Hallo Freaks.... wenn ich das C Programm "LCD2 Beispiel Ausgabe" im AVR Studio compeiliere und Linke bekomme ich folgende Fehlermeldungen. Im AVR Workpad funktioniert es, aber ich möchte undbedingt das AVR Studio zum programieren nehmen. Bitte dringend um Hilfe.... Build started 27.2.2008 at 13:20:55 avr-gcc.exe -mmcu=atmega8 -Wall -gdwarf-2 -Os -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT display.o -MF dep/display.o.d -c ../display.c ../display.c: In function 'lcd_send': ../display.c:43: warning: implicit declaration of function 'sbi' ../display.c:44: warning: implicit declaration of function 'cbi' ../display.c: At top level: ../display.c:81: error: conflicting types for 'lcd_write' ../display.c:71: error: previous definition of 'lcd_write' was here ../display.c: In function 'lcd_write': ../display.c:84: warning: passing argument 1 of 'lcd_write' makes pointer from integer without a cast ../display.c: At top level: ../display.c:94: error: conflicting types for 'lcd_write' ../display.c:71: error: previous definition of 'lcd_write' was here ../display.c: In function 'lcd_write': ../display.c:97: warning: passing argument 1 of 'lcd_write' makes pointer from integer without a cast ../display.c:97: error: too few arguments to function 'lcd_write' ../display.c: In function 'main': ../display.c:194: error: too few arguments to function 'lcd_write' ../display.c:196: error: too few arguments to function 'lcd_write' make: *** [display.o] Error 1 Build failed with 7 errors and 4 warnings... Hier das Programm: #define F_CPU 3686400 #include <avr\io.h> #include <util\delay.h> //////////////////////////////////////////////////////////////////////// ///// // allgemeine-Funktionen //---------------------------------------------------------------------- ----- // wait_ms(..) - Wartet einige Millisekunden // Die Dauer ist nicht kalibriert. // PE: miliSec=Anzahl der zu wartenden Millisekunden //---------------------------------------------------------------------- ----- void wait_ms(int miliSec) { _delay_loop_2( 1*(F_CPU/(1000/4)) * miliSec); // 4 Zyklen warteschleife } void wait_us(int mikroSec) { _delay_loop_2( 1*(F_CPU/(1000000/4)) * mikroSec); // 4 Zyklen warteschleife } //////////////////////////////////////////////////////////////////////// ////// // LCD-Funktionen für myAVR-Board + myAVR-LCD // 4-BitModus an PortD Bit 4-7 // PortD Bit 2 = RS, high=Daten, low=Kommando // PortD Bit 3 = E, high-Impuls für gültige Daten //---------------------------------------------------------------------- ----- // lcd_send(..) - sendet ein Byte an LCD im 4-Bit-Modus // RS muss vorher richtig gesetzt sein // PE: data=zu sendendes Byte //---------------------------------------------------------------------- ----- void lcd_send(char data) { // aktuelles RS ermitteln char rs=PORTD; rs&=4; // High-Teil senden char tmp=data; tmp&=0xf0; tmp|=rs; PORTD=tmp; // Schreibsignal sbi(PORTD,3); cbi(PORTD,3); // Low-Teil senden tmp=data; tmp&=0x0f; tmp*=16; tmp|=rs; PORTD=tmp; // Schreibsignal sbi(PORTD,3); cbi(PORTD,3); // verarbeiten lassen wait_ms(1); } //---------------------------------------------------------------------- ----- // lcd_cmd(..) - sendet ein Kommando an LCD // PE: cmd=Kommando-Byte //---------------------------------------------------------------------- ----- void lcd_cmd(char cmd) { cbi(PORTD,2); // RS löschen = Kommando lcd_send(cmd); // senden } //---------------------------------------------------------------------- ----- // lcd_write(..) - sendet ein Zeichen (Daten) an LCD // PE: text=Zeichen //---------------------------------------------------------------------- ----- void lcd_write(char text) { sbi(PORTD,2); // RS setzen = Daten lcd_send(text); // senden } //---------------------------------------------------------------------- ----- // lcd_write(..) - sendet eine Zeichenkette an LCD // Die Zeichenkette muss mit 0x00 abgeschlossen sein // PE: pText=Zeiger auf Zeichenkette //---------------------------------------------------------------------- ----- void lcd_write(char* pText) { while(pText[0]!=0) { lcd_write(pText[0]); pText++; } } //---------------------------------------------------------------------- ----- // lcd_write(..) - sendet eine Zeichenkette an LCD // PE: pText=Zeiger auf Zeichenkette // count=Anzahl der zu sendenden Zeichen //---------------------------------------------------------------------- ----- void lcd_write(char* pText, int count) { while(count!