Nexys 4: SPI-Flash mit iMPACT schreiben -> Fehler
Gast #3571880
Hallo an alle,
nach meinen ersten Designs möchte ich die nun dauerhaft im SPI-Flash des
Nexus-4 Board speichern. Dazu habe ich in iMPACT mittels des PROM
Formatters eine Vorlage für ein 128 Mbit SPI Flashs samt MCS File
erzeugt.
Beim Programmieren kommet es jedoch zur Fehlermeldung:
<pre>
INFO:iMPACT - Current time: 3/12/14 9:02 AM
// *** BATCH CMD : Program -p 1 -dataWidth 1 -spionly -e -v -loadfpga
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 66000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading:   41.52 C, Min. Reading:   37.09
C, Max. Reading:   42.01 C
1: VCCINT Supply: Current Reading:   0.999 V, Min. Reading:   0.987 V,
Max. Reading:   1.008 V
1: VCCAUX Supply: Current Reading:   1.784 V, Min. Reading:   1.781 V,
Max. Reading:   1.784 V
Unprotect sectors: FALSE
SPI SLAVE TYPE in Cse_Operate.c is 99
Core is not loaded.
INFO:iMPACT - Downloading
/opt/Xilinx/14.7/ISE_DS/ISE/data/cse/cseflash/artix7/xc7a100t_xsdbspi.co
r  core file.
INFO:iMPACT - Creating XC7A100T device.
'1': Programming device...
 Match_cycle = NoWait.
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:Cse - Status register values:
INFO:Cse - 0011 1111 1001 1110 0000 1000 0000 0010
INFO:Cse - '1': Completed downloading bit file to device.
INFO:Cse - '1': Programming completed successfully.
PROGRESS_END - End Operation.
Elapsed time =      1 sec.
key: dclk_has_reset, value: 0
key: period_frc, value: 0
key: period_int, value: 10
Found Slave on Bus Index.
Slave Int Type is 99, slave Index is 0 , SPI_SLAVE is 99
Slave Type is 99, slave Index is 0
SPI core clock speed value = 0xA801.
'1': IDCODE is '012018' (in hex).
'1': ID Check failed.
INFO:Cse - The operation did not complete successfully.
'1': Configuration data download to FPGA was not successful. DONE did
not go high, please check your configuration setup and mode settings.
Elapsed time =      3 sec.
</pre>
Ein direktes programmieren des FPGAs mit dem Bit-File funktioniert ohne
Probleme. Woran kann es hier liegen?
Danke im Voraus
Martin
#3572070
Hm, was genau ist denn für ein SPI Flash auf dem Board verbaut? Laut
Schaltplan sollte da ein Spansion S25FL128S drauf sein, aber die ID die
Impact bei dir ausliest (012018) passt da nicht. Der S25FL128S sollte
eine 0117xx bringen, 0118xx wäre der 256S. Welche Flash unterstützt
werden, findest du hier:
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_4/pim_c_introduction_indirect_programming.htm
Es gibt auch einen Umgebungsvariablen-Schalter zum skippen des ID Code
Checks, aber der hilft meistens auch nicht, da dann Impact nicht weiß,
wieviele Sektoren usw. zu programmieren sind. Die Variable weiß ich
leider nicht auswendig, kann ich auf Arbeit morgen mal gucken.
Achja, du musst natürlich beim Zuordnen des MCS Files zum SPI Flash
genau den Flash-Typ auswählen, der verbaut ist.
Gast #3572335
Christian R. schrieb:
> Sicher, aber dazu muss impact erst mal wollen. Das kann manchmal sehr
> widerspenstig sein. ID Check Failed sagt ja eigentlich schon dass er
> nicht will/kann. Kann man denn den S25FL128P beim Assign MCS File
> auswählen?
Das muss der OP beantworten, ich habe mich nur geäussert weil ich mich
auch gerade mit neuen Spansion Flashs beschäftigt habe.
Gast #3577455
ich hatte mal wieder Zeit zu testen. Und zwar habe ich den S25FL128S
ausgewählt. Damit funktioniert der ID-Check. Wenn ich das Programmieren
starte, bleibt Impact bei 0% hängen und es tut sich nichts mehr. Hier
der Log dazu:
Selected part: S25FL128S
// *** BATCH CMD : attachflash -position 1 -spi "S25FL128S"
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "/home/rschilling/vhdl-projects/knight-rider/Knight Rider.mcs"
INFO:iMPACT - Current time: 3/16/14 2:40 PM
Validating chain...
1: Device Temperature: Current Reading:   38.07 C, Min. Reading:   34.13 C, Max. Reading:   38.56 C
1: VCCINT Supply: Current Reading:   1.002 V, Min. Reading:   1.002 V, Max. Reading:   1.005 V
1: VCCAUX Supply: Current Reading:   1.793 V, Min. Reading:   1.790 V, Max. Reading:   1.793 V
Match cycle: NoWait
 LCK_cycle = NoWait.
LCK cycle: NoWait
done.
23
24
25
26
27
28
29
30
Match cycle: NoWait
31
 LCK_cycle = NoWait.
32
LCK cycle: NoWait
33
INFO:iMPACT - '1': Checking done pin....done.
34
'1': Programmed successfully.
35
36
37
38
39
Validating chain...
40
41
1: Device Temperature: Current Reading:   34.13 C, Min. Reading:   33.64 C, Max. Reading:   38.56 C
42
1: VCCINT Supply: Current Reading:   1.005 V, Min. Reading:   1.002 V, Max. Reading:   1.005 V
43
44
45
SPI SLAVE TYPE in Cse_Operate.c is 0
46
INFO:iMPACT - Downloading /opt/Xilinx/14.7/ISE_DS/ISE/data/cse/cseflash/artix7/xc7a100t_xsdbspi.cor core file.
47
48
49
50
51
Match cycle: NoWait
52
 LCK_cycle = NoWait.
53
LCK cycle: NoWait
54
done.
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
'1': ID Check passed.
72
 '1': Erasing Device.
73
'1': Using Sector Erase.
74
'1': Erasing non-volatile quad-enable bit...
75
'1': Programming Flash.
Weiß jemand woran es diesmal scheitert?
lg Martin
Gast #3578337
Es sollte ungefähr so weitergehen:
'1': Reading device contents...
done.
'1': Verification completed.
'1':Programming in x4 mode.
W25Q64BV Status Register Contents = 0x0200.
Wie lange hast Du gewartet?
Duke
