ich moechte meinen ESP32 und ESP8266 ueber eine Datei im Filesystem
updaten, dazu habe ich folgende Funktion geschrieben
1 | void performUpdate(Stream &updateSource, size_t updateSize) {
2 | if (Update.begin(updateSize)) {
3 | size_t written = Update.writeStream(updateSource);
4 | if (written == updateSize) {
5 | Serial.println("Written : " + String(written) + " successfully");
6 | }
7 | else {
8 | Serial.println("Written only : " + String(written) + "/" + String(updateSize) + ". Retry?");
9 | }
10 | if (Update.end()) {
11 | Serial.println(F("OTA done!"));
12 | if (Update.isFinished()) {
13 | Serial.println(F("Update successfully completed. Rebooting."));
14 | }
15 | else {
16 | Serial.println(F("Update not finished? Something went wrong!"));
17 | }
18 | }
19 | else {
20 | Serial.println("Error Occurred. Error #: " + String(Update.getError()));
21 | }
22 |
23 | }
24 | else
25 | {
26 | Serial.println(F("Not enough space to begin OTA"));
27 | }
28 | }
29 |
30 | void updateFromFS() {
31 | File updateBin = LittleFS.open("/update.bin","r");
32 | if (updateBin) {
33 | if(updateBin.isDirectory()){
34 | Serial.println("Error, update.bin is not a file");
35 | updateBin.close();
36 | return;
37 | }
38 |
39 | size_t updateSize = updateBin.size();
40 |
41 | if (updateSize > 0) {
42 | Serial.println("Try to start update");
43 | performUpdate(updateBin, updateSize);
44 | }
45 | else {
46 | Serial.println("Error, file is empty");
47 | }
48 |
49 | updateBin.close();
50 |
51 | // whe finished remove the binary from sd card to indicate end of the process
52 | LittleFS.remove("/update.bin");
53 | }
54 | else {
55 | Serial.println("Could not load update.bin from sd root");
56 | }
57 | }
Allerdings stuerzt dabei mein ESP32 und auch der ESP8266 ab - macht
einen reboot.
Was mache ich falsch bei der VErwendung?
