Hi, I use ADC12 of msp430f1611.but I have some problem with the ADC12 precision. The analog input is 0(no signal), but the ADC conversion value sometimes change of about 0 to 256 points(256/4095). But the input hat signal, the ADC conversion value is good and stabil. How can I do? Thank you Here is the code: void main(void) { WDTCTL = WDTPW+WDTHOLD; // Stop watchdog timer P6SEL = 0X3C; // Enable A/D channel inputs ADC12CTL0 = ADC12ON+MSC+SHT0_8; // Turn on ADC12, extend sampling time // to avoid overflow of results ADC12CTL1 = SHP+CONSEQ_3; // Use sampling timer, repeated sequence ADC12MCTL0 = SREF_2+INCH_2; // ref+=VeREF, channel = A0 ADC12MCTL1 = SREF_2+INCH_3; // ref+=VeREF, channel = A1 ADC12MCTL2 = SREF_2+INCH_4; // ref+=VeREF, channel = A2 ADC12MCTL3 = SREF_2+INCH_5+EOS; // ref+=VeREF, channel = A3, end seq. ADC12IE =0X08; // Enable ADC12IFG.3 ADC12CTL0 |= ENC; // Enable conversions ADC12CTL0 |= ADC12SC; // Start conversion _BIS_SR(LPM0_bits +GIE); // Enable interrupts } #pragma vector=ADC_VECTOR __interrupt void ADC (void) { static unsigned int index = 0; A0results[index] = ADC12MEM0; // Move A0 results, IFG is cleared A1results[index] = ADC12MEM1; // Move A1 results, IFG is cleared A2results[index] = ADC12MEM2; // Move A2 results, IFG is cleared A3results[index] = ADC12MEM3; // Move A3 results, IFG is cleared index = (index+1)%8; // Increment results index, modulo; }
ok ,schreibe ich auf Deutsch. Stefan Shröder wrote: > Hallo, > Ich benutze ADC12 von msp430f1611.aber Ich habe ein problem über ADC12 > . > der analog Eingang ist 0(Kein signal), aber ADC conversion value manchmal > change von 0 bis 256 Punkte(256/4095). Aber das Eingangsignal habe Signal, Die > ADC conversion value ist stabil. > Ist mit der Schaltung zu tu oder mit der Programierung zu tu? > > > Danke schön!
Is the ADC-Input really zero? Or left open? Or with resistor tied to ground? If so, what is the value of this resistor?
Ich hatte ein ähnliches Problem. Ursache war ein zu kleiner Kondensator an Vef. siehe auch Beitrag "Re: MSP430 Erfahrungsaustausch zu ADC12 gesucht"
