1 | ' Atmega8
2 | ' VDD -> VCC
3 | ' GND -> GND
4 | ' SDI -> MOSI (PB3, Pin 17)
5 | ' SDO -> MISO (PB4, Pin 18)
6 | ' SCK -> SCK (PB5, Pin 19)
7 | ' nSel -> SS (PB2, Pin 16)
8 | ' Fsk - > R 10k
9 |
10 | ' Atmega16
11 | ' VDD -> VCC
12 | ' GND -> GND
13 | ' SDI -> MOSI (PB5, Pin 6)
14 | ' SDO -> MISO (PB6, Pin 7)
15 | ' SCK -> SCK (PB7, Pin 8)
16 | ' nSel -> SS (PB4, Pin 5)
17 | ' Fsk - > R 10k
18 |
19 | $regfile = "m16def.dat"
20 | $crystal = 1000000 '
21 | $hwstack = 32
22 | $swstack = 32
23 | $framesize = 40
24 |
25 | Declare Sub Rf12_init
26 | Declare Function Rf12_trans(byval Wert As Word) As Word
27 | Declare Sub Rf12_setfreq(byval Freq As Single)
28 | Declare Sub Rf12_setbandwith(byval Bandwith As Byte , Byval Gain As Byte , Byval Drssi As Byte)
29 | Declare Sub Rf12_setbaud(byval Rfbaud As Long)
30 | Declare Sub Rf12_setpower(byval Outpower As Byte , Byval Fskmod As Byte)
31 | Declare Sub Rf12_ready
32 | Declare Sub Rf12_readys
33 | Declare Sub Rf12_txdata(byval Maxchar As Byte)
34 | Declare Sub Rf12_rxdata(byval Maxchar As Byte)
35 | Declare Sub Senden
36 | Declare Sub Empfangen
37 |
38 | Const Rf12freq = 433.92
39 | Const Rf12baud = 1200
40 | Const Maxchar = 16
41 |
42 | Config Lcdpin = Pin , Db4 = Porta.7 , Db5 = Porta.6 , Db6 = Porta.5 , Db7 = Porta.4 , E = Portc.1 , Rs = Portc.0
43 | Config Lcd = 16 * 2 , Chipset = Dogm162v3
44 |
45 | Cursor Off Noblink
46 | Cls
47 |
48 | ' config the SPI in master mode.The clock must be a quarter of the slave cpu
49 | ' Hier ggf. den SoftSPI reinmachen
50 | Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = Low , Phase = 0 , Clockrate = 128 , Noss = 1
51 | Config Portd.7 = Output ' LED zur Schleifenkontrolle
52 |
53 |
54 | ' werden benötigt für rf12_ready
55 | Spi_cs Alias Portb.4 ' SS-Pin
56 | Config Spi_cs = Output
57 | Spi_sdo Alias Pinb.6 ' MISO-PIN
58 | Set Spi_cs
59 |
60 | ' init the spi pins
61 | Spiinit
62 |
63 | Dim Count As Byte
64 | Dim Temp As Word
65 | Dim Rfdata(32) As Byte
66 | Dim Text As String * Maxchar At Rfdata Overlay
67 | 'Dim J As Byte
68 |
69 | Locate 1 , 1 : Lcd "Init RFM12 "
70 | Waitms 100
71 | Call Rf12_init ' ein paar Register setzen (z.B. CLK auf 10MHz)
72 | Locate 1 , 1 : Lcd "Set Frequenz "
73 | Waitms 100
74 | Call Rf12_setfreq(rf12freq) ' Sende/Empfangsfrequenz auf 433,92MHz einstellen
75 | Locate 1 , 1 : Lcd "Set Bandwith "
76 | Waitms 100
77 | Call Rf12_setbandwith(4 , 1 , 4) ' 200kHz Bandbreite, -6dB Verstärkung, DRSSI threshold: -79dBm
78 | Locate 1 , 1 : Lcd "Set Baudrate "
79 | Waitms 100
80 | Call Rf12_setbaud(rf12baud) ' 19200 baud
81 | Locate 1 , 1 : Lcd "Set Tx-Power "
82 | Waitms 100
83 | Call Rf12_setpower(0 , 6) ' 1mW Ausgangangsleistung, 120kHz Frequenzshift
84 |
85 |
86 | 'Text = "Dies ist ein 433MHz Test !!!!!{013}{010}"
87 | 'Text = "433MHz Test #" + J
88 |
89 | ' Je nachdem ob Sender oder Empfänger die entsprechenden Zeilen aktivieren
90 |
91 | Do ' Ewigschleife
92 | Empfangen
93 | Pulseout Portd , 7 , 500 ' Schleifenkontrolle
94 | Locate 1 , 1 : Lcd "Ready "
95 | Wait 1
96 | Loop
97 |
98 | End
99 |
100 | ' ########################################################################
101 | ' ####### Tranceiverroutinen
102 | ' ########################################################################
103 |
104 | Sub Empfangen
105 | Locate 1 , 1 : Lcd "Empfange "
106 | Waitms 100
107 | Locate 2 , 1 : Lcd " "
108 | Locate 2 , 1
