Hi folk, I have a small problem: When I am creating a Managed Make C-Project, I can add easily a library in the GCC C-Linker Options (Project Properties -> C/C++ Build -> GCC C Linker/ Libraries -> "pthread" and "upnp"). Further, i have a extra directory with all 'include files' in the Project-View (Binaires, Includes, Debug, SourceFiles,...). This is not the problem, but when I am creating a "Managed Make AVR32 C Project" for the AP7000/ STK1000, its impossible to add the libraries (Project Properties -> C/C++ Build --> AVR32/GNU Linux C Linker). I have absolute no idea, why it doesnt work and I am doing the same. The libraries are saved as well in the /usr/lib/ as in /usr/local/lib/ directories. Thanks in advance for any help. Cheers, Pete PS: I am using Fedora Core 6 and AVR Version 0.9 and 1.0. It doesnt matter for wich Version I will get a solution. PSPS: Antworten werden auch auf Deutsch akzeptiert ;-)
Hi Pete, the problem is probably that you want to add precompiled 'shared' libraries to your project which have not been compiled for the target architecture (i.e. AVR32) but for your host (e.g. x86). Get the library sources, compile them for AVR32 and then try to include them. Cheers, Florian
i'm not sure if i understand what you want. you can load other libraries over the framework tap.
