1 | #include <mega8.h>
2 | #include <LCDlib2x16.h>
3 | #include <stdio.h>
4 |
5 | //Definiton der Ein- bzw. Ausgaenge
6 | #define Links !PINC.0 //Active High Taster --> Links
7 | #define Rechts !PINC.1 //Active High Taster --> Rechts
8 | #define Enter !PINC.2 //Active High Taster --> Enter
9 | #define Back !PINC.3 //Active High Taster --> Back
10 |
11 | #define LCD_SIZE 16 //Zeichen pro Zeile im Display
12 |
13 |
14 | // Welcome string to display on a 16 char-LCD:
15 | const char Fstmsg[16]=//
16 | {'M','e','s','s','u','n','g','>','s','t','a','r','t',' ','K','2'};
17 |
18 |
19 | // Declare your global variables here:
20 | unsigned char n; // global count variable
21 | long zeit=0;
22 | long zeitarray[20];
23 | long aktuellezeit;
24 | void time_convert(unsigned long hundertstel, unsigned char zeile);
25 | void messfunktion(void);
26 | void LCD_puts(char *pStr1, char *pStr2, unsigned char);
27 | void initSFR(void);
28 | int run=0; //countvariable
29 | bit runLCD=0;
30 | bit erster=0; //sobald der erste Laeufer im Ziel ist wird diese
31 | //Variable 1 gesetzt...
32 | int laeuferNR=1;
33 | bit Messung_ready;
34 | bit Messung_running;
35 |
36 | // Timer 0 overflow interrupt service routine
37 | interrupt [TIM0_OVF] void timer0_ovf_isr(void)
38 | {
39 | if(!Messung_running){
40 | zeit++;
41 | TCNT0=0x06;}
42 | else
43 | {;}
44 | }
45 |
46 | // External Interrupt 0 service routine
47 | interrupt [EXT_INT0] void ext_int0_isr(void)
48 | {
49 | // Place your code here
50 | TCCR0=0x03;
51 | Messung_running=1;
52 | }
53 |
54 | // External Interrupt 1 service routine
55 | interrupt [EXT_INT1] void ext_int1_isr(void)
56 | {
57 | // Place your code here
58 | TCCR0=0x03;
59 | messfunktion();
60 | }
61 |
62 | void main(void)
63 | {
64 | bit x=0;
65 | initSFR();
66 | // Global enable interrupts
67 | #asm("sei")
68 |
69 | InitLCD(); // initialize LCD; auto increment cursorposition
70 | delay(10); // wait 250 ms before first write
71 | // write to LCD (cursor is at 1. pos. after initialization)
72 |
73 | SetCursLCD(1);
74 | for(n=0;n<16;n++) // write first 8 chars of welcome message
75 | {WrCharLCD(Fstmsg[n]);}
76 |
77 | SetCursLCD(17);
78 | for(n=0;n<16;n++) // write first 8 chars of welcome message
79 | {WrCharLCD(Fstmsg[n]);}
80 |
81 | while (1) // do forever
82 | {
83 | if(Enter)
84 | { Messung_ready=1;
85 | GICR|=0x40;
86 | MCUCR=0x01;
87 | GIFR=0x40; }
88 | else if(Back)
89 | { Messung_ready=0;}
90 | else
91 | {
92 | while(Messung_running && Messung_ready)
93 | {if(x=0)
94 | { GICR|=0x80;
95 | MCUCR=0x04;
96 | GIFR=0x80;}
97 | else
98 | {time_convert((zeitarray[1]+zeit),1);
99 | time_convert(zeitarray[laeuferNR]+zeitarray[0],2);
100 | delay(10);}
101 | } }
102 | }// End of while
103 |
104 | } //End of main
105 |
106 | void time_convert(unsigned long hundertstel, unsigned char zeile)
107 | {
108 | unsigned long int stunden, minuten, sekunden,
109 | minutenR, sekundenR, hundertstelR;
110 | unsigned char time[16],x;
111 |
112 | SetCursLCD(1);
113 | hundertstel = hundertstel / 10;
114 | hundertstelR = hundertstel % 100; //hundertstel
115 | sekunden = hundertstel / 100; //ganze sekunden
116 | sekundenR = sekunden % 60; //sekunden
117 | minuten = sekunden / 60; //ganze minuten
118 | minutenR = minuten % 60; //minuten
119 | stunden = minuten / 60; //ganze Stunden
120 |
121 | sprintf(time, "%i. %02d:%02d:%02d,%02d ",
122 |
123 | laeuferNR,stunden,minutenR,sekundenR,hundertstelR);
124 |
125 | if(zeile==0){
126 | LCD_puts(time,time,0);}
127 |
128 | if(zeile==1){
129 | LCD_puts(time,time,1);}
130 |
131 | if(zeile==2){
132 | LCD_puts(time,time,2);}
133 |
134 | } //time_convert
135 |
136 | void messfunktion(void)
137 | {
138 | if(!erster) {
139 | zeitarray[1]=zeit;
140 | zeit=0;
141 | erster=1; }
142 | else {
143 | laeuferNR++;
144 | zeitarray[laeuferNR]=zeit; }
145 | }
146 |
147 | void initSFR(void)
148 | {
149 | // Declare your local variables here
150 |
151 | //Allgemeine Definitionen des Mikrocontrollers
152 | // Port B initialization
153 | PORTB=0x00;
154 | DDRB=0x3F;
155 | // Port C initialization
156 | PORTC=0x7F;
157 | DDRC=0x00;
158 | // Port D initialization
159 | PORTD=0xFF;
160 | DDRD=0x00;
161 | // Analog Comparator initialization
162 | ACSR=0x80;
163 | SFIOR=0x00;
164 | // External Interrupt(s) initialization
165 | // INT0: On
166 | // INT0 Mode: Any change
167 | // INT1: On
168 | // INT1 Mode: Any change
169 | GICR|=0x00;
170 | MCUCR=0x00;
171 | GIFR=0x00;
172 | // Timer/Counter 0 initialization
173 | // Clock source: System Clock
174 | // Clock value: 16000,000 kHz
175 | TCCR0=0x03; //Prescaler 64 --> 0x01 = Standartwert
176 | TCNT0=0x06; //Vorladen mit 6
177 | // Timer(s)/Counter(s) Interrupt(s) initialization
178 | TIMSK=0x01;
179 | }
180 | /**Funktion um einzelne Zeichen eines Arrays auszugeben **/
181 | void LCD_puts(char *pStr1, char *pStr2, unsigned char zeile)
182 | {
183 | unsigned char count=0;
184 |
185 | if((zeile==1)||(zeile==0))
186 | {
187 | SetCursLCD(1);
188 | while (*pStr1)
189 | { WrCharLCD(*pStr1++);
190 | count++;}
191 | while (count++ < LCD_SIZE)
192 | { WrCharLCD(' '); }
193 | delay(2);
194 | count = 0;
195 | }
196 | else
197 | if((zeile==2)||(zeile==0))
198 | {
199 | SetCursLCD(17);
200 | while (*pStr2)
201 | { WrCharLCD(*pStr2++);
202 | count++; }
203 | while (count++ < LCD_SIZE)
204 | { WrCharLCD(' ');}
205 | }
206 | }
