1  | /* $Id: crc16.h,v 1.2.2.1 2006/04/19 20:35:54 joerg_wunsch Exp $ */
2  |
3  | #ifndef _UTIL_CRC16_H_
4  | #define _UTIL_CRC16_H_
5  |
6  | #include <stdint.h>
7  |
8  | /** \defgroup util_crc <util/crc16.h>: CRC Computations
9  |     \code#include <util/crc16.h>\endcode
10  |
11  |     This header file provides a optimized inline functions for calculating
12  |     cyclic redundancy checks (CRC) using common polynomials.
13  |
14  |     \par References:
15  |
16  |     \par
17  |
18  |     See the Dallas Semiconductor app note 27 for 8051 assembler example and
19  |     general CRC optimization suggestions. The table on the last page of the
20  |     app note is the key to understanding these implementations.
21  |
22  |     \par
23  |
24  |     Jack Crenshaw's "Implementing CRCs" article in the January 1992 isue of \e
25  |     Embedded \e Systems \e Programming. This may be difficult to find, but it
26  |     explains CRC's in very clear and concise terms. Well worth the effort to
27  |     obtain a copy.
28  |
29  |     A typical application would look like:
30  |
31  |     \code
32  |     // Dallas iButton test vector.
33  |     uint8_t serno[] = { 0x02, 0x1c, 0xb8, 0x01, 0, 0, 0, 0xa2 };
34  |
35  |     int
36  |     checkcrc(void)
37  |     {
38  |   uint8_t crc = 0, i;
39  |
40  |   for (i = 0; i < sizeof serno / sizeof serno[0]; i++)
41  |       crc = _crc_ibutton_update(crc, serno[i]);
42  |
43  |   return crc; // must be 0
44  |     }
45  |     \endcode
46  | */
47  |
48  | /** \ingroup util_crc
49  |     Optimized CRC-16 calculation.
50  |
51  |     Polynomial: x^16 + x^15 + x^2 + 1 (0xa001)<br>
52  |     Initial value: 0xffff
53  |
54  |     This CRC is normally used in disk-drive controllers.
55  |
56  |     The following is the equivalent functionality written in C.
57  |
58  |     \code
59  |     uint16_t
60  |     crc16_update(uint16_t crc, uint8_t a)
61  |     {
62  |   int i;
63  |
64  |   crc ^= a;
65  |   for (i = 0; i < 8; ++i)
66  |   {
67  |       if (crc & 1)
68  |     crc = (crc >> 1) ^ 0xA001;
69  |       else
70  |     crc = (crc >> 1);
71  |   }
72  |
73  |   return crc;
74  |     }
75  |
76  |     \endcode */
77  |
78  | static __inline__ uint16_t
79  | _crc16_update(uint16_t crc, uint8_t a)
80  | {
81  |
82  |   int i;
83  |
84  |   crc ^= a;
85  |   for( i = 0; i < 8; ++i )
86  |   {
87  |       if( crc & 1 )
88  |     crc = (crc>>1) ^ 0xA001;
89  |       else
90  |     crc = (crc>>1);
91  |   }
92  |
93  |   return crc;
94  | }
95  |
96  | /** \ingroup util_crc
97  |     Optimized CRC-XMODEM calculation.
98  |
99  |     Polynomial: x^16 + x^12 + x^5 + 1 (0x1021)<br>
100  |     Initial value: 0x0
101  |
102  |     This is the CRC used by the Xmodem-CRC protocol.
103  |
104  |     The following is the equivalent functionality written in C.
105  |
106  |     \code
107  |     uint16_t
108  |     crc_xmodem_update (uint16_t crc, uint8_t data)
109  |     {
110  |         int i;
111  |
112  |         crc = crc ^ ((uint16_t)data << 8);
113  |         for (i=0; i<8; i++)
114  |         {
115  |             if (crc & 0x8000)
116  |                 crc = (crc << 1) ^ 0x1021;
117  |             else
118  |                 crc <<= 1;
119  |         }
120  |
121  |         return crc;
122  |     }
123  |     \endcode */
124  |
125  | static __inline__ uint16_t
126  | _crc_xmodem_update(uint16_t __crc, uint8_t __data)
127  | {
128  |     uint16_t __ret;             /* %B0:%A0 (alias for __crc) */
129  |     uint8_t __tmp1;             /* %1 */
130  |     uint8_t __tmp2;             /* %2 */
131  |                                 /* %3  __data */
132  |
133  |     __asm__ __volatile__ (
134  |         "eor    %B0,%3"          "\n\t" /* crc.hi ^ data */
135  |         "mov    __tmp_reg__,%B0" "\n\t"
136  |         "swap   __tmp_reg__"     "\n\t" /* swap(crc.hi ^ data) */
137  |
138  |         /* Calculate the ret.lo of the CRC. */
139  |         "mov    %1,__tmp_reg__"  "\n\t"
140  |         "andi   %1,0x0f"         "\n\t"
141  |         "eor    %1,%B0"          "\n\t"
142  |         "mov    %2,%B0"          "\n\t"
143  |         "eor    %2,__tmp_reg__"  "\n\t"
144  |         "lsl    %2"              "\n\t"
145  |         "andi   %2,0xe0"         "\n\t"
146  |         "eor    %1,%2"           "\n\t" /* __tmp1 is now ret.lo. */
147  |
148  |         /* Calculate the ret.hi of the CRC. */
149  |         "mov    %2,__tmp_reg__"  "\n\t"
150  |         "eor    %2,%B0"          "\n\t"
151  |         "andi   %2,0xf0"         "\n\t"
152  |         "lsr    %2"              "\n\t"
153  |         "mov    __tmp_reg__,%B0" "\n\t"
154  |         "lsl    __tmp_reg__"     "\n\t"
155  |         "rol    %2"              "\n\t"
156  |         "lsr    %B0"             "\n\t"
157  |         "lsr    %B0"             "\n\t"
158  |         "lsr    %B0"             "\n\t"
159  |         "andi   %B0,0x1f"        "\n\t"
160  |         "eor    %B0,%2"          "\n\t"
161  |         "eor    %B0,%A0"         "\n\t" /* ret.hi is now ready. */
162  |         "mov    %A0,%1"          "\n\t" /* ret.lo is now ready. */
163  |         : "=d" (__ret), "=d" (__tmp1), "=d" (__tmp2)
164  |         : "r" (__data), "0" (__crc)
165  |         : "r0"
166  |     );
167  |     return __ret;
168  | }
169  |
170  | /** \ingroup util_crc
171  |     Optimized CRC-CCITT calculation.
