1 | /**************************************************************
2 | * *
3 | * UART.c *
4 | * *
5 | ***************************************************************/
6 |
7 | /* Include-Dateien
8 | -----------------*/
9 |
10 |
11 | #include <avr/io.h>
12 | #include <avr/interrupt.h>
13 |
14 | /* UCR - UART Control Register: Bit Definitionen
15 | -----------------------------------------------------------*/
16 | #define RXCIE 0x80 // Bit 7
17 | #define TXCIE 0x40 // Bit 6
18 | #define UDRIE 0x20 // Bit 5
19 | #define RXEN 0x10 // Bit 4
20 | #define TXEN 0x08 // Bit 3
21 | #define CHR9 0x04 // Bit 2
22 | #define RXB8 0x02 // Bit 1
23 | #define TXB8 0x01 // Bit 0
24 |
25 | /* USR - UART Status Register: Bit Definitionen
26 | ---------------------------------------------------------*/
27 | #define RXC 0x80 // Bit 7
28 | #define TXC 0x40 // Bit 6
29 | #define UDRE 0x20 // Bit 5
30 | #define FE 0x10 // Bit 4
31 | #define OVR 0x08 // Bit 3
32 |
33 | /* UBRR - UART Baudrate Register: Baud Definitionen fuer 4MHz
34 | ---------------------------------------------------------*/
35 | #define BAUD_1200 208
36 | #define BAUD_2400 103
37 | #define BAUD_9600 25
38 | #define BAUD_19200 12
39 |
40 | /* UART Daten-Puffer Definitionen
41 | ------------------------------*/
42 | #define BUFFER_SIZE 8 // Modulo 2 Groesse: nur 2,4,8,16,32 Bytes
43 | #define BUFFER_MASK (BUFFER_SIZE-1)
44 |
45 | /* Allgemeine typ-Definitionen
46 | -----------------------------------------------------------*/
47 | typedef enum{ FALSE=0, TRUE=1} Boolean_t ;
48 |
49 | typedef struct{ unsigned char UartData[ BUFFER_SIZE ];
50 | unsigned char NumberOfBytes;
51 | unsigned char UartStatus; } Uart_t;
52 |
53 | /* Static Variables
54 | -------------------*/
55 | static unsigned char RxBuf[ BUFFER_SIZE ];
56 | static volatile unsigned char RxProducer; // Empfang: Int-Service ist der Producer
57 | static volatile unsigned char RxConsumer; // Empfang: Hauptprogramm ist Consumer
58 | static unsigned char TxBuf[ BUFFER_SIZE ];
59 | static volatile unsigned char TxProducer; // Senden: Hauptprogramm ist der Producer
60 | static volatile unsigned char TxConsumer; // Senden: Int-Service ist Consumer
61 |
62 | /* Funktion-Prototypen
63 | ----------------------------*/
64 | void InitUart( unsigned char baudrate );
65 | Boolean_t ReceiveData( Uart_t * Data );
66 | Boolean_t TransmitData( Uart_t * Data );
67 | void Delay( void );
68 |
69 | /* Input Pins, Port B: sfrb PINB = 0x16;
70 | Data Direction Register, Port B: sfrb DDRB = 0x17;
71 | Data Register, Port B: sfrb PORTB = 0x18; */
72 | void Delay( void ) // warte zeit
73 | {
74 | unsigned int i= 0x7FFF;
75 | while(--i);
76 | }
77 |
78 |
79 | /* Main - ein einfaches Anwendungsbeispiel fuer UART und Timer
80 | -------------------------------------------------------------*/
81 | void C_task main( void )
82 | {
83 | Uart_t UartData;
84 |
85 | DDRB = 0xFF ; // Konfiguriert Port B als Ausgang
86 | PORTB = 0xAA;
87 |
88 | InitUart( BAUD_9600 ); // Baudrate = 9600 Baud bei 4MHz Quarz
89 | _SEI(); // Freigabe aller Interrupts => Enable UART Interrupts
90 |
91 | for( ;; ) // Endlos-Schleife
