AVR32 Studio.Einstiegshilfe.Toolchain
Hier ensteht eine knappe Referenz zu Commandline-Parametern der Toolchain.
avr32gdpproxy
  • --help output:
C:\>avr32gdbproxy --help
Usage: avr32gdbproxy [OPTION]...
Options:
 -h, --help                    Print this message.
 -V, --version                 Print version information.
 --config                      Print configuration for bug reports and exit.
 -d, --debug, --debug=<level>  Enable debug output.
                               Optionally specify debug level (1-3, default 1).
 -l, --log  <file name>        Log debug info to file
 -c, --comport <port>          Connect to given serial port. If <port> is
                               'USB', connect to a USB device. If <port> is
                               'USB:serial', the emulator with the given
                               serial number will be used. The default is to
 -e, --emulator <tool>         Use tool of given type for debugging. Available
                               emulators are 'avrone' and 'jtagicemkii'. By
                               default connect to a sole device on USB.
 -f <type@address>             Notify avr32gdbproxy of a <type> flash memory
                               at <address>. <type> can be either 'cfi' or
                               'internal'.
                               example: -f cfi@0 or -f cfi@0x0
 -t, --traceaddress            <[hostname]:port>
                               Specify host name and port number for
                               trace communication.
                               example 1: -t anyhost.anydomain.com:4242
                               example 2: -t :4242
                               If no hostname is given, avr32gdbproxy
                               listens on all network interfaces.
                               The default port is 4712.
 -a, --gdbaddress              <[hostname]:port>
                               Specify host name and port number for GDB
                               communication.
                               example 1: -a anyhost.anydomain.com:4242
                               example 2: -a :4242
                               The default port is 4711.
 -x, --xmlpath <path>          Specify the path to the part description files.
 -p, --pc <address>            Start execution from specified address.
 -k, --keepalive               Keep running when avr32-gdb disconnects.
 -R, --no-reset                Do not reset target when connecting.
 -s, --simulate <part>         Specify part to simulate.
                               example: -s ap7000
 -m, --memory <address,size>   Specify memory to simulate. Note that it is not
                               necessary to specify internal memories.
                               example: -m 0,8Mb
 -F, --file <filename>         Specify program to run in simulator or program
                               onto target before debugging. Support is
                               limited to ELF files.
 -E, --chiperase               Erase entire chip before programming target.
 --clock <source>              Specify CPU clock source when programming.
                               Valid clock sources are 'xtal' (crystal
                               connected to osc0), 'extclk' (external clock
                               connected to osc0), and 'int' (internal RC
                               oscillator (default)).
 -b, --bufferfile <filename>   Specify file to use in replay session.
                               If specified, avr32gdbproxy will serve trace
                               data from file instead of from target.
 -D, --daisy <devbefore,devafter,bitsbefore,bitsafter>
                               Specify JTAG daisy-chain parameters.
 -T, --transactions            Print protocol transactions.
                               Between trace client and avr32gdbproxy:
                                       --) prefix = rx and (-- prefix = tx
                               Between GDB and avr32gdbproxy:
                                       --> prefix = rx and <-- prefix = tx
 --part <partname>             Specify part name, fail unless target matches.
Example:
avr32gdbproxy -cUSB:00A0000000BB -f cfi@0 -l log.txt -a anyhost.anydomain.com:42 42
C:\>
