HI : I am going to use DS89C420 ! when I use the Software "loader420.exe" to load "hex" file to DS89C420! but the err always is : ************************************************************************ No response on reset from the 420 Make sure the serial cable is connected, that you are using the right port, and have the correct voltage applied. Loading file E:\HDQ\d.hex 131 % loaded. (1 retries) 197 % loaded. (2 retries) 263 % loaded. (3 retries) 328 % loaded. (4 retries) Timed out, trying to get loader prompt and continue File loading failed. > ************************************************************ I can make sure the serial cable is connected,and the right serial port ! I don't know why ! If some have some advise .please send me a email ! what case can make these problem ? my email : ymq8328@hotmail.com thank you !
Hi there I was also having problems using the loader420.exe to load hex files to a DS89C420 and found your email on the internet. Were you able to resolve the problem? If so, please let me know what you did. Thank you Ian McLeod Ontario, Canada.
Komisch; kriegen die Leute nicht mit, dass das hier ein deutschsprachiges Forum ist? :-? Sowas wundert mich einfach....
man könnte ein englisch-sprachiges Unterforum auf machen...
Hi, I use the DS89C420/ 440/ 450, too. You have to erase the Microcontoller fist!! If you don't do this, the micro can be distroid. Cause the HEX-code can be writen in wrong adresses. In the first time I had this problems too. Regards Benjamin
