hallo, ich habe ein problem mit openocd :-( also mein makefile hat eine main.bin erstellt. #daemon configuration telnet_port 4444 gdb_port 3333 #interface interface parport parport_port 0x378 parport_cable wiggler jtag_speed 0 #use combined on interfaces or targets that can't set TRST/SRST separately reset_config trst_and_srst srst_pulls_trst #jtag scan chain #format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE) jtag_device 4 0x1 0xf 0xe jtag_nsrst_delay 333 jtag_ntrst_delay 333 #target <type> <startup mode> #target arm7tdmi <reset mode> <chainpos> <endianness> <variant> target arm7tdmi little run_and_init 0 arm7tdmi-s_r4 run_and_halt_time 0 30 #target configuration daemon_startup reset # flash-options LPC2148 target_script 0 reset openocd_lpc2148_flash.script working_area 0 0x40000000 0x4000 nobackup #working_area 0 0x40000000 0x40000 nobackup # LPC2148 @ 12MHz / 0x7D000 from 500*1024 (not 512!) #flash bank lpc2000 0x0 0x7D000 0 0 lpc2000_v2 0 12000 calc_checksum #flash bank lpc2000 0x0 0x7d000 0 0 lpc2000_v2 0 14765 calc_checksum flash bank lpc2000 0x0 0x7D000 0 0 lpc2000_v2 0 12000 calc_checksum # For more information about the configuration files, take a look at: # http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger und mein openocd_lpc2148_flash.script # # The following command wills be executed on # reset (because of run_and_init in the config-file) # - wait for target halt # - erase memory # - flash content of file main.bin into target-memory # - shutdown openocd # # created by Martin Thomas # http://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects # based on information from Dominic Rath # arm7_9 dcc_downloads enable wait_halt sleep 10 poll flash probe 0 flash erase 0 0 0 flash write 0 main.bin 0x0 reset run sleep 10 shutdown ich benutze als compiler winarm. wenn ihr noch mehr infos braucht, dann sagt bitte bescheid. mfg world