=0) { lcd_write(pText[0]); pText++; count--; } } //---------------------------------------------------------------------- ----- // lcd_home(..) - Cursor auf Position 1,1 //---------------------------------------------------------------------- ----- void lcd_home() { lcd_cmd(0x02); wait_ms(2); // warten } //---------------------------------------------------------------------- ----- // lcd_clear(..) - löscht die Anzeige im LCD //---------------------------------------------------------------------- ----- void lcd_clear() { lcd_cmd(0x01); wait_ms(2); // warten } //---------------------------------------------------------------------- ----- // lcd_on(..) - schaltet das LCD an //---------------------------------------------------------------------- ----- void lcd_on() { lcd_cmd(0x0E); } //---------------------------------------------------------------------- ----- // lcd_off(..) - schaltet das LCD aus //---------------------------------------------------------------------- ----- void lcd_off() { lcd_cmd(0x08); } //---------------------------------------------------------------------- ----- // lcd_goto(..) - setzt die Cursorposition // PE: row = Zeile 1..2 // col = Spalte 1..16 //---------------------------------------------------------------------- ----- void lcd_goto(int row, int col) { row--; // Null-basierend row&=0x01; // sicherheitshalber row*=0x40; // Zeile nach Bit 6 bringen col--; // Null-basierend col&=0x0f; // sicherheitshalber char tmp=row|col; tmp|=0x80; // Cursor setzen lcd_cmd(tmp); // senden } //---------------------------------------------------------------------- ----- // lcd_init(..) - Schaltet die Ports und Initialisiert das LCD //---------------------------------------------------------------------- ----- void lcd_init() { // Port D = Ausgang DDRD=0xff; PORTD=0; // warten bist LCD-Controller gebootet wait_ms(50); // SOFT-RESET PORTD = 0x30; //0b00110000; sbi(PORTD,3); cbi(PORTD,3); wait_ms(5); PORTD = 0x30; //0b00110000; sbi(PORTD,3); cbi(PORTD,3); wait_us(100); PORTD = 0x30; //0b00110000; sbi(PORTD,3); cbi(PORTD,3); wait_ms(5); // 4-BitModus einschalten PORTD=0x20; // Schreibsignal sbi(PORTD,3); cbi(PORTD,3); wait_ms(5); // ab hier im 4-Bit-Modus lcd_cmd(0x28); // Funktions-Set: 2 Zeilen, 5x7 Matrix, 4 Bit //lcd_off(); lcd_cmd(0x06); // Entry Mode lcd_on(); lcd_clear(); } //---------------------------------------------------------------------- ----- // Main-Funktion //---------------------------------------------------------------------- ----- int main (void) { wait_ms(200); lcd_init(); lcd_goto(1,1); lcd_write("Hallo LCD"); lcd_goto(2,1); lcd_write("12345678"); while (1) { } // Mainloop return 0; } //---------------------------------------------------------------------- -----
> ../display.c:43: warning: implicit declaration of function 'sbi' > ../display.c:44: warning: implicit declaration of function 'cbi' Das ist ein Zeichen fdafür, dass deine Sourcen ziemlich alt sind. Diese Funktionen oder Makros (bin zu strack um nachzusehen) sind schon lange aus der avr-libc (Bibliothek mit den Standard C Funktionen für AVRs) verschwunden. Bei der Doku der avr-libc und im Netz und bei Bitmanipulation ist aber beschrieben, wie man diese Hürde beseitigt. Schwieriger wird es hier: //------------------------------------------------- // lcd_write(..) - sendet ein Zeichen (Daten) an LCD // PE: text=Zeichen //------------------------------------------------- void lcd_write(char text) { ... } //------------------------------------------------- // lcd_write(..) - sendet eine Zeichenkette an LCD // Die Zeichenkette muss mit 0x00 abgeschlossen sein // PE: pText=Zeiger auf Zeichenkette //------------------------------------------------- void lcd_write(char* pText) { ... } //------------------------------------------------- // lcd_write(..) - sendet eine Zeichenkette an LCD // PE: pText=Zeiger auf Zeichenkette // count=Anzahl der zu sendenden Zeichen //-_----------------------------------------------- void lcd_write(char* pText, int count) { ... } Du hast also drei Funktionen, die mit unterschiedlichen Argumenten aufgerufen werden und die jeweils was unterschiedliches machen aber *den gleichen Namen* haben. Das ist eine Programmierdenke die man von C++ kennt. Um das auf C umzumodeln, muss man die ganze Source durchgehen, versuchen den Sinn hinter jedem Aufruf zu sehen und dann einheitliche Namen schaffen. Möglicherweise sind auch andere Funktionen davon betroffen. Machbar ist das, die Source ist ja nicht so lang. Vielleicht hilft es auch das Beispiel so zu lassen und als C++ Projekt zu kompilieren. Der Kompiler macht dann aus dem Funktionsnamen und den Argumenttypen unterscheidbare Namen (stichwort Namemangling). Ich habe aber noch nie C++ mit AVRs eingesetzt, so dass ich dir hierbei nicht weiterhelfen kann.
Hi, schon etwas älter der Thread. Aber,...hast du, bzw. irgendjemand das hier schon hinbekommen? Bin auch gerade dabei, bekomme aber im AVR Studio kein Zeichen aufs Display. Fehler im obigen Code wurden alle beseitigt. Bzw. die der Compiler moniert hat. lg
