Hallo zusammen, ich habe mit dem ICD2 einen PIC programmiert. Jetzt wollte ich die 8.00 Version von MPLAP an einem anderen Rechner ausprobieren. Als ich wieder auf den alten Rechner ging (MPLAP 7.60) funktionierte das debuggen nicht mehr - programmieren kann ich den Chip weiterhin - da gibt mir der Rechner keine Fehlermeldung aus. Hier nochmal das Output-Window: MPLAB ICD 2 Ready Resetting Target MPLAB ICD 2 Ready Connecting to MPLAB ICD 2 ...Connected Setting Vdd source to MPLAB ICD 2 Target Device PIC18F4331 found, revision = Rev 0x2 ...Reading ICD Product ID Running ICD Self Test ...Passed MPLAB ICD 2 Ready Resetting Target MPLAB ICD 2 Ready ICDWarn0015: Program memory has changed since last program operation? Continue with Debug operation? Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. Kann mir einer von Euch helfen? Vielen Dank im Voraus Korbinian
"ICDWarn0015: Program memory has changed since last program operation? Continue with Debug operation?" Hier unterscheidet sich der Code auf dem Chip mit deinem Code.
Hallo Micha, ich habe jetzt mal das aktuelle Programm auf den Chip programmiert: ..Programming Program Memory (0x0 - 0x5F) Verifying... ...Program Memory ...EEPROM ...Verify Succeeded Programming Configuration Bits .. Config Memory Verifying configuration memory... ...Verify Succeeded ...Programming succeeded 09-Jan-2008, 11:05:19 MPLAB ICD 2 Ready Nachher hab ich auf den Debugger umgeschaltet: Connecting to MPLAB ICD 2 ...Connected Setting Vdd source to MPLAB ICD 2 Target Device PIC18F4331 found, revision = Rev 0x2 ...Reading ICD Product ID Running ICD Self Test ...Passed MPLAB ICD 2 Ready Und dann wollte ich das Programm wieder Schritt für Schritt laufen lassen, aber hier taucht immer wieder das Problem mit ICDWarn0015 und ICD0083 auf: CDWarn0015: Program memory has changed since last program operation? Continue with Debug operation? Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target ICD0083: Debug: Unable to enter debug mode. Please double click this message for more information. MPLAB ICD 2 Ready Stepping Target Was mache ich falsch?
Du musst erst den Debugger auswählen und dann nochmal programmieren (mit dem Debugger)
Super, danke das war´s!!! Ich habe immer erst mit dem Programmer programmiert und dann zum Debugger gewechselt! Vielen Dank nochmal Korbinian
