Mit Hilfe eines structs zerlege ich den Header einer Datei in die einzelnen Werte. Leider richtet der Compiler die long Werte auf 4Byte Grenzen aus. Gibt es bei MVC++ 6.0 irgendwas, um dem Compiler mitzuteilen, dass er dieses Struct möglichst unverändert lassen soll ? Dass man das global einstellen kann, ist mir bekannt, ich möchte aber nur dieses eine struct packen. Beim gcc Compiler geht das mit _attribut_ ((packed)) Aber dies scheint eben nicht Standard zu sein.
#pragma pack heißt es bei MSVC. #pragma pack( [ n] ) Specifies packing alignment for structure and union members. Whereas the packing alignment of structures and unions is set for an entire translation unit by the /Zp option, the packing alignment is set at the data-declaration level by the pack pragma. The pragma takes effect at the first structure or union declaration after the pragma is seen; the pragma has no effect on definitions. When you use #pragma pack(n), where n is 1, 2, 4, 8, or 16, each structure member after the first is stored on the smaller member type or n-byte boundaries. If you use #pragma pack without an argument, structure members are packed to the value specified by /Zp. The default /Zp packing size is /Zp8. The compiler also supports the following enhanced syntax: #pragma pack( [ [ { push | pop}, ] [ identifier, ] ] [ n ] ) This syntax allows you to combine program components into a single translation unit if the different components use pack pragmas to specify different packing alignments. Each occurrence of a pack pragma with a push argument stores the current packing alignment on an internal compiler stack. The pragma’s argument list is read from left to right. If you use push, the current packing value is stored. If you provide a value for n, that value becomes the new packing value. If you specify an identifier, a name of your choosing, the identifier is associated with the new packing value. Each occurrence of a pack pragma with a pop argument retrieves the value at the top of an internal compiler stack and makes that value the new packing alignment. If you use pop and the internal compiler stack is empty, the alignment value is that set from the command-line and a warning is issued. If you use pop and specify a value for n, that value becomes the new packing value. If you use pop and specify an identifier, all values stored on the stack are removed from the stack until a matching identifier is found. The packing value associated with the identifier is also removed from the stack and the packing value that existed just before the identifier was pushed becomes the new packing value. If no matching identifier is found, the packing value set from the command line is used and a level-one warning is issued. The default packing alignment is 8. The new, enhanced functionality of the pack pragma allows you to write header files that ensure that packing values are the same before and after the header file is encountered:
1 | /* File name: include1.h */
2 | #pragma pack( push, enter_include1 )
3 | /* Your include-file code ... */
4 | #pragma pack( pop, enter_include1 )
5 | /* End of include1.h */
In the previous example, the current pack value is associated with the identifier enter_include1 and pushed, remembered, on entry to the header file. The pack pragma at the end of the header file removes all intervening pack values that may have occurred in the header file and removes the pack value associated with enter_include1. The header file thus ensures that the pack value is the same before and after the header file. The new functionality also allows you to use code, such as header files, that uses pack pragmas to set packing alignments that differ from the packing value set in your code:
1 | #pragma pack( push, before_include1 )
2 | #include "include1.h" |
3 | #pragma pack( pop, before_include1 )
In the previous example, your code is protected from any changes to the packing value that might occur in include.h.
Du kannst alternativ das Alignment in Structs auch in den ganz normalen Kompilierungs-Einstellungen ändern. (Eigenschaften von Projekt->Settings oder sowas)
Das gilt dann aber für das gesamte Programm, was zu interessanten Nebenwirkungen führen kann, wenn mit Betriebssystem- oder anderen Libraries gearbeitet wird. Bei Betriebssystemheaderdateien sollte man zwar ernsthaft annehmen, daß die durch entsprechende Verwendung von #pragma pack vor solchem Unfug geschützt sind, aber andere Headerdateien müssen nicht so sauber programmiert sein ...
Rufus t. Firefly wrote: > Das gilt dann aber für das gesamte Programm, was zu interessanten > Nebenwirkungen führen kann, wenn mit Betriebssystem- oder anderen > Libraries gearbeitet wird. > Bei Betriebssystemheaderdateien sollte man zwar ernsthaft annehmen, daß > die durch entsprechende Verwendung von #pragma pack vor solchem Unfug > geschützt sind, aber andere Headerdateien müssen nicht so sauber > programmiert sein ... Jup, das stimmt natürlich. Hast du ja auch nen langen Beitrag oben drüber geschrieben :-)
> s/geschrieben/zitiert/
Dann mal :wq
ums mal in VI-Syntax zu sagen ;)
