Hallo Leute,
ich versuche grade auf dem AVR Butterfly ein Menü zu erstellen. Mein
bisheriger Code:
menu.h
1 | /*
2 | Menütexte erstellen
3 | */
4 | static const char menu_string0[] PROGMEM = "Anfang";
5 | static const char menu_string1[] PROGMEM = "Test1";
6 | static const char menu_string2[] PROGMEM = "Ende";
7 |
8 |
9 | /*
10 | */
11 | typedef struct MENU{
12 | const char *text;
13 |
14 | unsigned char next;
15 | unsigned char prev;
16 |
17 | } MENU_ENTRY;
18 |
19 | const MENU_ENTRY menue[] PROGMEM = {
20 |
21 | {menu_string0, 1, 2},
22 | {menu_string1, 2, 0},
23 | {menu_string2, 0, 2},
24 |
25 | };
Meine main.c
1 | int main(void)
2 | {
3 | unsigned char MENU_COUNT=0; //menu entry
4 | char key; //pressed key
5 | char run=TRUE; //Hilfsvariable updatet das LCD-Display
6 |
7 |
8 | Initialization();
9 | sei();
10 |
11 | for (;;) // Main loop
12 | {
13 | if (run)
14 | {
15 | LCD_puts_f((char *)pgm_read_word (&menue[MENU_COUNT].text), 1); //get current menu entry
16 | LCD_Colon(0);
17 | run = NULL; //only update lcd when key is up-to-date
18 | }
19 |
20 | key = getkey();
21 |
22 | if (key==KEY_PLUS)
23 | {
24 | MENU_COUNT=GetPost(MENU_COUNT, TRUE); //get next menu entry
25 | run = TRUE; //update lcd
26 | }
27 |
28 | if (key==KEY_MINUS)
29 | {
30 | MENU_COUNT=GetPost(MENU_COUNT, FALSE); //get previous menu entry
31 | run = TRUE;
32 | }
33 |
34 |
35 |
36 | } //End Main loop
37 |
38 | return 0;
39 | }
40 |
41 | /*********************************************************
42 | *
43 | * Function name : GetPost
44 | *
45 | * Returns : POST
46 | *
47 | * Parameters : CURRENT, MODE
48 | *
49 | * Purpose: Get Next/Previous menu entry
50 | *
51 | **********************************************************/
52 |
53 | unsigned char GetPost (unsigned char CURRENT, BOOL MODE)
54 | {
55 | unsigned char POST;
56 |
57 | if (MODE==TRUE) //get next entry
58 | {
59 | POST = menue[CURRENT].next;
60 | }
61 |
62 | else //get previous entry
63 | {
64 | POST = menue[CURRENT].prev;
65 | }
66 |
67 | return POST;
68 | }
GCC kompiliert das ganze ohne Probleme, nur leider wird nur der erste
String ('Anfang') auf dem LCD angezeigt. Bei Drücken des Joysticks ist
nichts mehr auf dem Display zu sehen.
Hat jemand von euch ne Idee?