172  |
173  |     Polynomial: x^16 + x^12 + x^5 + 1 (0x8408)<br>
174  |     Initial value: 0xffff
175  |
176  |     This is the CRC used by PPP and IrDA.
177  |
178  |     See RFC1171 (PPP protocol) and IrDA IrLAP 1.1
179  |
180  |     \note Although the CCITT polynomial is the same as that used by the Xmodem
181  |     protocol, they are quite different. The difference is in how the bits are
182  |     shifted through the alorgithm. Xmodem shifts the MSB of the CRC and the
183  |     input first, while CCITT shifts the LSB of the CRC and the input first.
184  |
185  |     The following is the equivalent functionality written in C.
186  |
187  |     \code
188  |     uint16_t
189  |     crc_ccitt_update (uint16_t crc, uint8_t data)
190  |     {
191  |         data ^= lo8 (crc);
192  |         data ^= data << 4;
193  |
194  |         return ((((uint16_t)data << 8) | hi8 (crc)) ^ (uint8_t)(data >> 4)
195  |                 ^ ((uint16_t)data << 3));
196  |     }
197  |     \endcode */
198  |
199  | static __inline__ uint16_t
200  | _crc_ccitt_update (uint16_t __crc, uint8_t __data)
201  | {
202  |     uint16_t __ret;
203  |
204  |     __asm__ __volatile__ (
205  |         "eor    %A0,%1"          "\n\t"
206  |
207  |         "mov    __tmp_reg__,%A0" "\n\t"
208  |         "swap   %A0"             "\n\t"
209  |         "andi   %A0,0xf0"        "\n\t"
210  |         "eor    %A0,__tmp_reg__" "\n\t"
211  |
212  |         "mov    __tmp_reg__,%B0" "\n\t"
213  |
214  |         "mov    %B0,%A0"         "\n\t"
215  |
216  |         "swap   %A0"             "\n\t"
217  |         "andi   %A0,0x0f"        "\n\t"
218  |         "eor    __tmp_reg__,%A0" "\n\t"
219  |
220  |         "lsr    %A0"             "\n\t"
221  |         "eor    %B0,%A0"         "\n\t"
222  |
223  |         "eor    %A0,%B0"         "\n\t"
224  |         "lsl    %A0"             "\n\t"
225  |         "lsl    %A0"             "\n\t"
226  |         "lsl    %A0"             "\n\t"
227  |         "eor    %A0,__tmp_reg__"
228  |
229  |         : "=d" (__ret)
230  |         : "r" (__data), "0" (__crc)
231  |         : "r0"
232  |     );
233  |     return __ret;
234  | }
235  |
236  | /** \ingroup util_crc
237  |     Optimized Dallas (now Maxim) iButton 8-bit CRC calculation.
238  |
239  |     Polynomial: x^8 + x^5 + x^4 + 1 (0x8C)<br>
240  |     Initial value: 0x0
241  |
242  |     See http://www.maxim-ic.com/appnotes.cfm/appnote_number/27
243  |
244  |     The following is the equivalent functionality written in C.
245  |
246  |     \code
247  |     uint8_t
248  |     _crc_ibutton_update(uint8_t crc, uint8_t data)
249  |     {
250  |   uint8_t i;
251  |
252  |   crc = crc ^ data;
253  |   for (i = 0; i < 8; i++)
254  |   {
255  |       if (crc & 0x01)
256  |           crc = (crc >> 1) ^ 0x8C;
257  |       else
258  |           crc >>= 1;
259  |   }
260  |
261  |   return crc;
262  |     }
263  |     \endcode
264  | */
265  |
266  | static __inline__ uint8_t
267  | _crc_ibutton_update(uint8_t __crc, uint8_t __data)
268  | {
269  |   uint8_t __i, __pattern;
270  |   __asm__ __volatile__ (
271  |     "  eor  %0, %4" "\n\t"
272  |     "  ldi  %1, 8" "\n\t"
273  |     "  ldi  %2, 0x8C" "\n\t"
274  |     "1:  bst  %0, 0" "\n\t"
275  |     "  lsr  %0" "\n\t"
276  |     "  brtc  2f" "\n\t"
277  |     "  eor  %0, %2" "\n\t"
278  |     "2:  dec  %1" "\n\t"
279  |     "  brne  1b" "\n\t"
280  |     : "=r" (__crc), "=d" (__i), "=d" (__pattern)
281  |     : "0" (__crc), "r" (__data));
282  |   return __crc;
283  | }
284  |
285  | #endif /* _UTIL_CRC16_H_ */
