Ich habe einen Atmega88 mit externen Quarz im Einsatz und benötige einen Interrupt jede Sekunde vom Timer2: Ich finde den Fehler nicht: void timer2 (void) { cli(); // disable global interrupts TIMSK2 = 0x00; //1. Disable the Timer/Counter2 interrupts clear ASSR = (1<<AS2); //2. Select clock source by setting AS2 as appropriate. TCNT2 = 0x00; //3. Timer2 = 0 TCCR2B |= (1<<CS22) | (1<<CS20); // select prescaler: 32.768 kHz/128=1 //sec between each overflow // 4. To switch to asynchronous operation: Wait for TCN2UB, OCR2UB, and // TCR2UB. while( (ASSR & (1<<TCN2UB)) | (ASSR & (1<<OCR2AUB)) | (ASSR & (1<<TCR2BUB)) ); // 5. Clear the Timer/Counter2 Interrupt Flags. TIFR2 |= ((1<<OCF2A)|(1<<TOV2)); // 6. enable Timer2 Overflow interrupt TIMSK2 |= (1<<TOIE2); sei(); }
