einen schönen guten morgen.
Ich habe ein Problem mit ESP-IDF.
Ich habe ein ESP32 (und auch schon code) und möchte dafür den code bauen
1 | ^spressif/esp-idf/components/tinyusb C:/Espressif/esp-idf/components/ulp C:/Espressif/esp-idf/components/unity C:/Espressif/esp-idf/components/usb C:/Espressif/esp-idf/components/vfs C:/Espressif/esp-idf/components/wear_levelling C:/Espressif/esp-idf/components/wifi_provisioning C:/Espressif/esp-idf/components/wpa_supplicant C:/Espressif/esp-idf/components/xtensa
2 | -- Configuring done
3 | CMake Error at C:/Espressif/esp-idf/tools/cmake/component.cmake:470 (add_library):
4 | Cannot find source file:
5 |
6 | C:/Espressif/esp-idf/components/coap/libcoap/src/coap_asn1.c
7 |
8 | Tried extensions .c .C .c++ .cc .cpp .cxx .cu .mpp .m .M .mm .h .hh .h++
9 | .hm .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .ispc
10 | Call Stack (most recent call first):
11 | C:/Espressif/esp-idf/components/coap/CMakeLists.txt:37 (idf_component_register)
12 |
13 |
14 | CMake Error at C:/Espressif/esp-idf/tools/cmake/component.cmake:470 (add_library):
15 | Cannot find source file:
16 |
17 | C:/Espressif/esp-idf/components/libsodium/libsodium/src/libsodium/crypto_box/curve25519xchacha20poly1305/box_seal_curve25519xchacha20poly1305.c
18 |
19 | Tried extensions .c .C .c++ .cc .cpp .cxx .cu .mpp .m .M .mm .h .hh .h++
20 | .hm .hpp .hxx .in .txx .f .F .for .f77 .f90 .f95 .f03 .ispc
21 | Call Stack (most recent call first):
22 | C:/Espressif/esp-idf/components/libsodium/CMakeLists.txt:126 (idf_component_register)
23 |
24 |
25 | CMake Error at C:/Espressif/esp-idf/tools/cmake/component.cmake:470 (add_library):
26 | No SOURCES given to target: __idf_coap
27 | Call Stack (most recent call first):
28 | C:/Espressif/esp-idf/components/coap/CMakeLists.txt:37 (idf_component_register)
29 |
30 |
31 | CMake Error at C:/Espressif/esp-idf/tools/cmake/component.cmake:470 (add_library):
32 | No SOURCES given to target: __idf_libsodium
33 | Call Stack (most recent call first):
34 | C:/Espressif/esp-idf/components/libsodium/CMakeLists.txt:126 (idf_component_register)
35 |
36 |
37 | CMake Generate step failed. Build files cannot be regenerated correctly.
38 | cmake failed with exit code 1
was ich gefunden habe, ist die submodule von esp-idf zu updaten
1 | git submodule update --init --recursive
das funktioniert jedoch nicht
1 | tests/ssl-opt.sh
2 | Please commit your changes or stash them before you switch branches.
3 | Aborting
4 | error: Your local changes to the following files would be overwritten by checkout:
5 | genheaderfunc.py
6 | genlibtokenlookup.py
7 | genmethodfunc.py
8 | gennghttpxfun.py
9 | help2rst.py
10 | mkhufftbl.py
11 | Please commit your changes or stash them before you switch branches.
12 | Aborting
13 | Submodule path 'components/tinyusb/tinyusb': checked out 'c4badd394eda18199c0196ed0be1e2d635f0a5f6'
14 | Submodule path 'examples/peripherals/secure_element/atecc608_ecdsa/components/esp-cryptoauthlib': checked out '36d0642e66ff5b1c7a291873f24c498ca6ffedef'
15 | Unable to checkout '3aa11612c143c9734d72022720f33e12506f7a2c' in submodule path 'components/coap/libcoap'
16 | Unable to checkout 'cd7d14917f2c3d0ea4382f4a188cb290304faf47' in submodule path 'components/esp_wifi/lib'
17 | Unable to checkout 'b082b0ed2d86b3330134c4854a021dfd14c29b08' in submodule path 'components/esptool_py/esptool'
18 | Unable to checkout 'a28238bdeebc087071777001245df1876a11f5ee' in submodule path 'components/expat/expat'
19 | Unable to checkout '4f5e89fa84ce1d178a6765b8b46f2b6f91216677' in submodule path 'components/libsodium/libsodium'
20 | Unable to checkout 'dc406b82b20481bde74a60fa8a776285d3fb9cf3' in submodule path 'components/mbedtls/mbedtls'
21 | Unable to checkout '8f7b008b158e12de0e58247afd170f127dbb6456' in submodule path 'components/nghttp/nghttp2'
wenn ich
mache bekomme ich die Ausgabe
1 | HEAD detached at v4.4
2 | Changes not staged for commit:
3 | (use "git add <file>..." to update what will be committed)
4 | (use "git restore <file>..." to discard changes in working directory)
5 | (commit or discard the untracked or modified content in submodules)
6 | modified: components/asio/asio (modified content)
7 | modified: components/bootloader/subproject/components/micro-ecc/micro-ecc (modified content)
8 | modified: components/bt/host/nimble/nimble (modified content)
9 | modified: components/cbor/tinycbor (modified content)
10 | modified: components/coap/libcoap (new commits, modified content)
11 | modified: components/esp_wifi/lib (new commits, modified content)
12 | modified: components/esptool_py/esptool (new commits, modified content)
13 | modified: components/expat/expat (new commits, modified content)
14 | modified: components/json/cJSON (modified content)
15 | modified: components/libsodium/libsodium (new commits, modified content)
16 | modified: components/lwip/lwip (modified content)
17 | modified: components/mbedtls/mbedtls (new commits, modified content)
18 | modified: components/mqtt/esp-mqtt (modified content)
19 | modified: components/nghttp/nghttp2 (new commits, modified content)
20 | modified: components/protobuf-c/protobuf-c (modified content)
21 | modified: components/unity/unity (modified content)
22 | modified: examples/build_system/cmake/import_lib/main/lib/tinyxml2 (modified content)
23 |
24 | Untracked files:
25 | (use "git add <file>..." to include in what will be committed)
26 | components/bt/controller/lib/
allerdings bekomme ich die Änderungen nicht weg
1 | git add -A
2 | git reset --hard
sieht der status immer noch gleich aus
