ich bin gerade dabei, das ADC Modul mit Multichannel, Softwaretriggerung
und Interrupt zu programmieren.
Nachfolgend mal der Quellcode:
1 | unsigned int adc_Init(void)
2 | {
3 | // reset
4 | AT91F_ADC_SoftReset(AT91C_BASE_ADC);
5 |
6 | // enable peripheral clock ADC
7 | AT91F_ADC_CfgPMC();
8 |
9 | // config timing of ADC 55Mhz mainclock, ADC clock 5MHz
10 | AT91F_ADC_CfgTimings(AT91C_BASE_ADC,
11 | 55 /*MHz MCK*/,
12 | 5 /*MHz ADCCK*/,
13 | 20 /*uSec startup time*/,
14 | 700 /*nSec sample and hold*/);
15 |
16 | // enable channels to measure
17 | // channel 0
18 | // channel 1
19 | // channel 2
20 | // channel 3
21 | AT91F_ADC_EnableChannel(AT91C_BASE_ADC,
22 | (AT91C_ADC_CH0 | AT91C_ADC_CH1 | AT91C_ADC_CH2 | AT91C_ADC_CH3));
23 |
24 |
25 | // enable interrupt of the last ADC channel 3
26 | AT91F_ADC_EnableIt(AT91C_BASE_ADC, (AT91C_ADC_CH3));
27 |
28 | // configure AIC
29 | AT91F_AIC_ConfigureIt(AT91C_BASE_AIC,
30 | AT91C_ID_ADC,
31 | AT91C_AIC_PRIOR_HIGHEST,
32 | AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL,
33 | adc_ISR);
34 |
35 | // enable AIC
36 | AT91F_AIC_EnableIt(AT91C_BASE_AIC, AT91C_ID_ADC);
37 |
38 | return 0;
39 | }
40 |
41 | static void adc_ISR(void)
42 | {
43 | unsigned int uiStatus = 0;
44 |
45 |
46 | // read status register
47 | uiStatus = AT91C_BASE_ADC->ADC_SR;
48 | uiStatus = uiStatus;
49 |
50 | if(uiStatus & AT91C_ADC_CH3)
51 | {
52 | // read ADC value
53 | ui_ValueCH0 = AT91F_ADC_GetConvertedDataCH0(AT91C_BASE_ADC);
54 | ui_ValueCH1 = AT91F_ADC_GetConvertedDataCH1(AT91C_BASE_ADC);
55 | ui_ValueCH2 = AT91F_ADC_GetConvertedDataCH2(AT91C_BASE_ADC);
56 | ui_ValueCH3 = AT91F_ADC_GetConvertedDataCH3(AT91C_BASE_ADC);
57 |
58 | // set valid
59 | adc_bool_Conversation_Valid = TRUE;
60 |
61 | }
62 |
63 | // clear interrupt
64 | AT91F_AIC_ClearIt(AT91C_BASE_AIC, AT91C_ID_ADC);
65 | }
66 |
67 | unsigned int adc_StartConversation(void)
68 | {
69 | adc_bool_Conversation_Valid = FALSE;
70 | AT91F_ADC_StartConversion(AT91C_BASE_ADC);
71 | return 0;
72 | }
Der Anstoss für die ADC erfolgt asynchron durch einen Softwaretrigger.
Mein Problem ist jetzt, dass die ADC genau einmal sauber funktioniert.
Bei allen weiteren
Softwaretriggers(AT91F_ADC_StartConversion(AT91C_BASE_ADC)) wird die ISR
nicht mehr ausgeführt.
Hat jemand eine Idee woran das liegen kann?
Danke Nobbie