109 | Call Rf12_rxdata(maxchar)
110 | For Count = 1 To Maxchar
111 | Lcd Chr(rfdata(count)) ;
112 | Waitms 100
113 | Next Count
114 | End Sub
115 |
116 | Sub Senden
117 | Locate 1 , 1 : Lcd "Sende "
118 | Waitms 100
119 | Call Rf12_txdata(maxchar)
120 | Waitms 10
121 | End Sub
122 |
123 | ' ########################################################################
124 | ' ###### Unterroutinen
125 | ' ########################################################################
126 |
127 | Sub Rf12_init:
128 | Waitms 150
129 | Temp = Rf12_trans(&Hc0e0)
130 | Temp = Rf12_trans(&H80d7)
131 | Temp = Rf12_trans(&Hc2ab)
132 | Temp = Rf12_trans(&Hca81)
133 | Temp = Rf12_trans(&He000)
134 | Temp = Rf12_trans(&Hc800)
135 | Temp = Rf12_trans(&Hc4f7)
136 | End Sub
137 |
138 | Sub Rf12_setfreq(byval Freq As Single)
139 | Freq = Freq - 430.00
140 | Temp = Freq / 0.0025
141 | If Temp < 96 Then
142 | Temp = 96
143 | Elseif Temp > 3903 Then
144 | Temp = 3903
145 | End If
146 | Temp = Temp + &HA000
147 | Temp = Rf12_trans(temp)
148 | End Sub
149 |
150 | Sub Rf12_setbandwith(byval Bandwith As Byte , Byval Gain As Byte , Byval Drssi As Byte)
151 | Drssi = Drssi And 7
152 | Gain = Gain And 3
153 | Temp = Bandwith And 7
154 | Shift Temp , Left , 2
155 | Temp = Temp + Gain
156 | Shift Temp , Left , 3
157 | Temp = Temp + Drssi
158 | Temp = Temp + &H9400
159 | Temp = Rf12_trans(temp)
160 | End Sub
161 |
162 | Sub Rf12_setbaud(byval Rfbaud As Long )
163 | Local Ltemp As Long
164 | If Rfbaud < 663 Then Exit Sub
165 | If Rfbaud < 5400 Then
166 | Temp = 43104 / Rfbaud
167 | Temp = Temp + &HC680
168 | Else
169 | Ltemp = 344828 / Rfbaud
170 | Temp = Ltemp
171 | Temp = Temp + &HC600
172 | End If
173 | Decr Temp
174 | Temp = Rf12_trans(temp)
175 | End Sub
176 |
177 | Sub Rf12_setpower(byval Outpower As Byte , Byval Fskmod As Byte)
178 | Outpower = Outpower And 7
179 | Temp = Fskmod And 15
180 | Shift Temp , Left , 4
181 | Temp = Temp + Outpower
182 | Temp = Temp + &H9800
183 | Temp = Rf12_trans(temp)
184 | End Sub
185 |
186 | Sub Rf12_txdata(byval Maxchar As Byte)
187 | Temp = Rf12_trans(&H8238)
188 | Rf12_ready
189 | Temp = Rf12_trans(&Hb8aa)
190 | Rf12_ready
191 | Temp = Rf12_trans(&Hb8aa)
192 | Rf12_ready
193 | Temp = Rf12_trans(&Hb8aa)
194 | Rf12_ready
195 | Temp = Rf12_trans(&Hb82d)
196 | Rf12_ready
197 | Temp = Rf12_trans(&Hb8d4)
198 | Rf12_ready
199 | For Count = 1 To Maxchar
200 | Rf12_ready
201 | Temp = &HB800 + Rfdata(count)
202 | Temp = Rf12_trans(temp)
203 | Next Count
204 | Rf12_ready
205 | Temp = Rf12_trans(&H8208)
206 | End Sub
207 |
208 | Sub Rf12_rxdata(byval Maxchar As Byte)
209 | Temp = Rf12_trans(&H82c8)
210 | Temp = Rf12_trans(&Hca81)
211 | Temp = Rf12_trans(&Hca83)
212 | For Count = 1 To Maxchar
213 | Rf12_ready
214 | Temp = Rf12_trans(&Hb000)
215 | Rfdata(count) = Temp
216 | Next Count
217 | Temp = Rf12_trans(&H8208)
218 | End Sub
219 |
220 | Function Rf12_trans(byval Wert As Word) As Word
221 | Local Lowbyte As Byte
222 | Local Highbyte As Byte
223 | Lowbyte = Wert And 255
224 | Shift Wert , Right , 8
225 | Reset Spi_cs
226 | Highbyte = Spimove(wert)
227 | Lowbyte = Spimove(lowbyte)
228 | Set Spi_cs
229 | Temp = Highbyte * 256
230 | Temp = Temp + Lowbyte
231 | Rf12_trans = Temp
232 | End Function
233 |
234 | Sub Rf12_ready
235 | Local I As Word
236 | Reset Spi_cs
237 | For I = 1 To 65000
238 | If Spi_sdo = 1 Then Exit For
239 | Next
240 | End Sub
