_mask = (1 << PIR_SENSOR_PIN);
46 | result = gpio_config(&sensorConfig);
47 | if(result != ESP_OK)
48 | {
49 | ESP_LOGE(TAG, "failed gpio_config: %s", esp_err_to_name(result));
50 | return;
51 | }
52 | ESP_LOGI(TAG, "pirSensor configured");
53 |
54 | /* get initial sensorlevel */
55 | pirSensorLevel = gpio_get_level(PIR_SENSOR_PIN);
56 |
57 | /* configure interrupt and add handler */
58 | result = gpio_install_isr_service(0);
59 | if(result != ESP_OK)
60 | {
61 | ESP_LOGE(TAG, "failed gpio_install_isr_service: %s", esp_err_to_name(result));
62 | return;
63 | }
64 | result = gpio_isr_handler_add(PIR_SENSOR_PIN, pirSensorIsrHandler, NULL);
65 | if(result != ESP_OK)
66 | {
67 | ESP_LOGE(TAG, "failed gpio_isr_handler_add: %s", esp_err_to_name(result));
68 | return;
69 | }
70 | ESP_LOGI(TAG, "ISR handler Pir-Sensor configured");
71 |
72 | while(1)
73 | {
74 | uxBits = xEventGroupWaitBits(
75 | pirSensorEventGroup,
76 | PIR_SENSOR_HIGH_BIT | PIR_SENSOR_LOW_BIT,
77 | pdFALSE,
78 | pdFALSE,
79 | portMAX_DELAY);
80 | //1000/portTICK_PERIOD_MS);
81 | if(!(uxBits & PIR_SENSOR_HIGH_BIT) && !(uxBits & PIR_SENSOR_LOW_BIT))
82 | {
83 | ESP_LOGI(TAG, "Triggered without sensor");
84 | }
85 | }
86 | }
87 |
88 | uint8_t getPirSensorLevel(void)
89 | {
90 | return pirSensorLevel;
91 | }
92 |
93 | void initPirSensorTask(void)
94 | {
95 | xTaskCreate(pirSensorTask, "pirSensorTask", 100000, (void*)1, tskIDLE_PRIORITY, NULL);
96 | }
