1 | # Hey Emacs, this is a -*- makefile -*-
2 | #----------------------------------------------------------------------------
3 | # WinAVR Makefile Template written by Eric B. Weddington, J�rg Wunsch, et al.
4 | #
5 | # Released to the Public Domain
6 | #
7 | # Additional material for this makefile was written by:
8 | # Peter Fleury
9 | # Tim Henigan
10 | # Colin O'Flynn
11 | # Reiner Patommel
12 | # Markus Pfaff
13 | # Sander Pool
14 | # Frederik Rouleau
15 | #
16 | #----------------------------------------------------------------------------
17 | # On command line:
18 | #
19 | # make all = Make software.
20 | #
21 | # make clean = Clean out built project files.
22 | #
23 | # make coff = Convert ELF to AVR COFF.
24 | #
25 | # make extcoff = Convert ELF to AVR Extended COFF.
26 | #
27 | # make program = Download the hex file to the device, using avrdude.
28 | # Please customize the avrdude settings below first!
29 | #
30 | # make debug = Start either simulavr or avarice as specified for debugging,
31 | # with avr-gdb or avr-insight as the front end for debugging.
32 | #
33 | # make filename.s = Just compile filename.c into the assembler code only.
34 | #
35 | # make filename.i = Create a preprocessed source file for use in submitting
36 | # bug reports to the GCC project.
37 | #
38 | # To rebuild project do "make clean" then "make all".
39 | #----------------------------------------------------------------------------
40 |
41 |
42 | # MCU name
43 | MCU = atmega8
44 |
45 |
46 | # Processor frequency.
47 | # This will define a symbol, F_CPU, in all source code files equal to the
48 | # processor frequency. You can then use this symbol in your source code to
49 | # calculate timings. Do NOT tack on a 'UL' at the end, this will be done
50 | # automatically to create a 32-bit value in your source code.
51 | F_CPU = 8000000
52 |
53 |
54 | # Output format. (can be srec, ihex, binary)
55 | FORMAT = ihex
56 |
57 |
58 | # Target file name (without extension).
59 | TARGET = led_blink
60 |
61 |
62 | # List C source files here. (C dependencies are automatically generated.)
63 | SRC = $(TARGET).c
64 |
65 |
66 | # List Assembler source files here.
67 | # Make them always end in a capital .S. Files ending in a lowercase .s
68 | # will not be considered source files but generated files (assembler
69 | # output from the compiler), and will be deleted upon "make clean"!
70 | # Even though the DOS/Win* filesystem matches both .s and .S the same,
71 | # it will preserve the spelling of the filenames, and gcc itself does
72 | # care about how the name is spelled on its command-line.
73 | ASRC =
74 |
75 |
76 | # Optimization level, can be [0, 1, 2, 3, s].
77 | # 0 = turn off optimization. s = optimize for size.
78 | # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
79 | OPT = s
80 |
81 |
82 | # Debugging format.
83 | # Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
84 | # AVR Studio 4.10 requires dwarf-2.
85 | # AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
86 | DEBUG = stabs
87 |
88 |
89 | # List any extra directories to look for include files here.
90 | # Each directory must be seperated by a space.
91 | # Use forward slashes for directory separators.
92 | # For a directory that has spaces, enclose it in quotes.
93 | # EXTRAINCDIRS = f:/Programme/AVRlib
94 |
95 |
96 | # Compiler flag to set the C Standard level.
97 | # c89 = "ANSI" C
98 | # gnu89 = c89 plus GCC extensions
99 | # c99 = ISO C99 standard (not yet fully implemented)
100 | # gnu99 = c99 plus GCC extensions
101 | CSTANDARD = -std=gnu99
102 |
103 |
104 | # Place -D or -U options here
105 | CDEFS = -DF_CPU=$(F_CPU)UL
106 |
107 |
108 | # Place -I options here
109 | CINCS =
110 |
111 |
112 |
113 | #---------------- Compiler Options ----------------
114 | # -g*: generate debugging information
115 | # -O*: optimization level
116 | # -f...: tuning, see GCC manual and avr-libc documentation
117 | # -Wall...: warning level
118 | # -Wa,...: tell GCC to pass this to the assembler.