92 | {
93 | if( ReceiveData( & UartData ) )
94 | {
95 | TransmitData( & UartData ); // Echo der empfangenen Bytes
96 | }
97 |
98 | PORTB++; // Nur zum Testen Led schalten
99 | Delay(); // damit das Programm nicht nur die UART Daten abfragt
100 | }
101 | }
102 |
103 | /* Initialisierung der UART
104 | ------------------------------*/
105 | void InitUart( unsigned char baudrate )
106 | {
107 | UBRR = baudrate; // Baudrate setzen
108 |
109 | // Freigabe der UART Interrupts
110 | UCR = TXEN | RXEN | RXCIE; // ==> Senden/Empfangen/Empf.INT
111 |
112 | RxConsumer = 0; // Ruecksetzen der Puffer-Index
113 | RxProducer = 0;
114 | TxConsumer = 0;
115 | TxProducer = 0;
116 | }
117 |
118 | /* Empfangs-Interrupt Handler
119 | --------------------------- */
120 | interrupt [UART_RX_vect] void UartRxIntHandler( void )
121 | {
122 | unsigned char data;
123 |
124 | data = UDR; // Lesen der Empfangsdaten
125 | RxBuf[RxProducer] = data; // Empfangenes Byte in Puffer ablegen
126 | RxProducer++; // Bufferindex setzen
127 | RxProducer &=BUFFER_MASK; // Index begrenzen und evtl. auf Puffer-Anfang
128 |
129 | if (RxProducer == RxConsumer )
130 | {
131 | // Fehler! Ueberlauf Empfangspuffer
132 | }
133 | if( data =='\r') Wenn return Taste gedruckt
134 | {
135 | RxProducer == RxConsumer ; // Überlauf simulieren
136 | // UCR=~RXCIE; //oder der interrupt disable
137 | }
138 |
139 | }
140 |
141 | /* Sende-Interrupt Handler
142 | --------------------------- */
143 | interrupt [UART_UDRE_vect] void UART_TX_interrupt( void )
144 | {
145 | // Test ob noch nicht fertig mit Senden
146 | if ( TxConsumer != TxProducer ) // Nein, weiter machen mit senden
147 | {
148 | ++TxConsumer; // Pufferindex aktualisieren
149 | TxConsumer &=BUFFER_MASK; // Index begrenzen und evtl. auf Puffer-Anfang
150 | UDR = TxBuf[TxConsumer]; // Uebergabe eines Bytes
151 | }
152 | else // fertig ,senden beenden
153 | {
154 | UCR &= ~UDRIE; // Disable UDRE interrupt
155 | }
156 | }
157 |
158 |
159 | /* UART Empfangsfunktion
160 | --------------------- */
161 | Boolean_t ReceiveData( Uart_t * Data )
162 | {
163 | unsigned char i=0;
164 |
165 | // Schleife zur Uebergabe der empfangenen Daten
166 | while (( RxConsumer != RxProducer ) && ( i < BUFFER_SIZE ) )
167 | {
168 | Data->UartData[i++] = RxBuf[RxConsumer++];
169 |
170 | RxConsumer &=BUFFER_MASK; // Consumer-Index begrenzen und evtl. auf Puffer-Anfang
171 | }
172 |
173 | Data->NumberOfBytes = i ;
174 |
175 | if( i ) return TRUE ;
176 | else return FALSE ;
177 | }
178 |
179 | /* Sendefunktion
180 | --------------------- */
181 | Boolean_t TransmitData( Uart_t * Data )
182 | {
183 | unsigned char i=0;
184 |
185 | while (( i < Data->NumberOfBytes ) && ( i < BUFFER_SIZE ) )// Uebergabe Sendendaten
186 | {
187 | TxBuf[TxProducer++] = Data->UartData[i++] ;
188 |
189 | TxProducer &=BUFFER_MASK; // Producer-Index begrenzen und evtl. auf Puffer-Anfang
190 | }
191 |
192 | UDR = TxBuf[TxConsumer]; // Senden Anstossen
193 | ++TxConsumer;
194 | TxConsumer &=BUFFER_MASK; // Consumer-Index begrenzen
195 |
196 | UCR |= UDRIE ;
197 | Data->NumberOfBytes = 0;
198 | return TRUE ;
199 | }
