Wie ist die prinzipielle vorgehensweise bei 2 Bluetoothmodulen(hier HM-10), um diese miteinander zu verbingen. Eins stellt man als Master das andere als Slave und dann? Müssen beide den gleichen Namen haben? Mit welcher der hier gelisteten AT Befehle kann man geziehlt eine Verbindung aufabuen?! * AT Check if the command terminal work normally *<\r><\n> * AT+RESET Software reboot<9><9><9><9> *<\r><\n> * AT+VERSION Get firmware, bluetooth, HCI and LMP version *<\r><\n> * AT+HELP List all the commands<9><9> *<\r><\n> * AT+NAME Get/Set local device name *<\r><\n> * AT+PIN Get/Set pin code for pairing *<\r><\n> * AT+PASS Get/Set pin code for pairing *<\r><\n> * AT+BAUD Get/Set baud rate<9><9> *<\r><\n> * AT+LADDR Get local bluetooth address<9><9> *<\r><\n> * AT+ADDR Get local bluetooth address<9><9> *<\r><\n> * AT+DEFAULT Restore factory default<9><9><9> *<\r><\n> * AT+RENEW Restore factory default<9><9><9> *<\r><\n> * AT+STATE Get current state<9><9><9><9> *<\r><\n> * AT+PWRM Get/Set power on mode(low power) <9><9> *<\r><\n> * AT+POWE Get/Set RF transmit power <9><9> *<\r><\n> * AT+SLEEP Sleep mode <9><9> *<\r><\n> * AT+ROLE Get/Set current role.<9> *<\r><\n> * AT+PARI Get/Set UART parity bit. *<\r><\n> * AT+STOP Get/Set UART stop bit. *<\r><\n> * AT+START System start working.<9><9><9> *<\r><\n> * AT+IMME System wait for command when power on.<9> *<\r><\n> * AT+IBEA Switch iBeacon mode.<9> *<\r><\n> * AT+IBE0 Set iBeacon UUID 0. <9> *<\r><\n> * AT+IBE1 Set iBeacon UUID 1. <9> *<\r><\n> * AT+IBE2 Set iBeacon UUID 2. <9> *<\r><\n> * AT+IBE3 Set iBeacon UUID 3. <9> *<\r><\n> * AT+MARJ Set iBeacon MARJ . <9> *<\r><\n> * AT+MINO Set iBeacon MINO . <9> *<\r><\n> * AT+MEA Set iBeacon MEA . <9> *<\r><\n> * AT+NOTI Notify connection event . *<\r><\n> * AT+UUID Get/Set system SERVER_UUID . <9> *<\r><\n> * AT+CHAR Get/Set system CHAR_UUID . <9> *<\r><\n> * -----------------------------------------------------------------*<\r><\ n> * Note: (M) = The command support slave mode only. <9><9> *<\r><\n> * For more information, please visit http://www.cyobd.com *<\r><\n> * Copyright@2013 www.cyobd.com. All rights reserved.<9><9> *<\r><\n> ********************************************************************<\r>
...schon mal im Internet mit einer Suchmaschine deiner Wahl gesucht?
Was denkst du? Heute schon dumme Fragen gestellt? Kansnt du helfen doer nicht?! Sonst klemm dir solche Kommentare http://www.martyncurrey.com/hm-10-bluetooth-4ble-modules/ Hier z.B. To scan for other HM-10 modules use the Discover command AT+DISC? Nur gib es den Parameter nicht
Dangerous Rick schrieb: > http://www.martyncurrey.com/hm-10-bluetooth-4ble-modules/ Über den Link bin ich auf das Beispiel "HM-10 stand-alone: Remote control an LED using MODE2" gekommen. Dieses beschreibt eine Master/Slaveverbindung zweier Module sehr ausführlich.
...siehste Dangerous Rick...... Bleibt doch die Suchmaschine deiner Wahl. Oder willst Du mich nun auch verprügeln? ;-)
Ja, das hatte ich geshen und die befehle funktioneiren nicht bzw sind nicht gelistet. Offenbar ist es nicht ganz kompatibel zum AT-09 Das ist das was ich habe Es ist wohl egientlich ein AT-09 https://www.ebay.de/itm/264058008961?_trkparms=amclksrc%3DITM%26aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20170511121231%26meid%3D98f1a06b4b3c4dce99b0e95a7f01385b%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D264058008961%26itm%3D264058008961%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DMarkenlos&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A960ebb8d-e00c-11ec-818b-d6a8e4c131d2%7Cparentrq%3A14bfc1da1810aa7027eb396dfff80ccc%7Ciid%3A15
ich hätte noch den Link zu bieten: https://robin.meis.space/2015/07/08/hm-10-bluetooth-4-0-module-verbinden/ AT+DISC? --> vielleicht gibt es den Befehl nur im Master-Mode, schon mal probiert? Dangerous Rick schrieb: > Heute schon dumme Fragen gestellt? ...ich nicht... Dangerous Rick schrieb: > Kansnt du helfen doer nicht?! ...naja, ich habe es versucht, "sorry"... Dangerous Rick schrieb: > Sonst klemm dir solche Kommentare ...den kommentiere ich jetzt nicht mehr!
da steht dann auch: Please set AT+ROLE1 and AT+IMME1 first. Du Krawallbürste "Was denkst du? Heute schon dumme Fragen gestellt? Kansnt du helfen doer nicht?! Sonst klemm dir solche Kommentare"
Die möglcihen At Befehle sind ganz oben aufgelistet...
Dangerous Rick schrieb: > Roel und Imme 1 gehen auch Glaub ich dir nicht. AT+ROLE1 und AT+IMME1 funktionieren
ah moment, evtl ist das aber dennoch mein fehler:-) Ich hatte die Command list noch im Slave mode gepostet. Ich versuche es mal weiter:-) Danke erstmal
Die HM-10 werden oft mit uralt Firmware geliefert weil nachbauten/fake. Versuche die aktuelle Firmware aufzuspielen dann wird das auch was. https://www.youtube.com/watch?v=ez3491-v8Og
Ich kenne die Module nicht, aber prinzipiell ist die Vorgehensweise immer so: - Eins der beiden Module muss sich sichtbar machen. - Das andere Scannt verfügbare Geräte und listet dabei Namen (falls vorhanden) und Adressen auf. - Dann paart man es mit der dem gewünschten Partner, wobei man die Adresse und meisten auch ein Passwort angeben muss. - Danach können sich die beiden Module mit einander verbinden. Wer die Verbindung initiieren muss, hängt von der Firmware ab. Bei den Lautsprechern in meinem Wohnzimmer kann sowohl der Fernseher als auch der Lautsprecher den Verbindungsaufbau zur Gegenseite initiieren. Das Paaren kann ich hingegen nur auf dem Fernseher machen.