119 | # -adhlns...: create assembler listing
120 | CFLAGS = -g$(DEBUG)
121 | CFLAGS += $(CDEFS) $(CINCS)
122 | CFLAGS += -O$(OPT)
123 | CFLAGS += -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
124 | CFLAGS += -Wall -Wstrict-prototypes
125 | CFLAGS += -Wa,-adhlns=$(<:.c=.lst)
126 | CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
127 | CFLAGS += $(CSTANDARD)
128 |
129 |
130 | #---------------- Assembler Options ----------------
131 | # -Wa,...: tell GCC to pass this to the assembler.
132 | # -ahlms: create listing
133 | # -gstabs: have the assembler create line number information; note that
134 | # for use in COFF files, additional information about filenames
135 | # and function names needs to be present in the assembler source
136 | # files -- see avr-libc docs [FIXME: not yet described there]
137 | # -listing-cont-lines: Sets the maximum number of continuation lines of hex
138 | # dump that will be displayed for a given single line of source input.
139 | ASFLAGS = -Wa,-adhlns=$(<:.S=.lst),-gstabs,--listing-cont-lines=100
140 |
141 |
142 | #---------------- Library Options ----------------
143 | # Minimalistic printf version
144 | PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
145 |
146 | # Floating point printf version (requires MATH_LIB = -lm below)
147 | PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
148 |
149 | # If this is left blank, then it will use the Standard printf version.
150 | PRINTF_LIB =
151 | #PRINTF_LIB = $(PRINTF_LIB_MIN)
152 | #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
153 |
154 |
155 | # Minimalistic scanf version
156 | SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
157 |
158 | # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
159 | SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
160 |
161 | # If this is left blank, then it will use the Standard scanf version.
162 | SCANF_LIB =
163 | #SCANF_LIB = $(SCANF_LIB_MIN)
164 | #SCANF_LIB = $(SCANF_LIB_FLOAT)
165 |
166 |
167 | MATH_LIB = -lm
168 |
169 |
170 |
171 | #---------------- External Memory Options ----------------
172 |
173 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
174 | # used for variables (.data/.bss) and heap (malloc()).
175 | #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
176 |
177 | # 64 KB of external RAM, starting after internal RAM (ATmega128!),
178 | # only used for heap (malloc()).
179 | #EXTMEMOPTS = -Wl,--defsym=__heap_start=0x801100,--defsym=__heap_end=0x80ffff
180 |
181 | EXTMEMOPTS =
182 |
183 |
184 |
185 | #---------------- Linker Options ----------------
186 | # -Wl,...: tell GCC to pass this to linker.
187 | # -Map: create map file
188 | # --cref: add cross reference to map file
189 | LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
190 | LDFLAGS += $(EXTMEMOPTS)
191 | LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
192 |
193 |
194 |
195 | #---------------- Programming Options (avrdude) ----------------
196 |
197 | # Programming hardware: alf avr910 avrisp bascom bsd
198 | # dt006 pavr picoweb pony-stk200 sp12 stk200 stk500
199 | #
200 | # Type: avrdude -c ?
201 | # to get a full listing.
202 | #
203 | AVRDUDE_PROGRAMMER = stk200
204 |
205 | # com1 = serial port. Use lpt1 to connect to parallel port.
206 | AVRDUDE_PORT = lpt1 # programmer connected to serial device
207 |
208 | AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
209 | #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
210 |
211 |
212 | # Uncomment the following if you want avrdude's erase cycle counter.
213 | # Note that this counter needs to be initialized first using -Yn,
214 | # see avrdude manual.
215 | #AVRDUDE_ERASE_COUNTER = -y
216 |
217 | # Uncomment the following if you do /not/ wish a verification to be
218 | # performed after programming the device.
219 | #AVRDUDE_NO_VERIFY = -V
220 |
221 | # Increase verbosity level. Please use this when submitting bug
222 | # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
223 | # to submit bug reports.
224 | #AVRDUDE_VERBOSE = -v -v
225 |
226 | AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
227 | AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
228 | AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
229 | AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
230 |
231 |
232 |
233 | #---------------- Debugging Options ----------------
234 |
235 | # For simulavr only - target MCU frequency.
236 | DEBUG_MFREQ = $(F_CPU)
237 |
238 | # Set the DEBUG_UI to either gdb or insight.
239 | # DEBUG_UI = gdb
240 | DEBUG_UI = insight
241 |
242 | # Set the debugging back-end to either avarice, simulavr.
