Diskussion:AVR Transistortester
M644 chip display SSD1306 fonts, 7x12 '6x8, can not compile the program.
I don't know how to contact you, these words are also translation software to do. This transistor tester is quite interesting, and I made a OLED SSD1306 display version. Address: http://bbs.yleee.com.cn/thread-41093-1-1.html. If you can contact me through the forum that would be the best。
There has A lot of unsolved problems found in the 2015.9.18 test.
1:Battery_check.c, M644 chip automatically shut down a problem,
Problem PORTD = 0; power off //switch Solved ON_PORT &= ~ (1<<ON_PIN); //switch power off
2:function_menu.c, cap_corr problem, the encoder is defined the same and too complicated.
WITH_ROTARY_SWITCH #ifdef
If (rotary.incre > FAST_ROTATION) break fast rotation ends setting of Korr
Problem //if (rotary.count > = 0) {
Solved korr - = rotary.count; / / increase the Korr by rotary.count
Problem //} {else
Problem //korr = rotary.count; / / decrease the Korr by rotary.count
Problem //}
3:The voltage test mode is not ideal, and the measurement is larger than 2.5V.
4:DisplayValue.c, the proposed - voltage takes two decimal places
Display_mV
void (XX uint16_t, ll uint8_t) {
If (ll = = 2)
DisplayValue ((long) XX, -3, ll+1,'V');
Else
DisplayValue ((long) XX, -3, ll,'V');
5: can you start the Chinese language module.
Thanks for providing such a good tool for free.
60.163.3.192 (Diskussion) und 125.123.186.128 (Diskussion) am 19. September 2015
Struktur
Sollte man dem Artikel etwas Struktur geben? Verzeichnis z.B.?
