hi leute. kenn mich irgenwie nicht so recht aus mit der erstellung von hex-files. wollte einfach mal zum ausprobieren dieses c-programm mit mfile von winavr in ein makefile und dann mit programmers-notepad in ein hex-file umwandeln.könnt ihr mir bitte genau erklären wie ich dabei vorgehe? kann es sein dass winavr die includes gar nicht kennt? was muss ich dann machen?hier der quelltext: #include <iostream> #include <stdlib.h> #include <time.h> using namespace std; void Start (); void GetResults (); int i, j, life, maxrand; char c; void Start () { i = 0; j = 0; life = 0; maxrand = 6; cout << "Select difficulty mode:\n"; // the user has to select a difficutly level cout << "1 : Easy (0-15)\n"; cout << "2 : Medium (0-30)\n"; cout << "3 : Difficult (0-50)\n"; cout << "or type another key to quit\n"; c = 30; cin >> c; // read the user's choice cout << "\n"; switch (c) { case '1' : maxrand = 15; // the random number will be between 0 and maxrand break; case '2' : maxrand = 30; break; case '3' : maxrand = 50; break; default : exit(0); break; } life = 5; // number of lifes of the player srand( (unsigned)time( NULL ) ); // init Rand() function j = rand() % maxrand; // j get a random value between 0 and maxrand GetResults(); } void GetResults () { if (life <= 0) // if player has no more life then he lose { cout << "You lose !\n\n"; Start(); } cout << "Type a number: \n"; cin >> i; // read user's number if ((i>maxrand) || (i<0)) // if the user number isn't correct, restart { cout << "Error : Number not between 0 and \n" << maxrand; GetResults(); } if (i == j) { cout << "YOU WIN !\n\n"; // the user found the secret number Start(); } else if (i>j) { cout << "Too BIG\n"; life = life - 1; // -1 to the user's "life" cout << "Number of remaining life: " << life << "\n\n"; GetResults(); } else if (i<j) { cout << "Too SMALL\n"; life = life - 1; cout << "Number of remaining life:\n" << life << "\n\n"; GetResults(); } } int main () { cout << "** Jackpot game **\n"; cout << "The goal of this game is to guess a number. You will be ask to type\n"; cout << "a number (you have 5 guess)\n"; cout << "Jackpot will then tell you if this number is too big of too small compared to the secret number to find\n\n"; Start(); return 0; }
> #include <iostream>
Da fehlt schonmal das ".h". Abgesehen davon ist iostream.h eine
C++-Bibliothek und keine C-Bibliothek...
jetzt hab ichs geändert und dann bringt er mir trozdem den fehler: > "make.exe" all -------- begin -------- avr-gcc (GCC) 4.1.2 (WinAVR 20070525) Copyright (C) 2006 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. make.exe: *** No rule to make target `main.elf', needed by `elf'. Stop. > Process Exit Code: 2 > Time Taken: 00:01
Da liegt wahrscheinlich das Problem: Marcel versucht wahrscheinlich ein C++ Programm mit dem GCC zu kompilieren.... dafür ist aber G++ zuständig. C++ hat auf dem AVR einige Einschränkungen und ist i.d.R. zu "schwergewichtig". Du (Marcel) solltest also nur C für AVRs einsetzen. Zudem dürfte dein Programm auch keine Ausgabe bringen, da der AVR-G++ keine Standardklassen mitbringt, also auch nicht die IO-Klassen. Mehr dazu: http://www.roboternetz.de/phpBB2/zeigebeitrag.php?t=32705 Gruß, SIGINT P.S.: @Johannes: Wie ich eben gelesen hab ist die include ohne ".h" sogar richtig, da C++ includes wohl immer ohne Endung angegeben werden.
Sigint 112 wrote: > P.S.: @Johannes: Wie ich eben gelesen hab ist die include ohne ".h" > sogar richtig, da C++ includes wohl immer ohne Endung angegeben werden. Oh, zu lange nix mehr mit C++ zu tun gehabt... Hatte mir den Rest auch grad nicht richtig angeschaut... das "using" lässt auch darauf schließen, dass es sich tatsächlich um ein C++-Programm handelt. Das ist auch offensichtlich kein µC-Programm, da die ganze Peripherie-Initialisierung fehlt.
ich glaub ich mach beim makefile immer was falsch. ich geb immer ein: mcu-type: atmega8 c/c++ soure file und prot: usb dann speichere ich im ordner wo das .c file liegt ab. muss ich sonst noch was einstellen?
Das ist kein C-Programm. Das kann ein C-Compiler nicht übersetzen. #include <iostream> Das ist ein C++-Header (ohne *.h) using namespace std; Das ist C++. void Start (); void GetResults (); Das sind C++-Prototypen (ohne Argumentenliste wären sie allenfalls K&R-konform, also pre-C89) cout << "Select difficulty mode:\n"; C kennt keine I/O-Streams und kennt kein entsprechende Überladen des Shift-Operators, auch sind cout/cin unbekannt.
@Rufus: Na, hoffentlich kapiert er es diesmal. Steht schließlich so oder so ähnlich alles oben schon mal...