243 | DEBUG_BACKEND = avarice
244 | #DEBUG_BACKEND = simulavr
245 |
246 | # GDB Init Filename.
247 | GDBINIT_FILE = __avr_gdbinit
248 |
249 | # When using avarice settings for the JTAG
250 | JTAG_DEV = /dev/com1
251 |
252 | # Debugging port used to communicate between GDB / avarice / simulavr.
253 | DEBUG_PORT = 4242
254 |
255 | # Debugging host used to communicate between GDB / avarice / simulavr, normally
256 | # just set to localhost unless doing some sort of crazy debugging when
257 | # avarice is running on a different computer.
258 | DEBUG_HOST = localhost
259 |
260 |
261 |
262 | #============================================================================
263 |
264 |
265 | # Define programs and commands.
266 | SHELL = sh
267 | CC = avr-gcc
268 | OBJCOPY = avr-objcopy
269 | OBJDUMP = avr-objdump
270 | SIZE = avr-size
271 | NM = avr-nm
272 | AVRDUDE = avrdude
273 | REMOVE = rm -f
274 | COPY = cp
275 | WINSHELL = cmd
276 |
277 |
278 | # Define Messages
279 | # English
280 | MSG_ERRORS_NONE = Errors: none
281 | MSG_BEGIN = -------- begin --------
282 | MSG_END = -------- end --------
283 | MSG_SIZE_BEFORE = Size before:
284 | MSG_SIZE_AFTER = Size after:
285 | MSG_COFF = Converting to AVR COFF:
286 | MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
287 | MSG_FLASH = Creating load file for Flash:
288 | MSG_EEPROM = Creating load file for EEPROM:
289 | MSG_EXTENDED_LISTING = Creating Extended Listing:
290 | MSG_SYMBOL_TABLE = Creating Symbol Table:
291 | MSG_LINKING = Linking:
292 | MSG_COMPILING = Compiling:
293 | MSG_ASSEMBLING = Assembling:
294 | MSG_CLEANING = Cleaning project:
295 |
296 |
297 |
298 |
299 | # Define all object files.
300 | OBJ = $(SRC:.c=.o) $(ASRC:.S=.o)
301 |
302 | # Define all listing files.
303 | LST = $(SRC:.c=.lst) $(ASRC:.S=.lst)
304 |
305 |
306 | # Compiler flags to generate dependency files.
307 | GENDEPFLAGS = -MD -MP -MF .dep/$(@F).d
308 |
309 |
310 | # Combine all necessary flags and optional flags.
311 | # Add target processor to flags.
312 | ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
313 | ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
314 |
315 |
316 |
317 |
318 |
319 | # Default target.
320 | all: begin gccversion sizebefore build sizeafter end
321 |
322 | build: elf hex eep lss sym extcoff
323 |
324 | elf: $(TARGET).elf
325 | hex: $(TARGET).hex
326 | eep: $(TARGET).eep
327 | lss: $(TARGET).lss
328 | sym: $(TARGET).sym
329 |
330 |
331 |
332 | # Eye candy.
333 | # AVR Studio 3.x does not check make's exit code but relies on
334 | # the following magic strings to be generated by the compile job.
335 | begin:
336 | @echo
337 | @echo $(MSG_BEGIN)
338 |
339 | end:
340 | @echo $(MSG_END)
341 | @echo
342 |
343 |
344 | # Display size of file.
345 | HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
346 | ELFSIZE = $(SIZE) $(TARGET).elf
347 |
348 | sizebefore:
349 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
350 | 2>/dev/null; echo; fi
351 |
352 | sizeafter:
353 | @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
354 | 2>/dev/null; echo; fi
355 |
356 |
357 |
358 | # Display compiler version information.
359 | gccversion :
360 | @$(CC) --version
361 |
362 |
363 |
364 | # Program the device.
365 | program: $(TARGET).hex $(TARGET).eep
366 | $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
367 |
368 |
369 | # Generate avr-gdb config/init file which does the following:
370 | # define the reset signal, load the target file, connect to target, and set
371 | # a breakpoint at main().
