Hallo Leute, ich bin in Thema AVR ein Anfänger: Ich habe mir zum Test, das AVR-GCC-TutorialProjekt, zu rade gezogen, und habe nur die Ports von B auf A umgeschrieben. #include <avr/io.h> // (1) int main (void) { // (2) DDRA = 0xff; // (3) PORTA = 0x03; // (4) while(1) { // (5a) /* "leere" Schleife*/; // (5b) } // (5c) /* wird nie erreicht */ return 0; // (6) } --------------------------------------------- Beim erstellen des Projektes bekomme ich folgende Fehlermeldung: gcc plug-in: Could not insert Project data into Project tree gcc plug-in: Error: Object file not found on expected location C:\Program Files (x86)\Stardock\Object Desktop\DeskScapes\Atmega8515\default\Atmega8515.elf Loaded plugin AVR GCC Loaded partfile: C:\Program Files (x86)\Atmel\AVR Tools\PartDescriptionFiles\ATmega8515.xml gcc plug-in: Error: Object file not found on expected location C:\Users\Tobias\Documents\AVR\Atmega8515\test\default\test.elf ______________________________________________________________ Loaded plugin STK500 gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found avr-gcc at C:\Program Files (x86)\WinAVR-20070525\bin\avr-gcc.exe gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found make at C:\Program Files (x86)\WinAVR-20070525\utils\bin\make.exe gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found avr-gcc at C:\Program Files (x86)\WinAVR-20070525\bin\avr-gcc.exe gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found make at C:\Program Files (x86)\WinAVR-20070525\utils\bin\make.exe Loaded plugin AVR GCC Loaded partfile: C:\Program Files (x86)\Atmel\AVR Tools\PartDescriptionFiles\ATmega8515.xml Flash memory 8192 EEPROM memory 512 I/O memory start 0x20 I/O start 0x00 I/O stop 0x3F SRAM size 512 SRAM start 0x60 XRAM size 65536 Temporary page buffer 64 SRAM start 0x260 gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::updateControlDataFromProject() Could not find source file in Project datastructure gcc plug-in: Could not insert Project data into Project tree gcc plug-in: Error: Object file not found on expected location C:\Program Files (x86)\Stardock\Object Desktop\DeskScapes\Atmega8515\default\Atmega8515.elf Loaded plugin AVR GCC Loaded partfile: C:\Program Files (x86)\Atmel\AVR Tools\PartDescriptionFiles\ATmega8515.xml Flash memory 8192 EEPROM memory 512 I/O memory start 0x20 I/O start 0x00 I/O stop 0x3F SRAM size 512 SRAM start 0x60 XRAM size 65536 Temporary page buffer 64 SRAM start 0x260 gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: PlugInUtility::getExternalHeaderFiles Dependency directory does not exist Loaded file: C:\Users\Tobias\Documents\AVR\Atmega8515\test\test.c gcc plug-in: Output directory C:\Users\Tobias\Documents\AVR\Atmega8515\test\default\ does not exist gcc plug-in: Created directory C:\Users\Tobias\Documents\AVR\Atmega8515\test\default\ gcc plug-in: make() Target successfully built gcc plug-in: PlugInUtility::getExternalHeaderFiles Dependency directory does not exist gcc plug-in: Error: Object file not found on expected location C:\Users\Tobias\Documents\AVR\Atmega8515\test\default\test.elf gcc plug-in: PlugInUtility::getExternalHeaderFiles Dependency directory does not exist Kann mir bitte jemand ein Tip geben was ich falsch mache. Mit besten Dank im voraus Tobias
Hmm, das sieht mir nach einer vermurksten Projektdatei aus. Ich habe mal ein Projekt angehängt. Vielleicht geht das ja. (Irgendwo entpacken und 'test.aps' doppelklicken. AVR-Studio sollte dann von selbst starten. Dort dann F7 drücken und sehen was passiert.)
Hallo für deine Antwort , aber leider willd as nicht Funktionieren. gcc plug-in: Error: Object file not found on expected location Was hat es mit dem plug-in Error aufsich? Mit besten Dank im vorraus Tobias Loaded plugin STK500 gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found avr-gcc at C:\Program Files (x86)\Atmel\WinAVR-20070525\bin\avr-gcc.exe gcc plug-in: PlugInUtility::setupAndCheckWinAVR() Found make at C:\Program Files (x86)\Atmel\WinAVR-20070525\utils\bin\make.exe Loaded plugin AVR GCC Loaded partfile: C:\Program Files (x86)\Atmel\AVR Tools\PartDescriptionFiles\ Flash memory EEPROM memory I/O memory start 0x20 I/O start I/O stop SRAM size SRAM start gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: CProjectTree::OnSize() gcc plug-in: Error: Object file not found on expected location C:\Users\Tobias\Downloads\Atmel\8515_test\m8515\test\default\test.elf
Diese Fehlermeldung habe ich noch nie gesehen. Aber ich habe gehört das es beim AVR-Studio/WinAVR Probleme gibt wenn Pfad- und/oder Dateinamen Leerzeichen enthalten. Soweit ich weiß ist der Standardordner für WinAVR C:\WINAVR. Vielleicht hilft es also wenn du WinAVR erst deinstallierst und danach erneut installierst und als Ordner 'C:\WINAVR' angibst. Bei mir liegt WinAVR jedenfalls dort (war glaube ich auch die Vorgabe). Das AVR-Studio liegt unter C:\Programme\Atmel\ bzw. C:\Program Files\Atmel. Beim Studio scheint es also egal zu sein.
Hallo let, du hast denn Nagel auf dem Kopf getroffen, neuer Pfad: "C:\MCU\Atmel\AVR" Danke an Euch allen :-) Gruß Tobias
