Hallo, ich habe folgendes Problem mit der AT91SAM7x256.h Headerdatei: Ich kompiliere die um die Headerdatei erweitertete Beispieldatei simple.c durch Eingabe von make: #include <compiler.h> #include "at91sam7x256.h" /*! * \brief Main application routine. * */ int main(void) { for (;;); } Und bekomme dann folgende Fehlermeldung: C:\ethernut-4.4.1\nutapp\simple>make arm-elf-gcc -c -mcpu=arm7tdmi -Os -mthumb-interwork -fomit-frame-pointer -Wall - Wstrict-prototypes -fverbose-asm -Wa,-ahlms=simple.lst -DAT91SAM7X_EK -I../../nu tbld/include -I../../nut/include simple.c -o simple.o In file included from simple.c:64: at91sam7x256.h:57: error: expected identifier or '(' before numeric constant at91sam7x256.h:58: error: expected ';' before 'AT91_REG' at91sam7x256.h:220: error: expected identifier or '(' before numeric constant at91sam7x256.h:221: error: expected ';' before 'AT91_REG' at91sam7x256.h:285: error: expected identifier or '(' before numeric constant at91sam7x256.h:286: error: expected ';' before 'AT91_REG' at91sam7x256.h:397: error: expected identifier or '(' before numeric constant at91sam7x256.h:398: error: expected ';' before 'AT91_REG' at91sam7x256.h:430: error: expected identifier or '(' before numeric constant at91sam7x256.h:431: error: expected ';' before 'AT91_REG' at91sam7x256.h:605: error: expected identifier or '(' before numeric constant at91sam7x256.h:606: error: expected ';' before 'AT91_REG' at91sam7x256.h:862: error: expected identifier or '(' before numeric constant at91sam7x256.h:863: error: expected ';' before 'AT91_REG' at91sam7x256.h:966: error: expected identifier or '(' before numeric constant at91sam7x256.h:967: error: expected ';' before 'AT91_REG' at91sam7x256.h:1079: error: expected identifier or '(' before numeric constant at91sam7x256.h:1080: error: expected ';' before 'AT91_REG' at91sam7x256.h:1468: error: expected identifier or '(' before numeric constant at91sam7x256.h:1469: error: expected ';' before 'AT91_REG' make: *** [simple.o] Error 1 C:\ethernut-4.4.1\nutapp\simple> Hatte jemand zufällig schon mal diesen Fehler und kann mir sagen wie der einfach zu beheben ist? Beste Grüße, Lucien
>Und bekomme dann folgende Fehlermeldung: >tbld/include -I../../nut/include simple.c -o simple.o >In file included from simple.c:64: >at91sam7x256.h:57: error: expected identifier or '(' before numeric >constant Solche Fehlermeldungen bekommt man wenn eine Include Datei vorher Fehler enthalten sind. Also schau mal in compiler.h
Danke schön, es funktioniert anscheinend nur wenn at91sam7x256.h als erstes includiert wird. Es wird auf jeden Fall fehlerfrei kompiliert...