372 | gdb-config:
373 | @$(REMOVE) $(GDBINIT_FILE)
374 | @echo define reset >> $(GDBINIT_FILE)
375 | @echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
376 | @echo end >> $(GDBINIT_FILE)
377 | @echo file $(TARGET).elf >> $(GDBINIT_FILE)
378 | @echo target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE)
379 | ifeq ($(DEBUG_BACKEND),simulavr)
380 | @echo load >> $(GDBINIT_FILE)
381 | endif
382 | @echo break main >> $(GDBINIT_FILE)
383 |
384 | debug: gdb-config $(TARGET).elf
385 | ifeq ($(DEBUG_BACKEND), avarice)
386 | @echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
387 | @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
388 | $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
389 | @$(WINSHELL) /c pause
390 | else
391 | @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
392 | $(DEBUG_MFREQ) --port $(DEBUG_PORT)
393 | endif
394 | @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
395 |
396 |
397 |
398 | # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
399 | COFFCONVERT=$(OBJCOPY) --debugging \
400 | --change-section-address .data-0x800000 \
401 | --change-section-address .bss-0x800000 \
402 | --change-section-address .noinit-0x800000 \
403 | --change-section-address .eeprom-0x810000
404 |
405 |
406 | coff: $(TARGET).elf
407 | @echo
408 | @echo $(MSG_COFF) $(TARGET).cof
409 | $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
410 |
411 |
412 | extcoff: $(TARGET).elf
413 | @echo
414 | @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
415 | $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
416 |
417 |
418 |
419 | # Create final output files (.hex, .eep) from ELF output file.
420 | %.hex: %.elf
421 | @echo
422 | @echo $(MSG_FLASH) $@
423 | $(OBJCOPY) -O $(FORMAT) -R .eeprom $< $@
424 |
425 | %.eep: %.elf
426 | @echo
427 | @echo $(MSG_EEPROM) $@
428 | -$(OBJCOPY) -j .eeprom --set-section-flags .eeprom=alloc,load \
429 | --change-section-lma .eeprom=0 -O $(FORMAT) $< $@
430 |
431 | # Create extended listing file from ELF output file.
432 | %.lss: %.elf
433 | @echo
434 | @echo $(MSG_EXTENDED_LISTING) $@
435 | $(OBJDUMP) -h -S $< > $@
436 |
437 | # Create a symbol table from ELF output file.
438 | %.sym: %.elf
439 | @echo
440 | @echo $(MSG_SYMBOL_TABLE) $@
441 | $(NM) -n $< > $@
442 |
443 |
444 |
445 | # Link: create ELF output file from object files.
446 | .SECONDARY : $(TARGET).elf
447 | .PRECIOUS : $(OBJ)
448 | %.elf: $(OBJ)
449 | @echo
450 | @echo $(MSG_LINKING) $@
451 | $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
452 |
453 |
454 | # Compile: create object files from C source files.
455 | %.o : %.c
456 | @echo
457 | @echo $(MSG_COMPILING) $<
458 | $(CC) -c $(ALL_CFLAGS) $< -o $@
459 |
460 |
461 | # Compile: create assembler files from C source files.
462 | %.s : %.c
463 | $(CC) -S $(ALL_CFLAGS) $< -o $@
464 |
465 |
466 | # Assemble: create object files from assembler source files.
467 | %.o : %.S
468 | @echo
469 | @echo $(MSG_ASSEMBLING) $<
470 | $(CC) -c $(ALL_ASFLAGS) $< -o $@
471 |
472 | # Create preprocessed source for use in sending a bug report.
473 | %.i : %.c
474 | $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
475 |
476 |
477 | # Target: clean project.
478 | clean: begin clean_list end
479 |
480 | clean_list :
481 | @echo
482 | @echo $(MSG_CLEANING)
483 | $(REMOVE) $(TARGET).hex
484 | $(REMOVE) $(TARGET).eep
485 | $(REMOVE) $(TARGET).cof
486 | $(REMOVE) $(TARGET).elf
487 | $(REMOVE) $(TARGET).map
488 | $(REMOVE) $(TARGET).sym
489 | $(REMOVE) $(TARGET).lss
490 | $(REMOVE) $(OBJ)
491 | $(REMOVE) $(LST)
492 | $(REMOVE) $(SRC:.c=.s)
493 | $(REMOVE) $(SRC:.c=.d)
494 | $(REMOVE) .dep/*
495 |
496 |
497 |
498 | # Include the dependency files.
499 | -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
500 |
501 |
502 | # Listing of phony targets.
503 | .PHONY : all begin finish end sizebefore sizeafter gccversion \
504 | build elf hex eep lss sym coff extcoff \
505 | clean clean_list program debug gdb-config
