Hi, aus mir nicht erklärlichen Gründen wird der AVR nicht erkannt, kann jedoch beschrieben sowie gelesen werden mit der -F Option? avrdude -p m8 -P /dev/ttyUSB0 -b 115200 -c avr910 -e -U flash:w:myproject.hex -F Found programmer: Id = "AVR ISP"; type = S Software Version = 4.1; Hardware Version = 0.1 Programmer supports auto addr increment. Programmer supports the following devices: Device code: 0x55 = ATtiny12 . . . Device code: 0x76 = ATMEGA8 Device code: 0x75 = ATMEGA6490 avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.01s avrdude: Device signature = 0x000000 avrdude: Yikes! Invalid device signature. avrdude: Expected signature for ATMEGA8 is 1E 93 07 avrdude: erasing chip avrdude: reading input file "myproject.hex" avrdude: input file myproject.hex auto detected as Intel Hex avrdude: writing flash (176 bytes): Writing | ################################################## | 100% 11.24s avrdude: 176 bytes of flash written avrdude: verifying flash memory against myproject.hex: avrdude: load data flash data from input file myproject.hex: avrdude: input file myproject.hex auto detected as Intel Hex avrdude: input file myproject.hex contains 176 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.38s avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0000 0x0c != 0x00 avrdude: verification error; content mismatch avrdude: safemode: Fuses OK avrdude done. Thank you.
Es handelt sich um die hier im AVR Tutorial vorgestellte Schaltung sowie den Programmer von ic-board.de
