Hallo Gibt es eine Software, um die Parameter ( Seriennummer, IDE-Modi) einer Compact Flash auszulesen oder sogar zu ändern ? Ich habe nach langem Googlen gefunden, dass für Palm-Computer ein Programm namens Card Info existiert. Gibt es sowas auch für PC mit Windows oder Linux? 73 Christoph
Das hier? http://www.tssc.de/index.htm -> Tools CISInfo Version 6.06.001 from 21-Sep-05 An application that interprets Card Information Structure (CIS) from PC Cards. License: 29.99 EUR Upgrade: 17.99 EUR It was designed to simplify development, debugging and support of PC Card products. Kann das auch ein Compact-Flash in einem PC-Card-Adapter auslesen?
Oder das ? http://pcmcia-cs.sourceforge.net/ftp/doc/PCMCIA-PROG-3.html int CardServices(ValidateCIS, client_handle_t client, cisinfo_t *cisinfo); ValidateCIS attempts to verify that a card has a reasonable Card Information Structure. It returns the number of tuples found in Chains.
Hab hier noch einen Tip gefunden: http://www.robgalbraith.com/bins/multi_page.asp?cid=6007 "... Look at the Internal Name... You may also see this information for both CompactFlash and SD in the file setupapi.log in the WINDOWS directory on the C: drive of a typical Windows XP installation ... Here's an example setupapi.log entry for a CompactFlash card that uses Toshiba components: #I124 Doing copy-only install of "USBSTOR\DISK&VEN_TOSHIBA&PROD_THNCF1G02CA&REV_3.00\1B03010305F416A9&0". You might also have a look in the Hardware tab of the Properties window for a given card/reader combo
