1 | #include....
2 | #define MSG_LENGTH 1024
3 |
4 |
5 | struct hdr{
6 | struct iphdr ip;
7 | struct tcphdr tcp;
8 | char Data[MSG_LENGTH];
9 |
10 | };
11 |
12 | int main(){
13 |
14 | struct hdr paket;
15 |
16 | struct pseudohdr Pseudo;
17 |
18 | struct sockaddr_in addr;
19 |
20 | int rawsock;
21 |
22 | const int on=1;
23 |
24 | int se;
25 |
26 | /**
27 | *create a raw socket
28 | *
29 | *transport protokol: TCP Protokol
30 | */
31 | rawsock = create_socket(AF_INET, SOCK_RAW, IPPROTO_TCP);
32 | printf("create a Raw Socket\n");
33 | /**
34 | *set a socket option
35 | */
36 | if(setsockopt(rawsock, IPPROTO_IP, IP_HDRINCL, &on, sizeof(on)) < 0){
37 | perror("setsockopt()");
38 | exit(1);
39 | }
40 | /**
41 | *initialize paket
42 | */
43 | memset(&paket, 0, sizeof(struct hdr));
44 | /**
45 | *create IP Header
46 | */
47 | ....
48 |
49 | paket.ip.check = compute_checksum((uint16*)&paket.ip, sizeof(struct iphdr));///checksum
50 | /**
51 | *create TCP Header
52 |
53 | */
54 | ....
55 |
56 | /**
57 | *create Pseudo Header for computing TCP checksum
58 | *(quelle rfc 793)
59 | */
60 | Pseudo.saddr = paket.ip.saddr;
61 | Pseudo.daddr = paket.ip.daddr;
62 | Pseudo.reserved = 0;
63 | Pseudo.protocol = paket.ip.protocol;
64 | Pseudo.tcp_seg_len = htons(sizeof(struct tcphdr));
65 | bcopy((char*)&paket.tcp, (char*)&Pseudo.tcp, sizeof(struct tcphdr));
66 |
67 |
68 | printf("give your Data:\t");
69 | fgets(paket.Data, MSG_LENGTH, stdin);
70 |
71 | bcopy((char*)&paket.Data, (char*)&Pseudo.buf, MSG_LENGTH);
72 |
73 |
74 | paket.tcp.check = compute_checksum((uint16*)&Pseudo, MSG_LENGTH +
75 | sizeof(struct tcphdr) + sizeof(struct pseudohdr));
76 |
77 | /**
78 | *now the paket is sent
79 | */
80 |
81 | se = sendto(rawsock, &paket, sizeof(struct hdr), 0,
82 | (struct sockaddr*)&addr, sizeof(struct sockaddr_in));
83 |
84 | printf("the paket is sent\n");
85 | printf("Sent %d byte paket to %s\n",paket.ip.tot_len, DES_IP);
86 |
87 |
88 | close_socket(rawsock);
89 |
90 | return 0;
91 | }
92 | /**
93 | *hier ist checksum
94 | */
95 | uint16
96 | compute_checksum(uint16 *ptr,
97 | int byte){
98 | register int sum=0;
99 | u_short odd_byte=0;
100 | /**
101 | *we add sequential 16 bit words to a 32 bit accumulator(sum)
102 | *
103 | *and at the end, fold back all the carry bit from the top 16 bits
104 | *into the lower 16 bits
105 | */
106 | while(byte >1){
107 | sum += *ptr++;
108 | byte -=2;
109 | }
110 | /**
111 | *mod up and add byte, if necessary
112 | */
113 | if(byte ==1){
114 | *((u_char*)&odd_byte) = *(u_char*)ptr;
115 | sum += odd_byte;
116 | }
117 | /**
118 | *add back carry outs from top 16 bits to low 16 bits
119 | */
120 | sum = (sum >> 16) + (sum & 0xffff);///add hight to low
121 | sum += (sum >>16);///add carry
122 | odd_byte =~sum;
123 | return (odd_byte);
124 | }
