1 | #define DDR_in set_tris_b(0xFFFF)
2 | #define DDR_out set_tris_b(0xF000)
3 | #define DATA_in input_b()
4 | #define DATA_out(value) output_b(value)
5 |
6 | // ASCII control commands
7 | #define SOH 0x01
8 | #define ENQ 0x05 // Enq
9 | #define ACK 0x06 // ACK
10 | #define NACK 0x15 // NACK
11 | #define BEL 0x07 // "Warnglocke"
12 | #define EOT 0x04
13 | #define temp 0xAA // Überhizung
14 |
15 | // RS232 steps
16 | #define waitENQ 0
17 | #define waitSOH 1
18 | #define waitCMD 2
19 | #define waitNUM 3
20 | #define waitPAR 4
21 | #define waitRED 0
22 | #define waitGREEN 1
23 | #define waitBLUE 2
24 | #define waitAX1 3
25 | #define waitAX2 4
26 | #define waitAX3 5
27 | #define waitACK 5
28 | #define waitEOT 6
29 |
30 | // Programm-defines
31 | #define STREAM 0x11
32 | #define STOP 0x22
33 | #define Stream_buf_max 1000 // Maximale Buffer-Grösse
34 |
35 | unsigned int8 command = STOP;
36 | unsigned int16 x_achse_buf[Stream_buf_max]; // X-Achsen Werte
37 | unsigned int16 y_achse_buf[Stream_buf_max]; // Y-Achsen Werte
38 | unsigned int8 red_buf[Stream_buf_max]; // RGB Werte
39 | unsigned int8 green_buf[Stream_buf_max];
40 | unsigned int8 blue_buf[Stream_buf_max];
41 |
42 | //*****************************************************************************
43 | // Definitionen
44 | #define TXE PIN_F6 // Transmitt-enabmle pin
45 | #define WR PIN_F4 // Write pin (high peak)
46 | #define RX PIN_D11 // Receive data Pin
47 | #define RD PIN_F3 // Read pin (during read low)
48 | #define PWREN PIN_F5 // configurations-status
49 |
50 | #define rxBuf_max 50 // buffer size
51 | static int8 index_rxBuf_R = 0; // Index of last write RX-Buffer
52 | static int8 index_rxBuf_W = 0; // Index of last read RX-Buffer
53 | static unsigned int8 rxBuf[rxBuf_max + 1]; // RX-Buffer
54 | #define txBuf_max 50 // buffer size
55 | static int8 index_txBuf_R = 0; // Index to write TX-Buffer
56 | static int8 index_txBuf_W = 0; // Index to read TX-Buffer
57 | static unsigned int8 txBuf[txBuf_max + 1]; // TX-Buffer
58 | //*****************************************************************************
59 | // Functions
60 | //=========== INIT ====================================
61 | void ft245_init(void){
62 | int8 i = 0;
63 | unsigned int8 blink_cnt = 0;
64 |
65 | output_high(RD); // set control-pins
66 | output_low(WR);
67 |
68 | for(i=0;i<=txBuf_max;i++){ // clear buffers
69 | txBuf[i] = 0;
70 | }
71 | i = 0;
72 | for(i=0;i<=rxBuf_max;i++){
73 | rxBuf[i] = 0;
74 | }
75 |
76 | while(input_state(PWREN) == 1){ // wait until the USB FTDI-configuration
77 | if(blink_cnt >= 250){ // Blaue LED mit 4Hz blinken
78 | output_toggle(LED_blue);
79 | blink_cnt = 0;
80 | }
81 | blink_cnt ++;
82 | delay_ms(1);
83 | }
84 | }
85 | //=========== TX ====================================
86 | // if no new data, return / need to calls in the main
87 | void usart_tx(void){ // send-function
88 | if(input_state(TXE) == 0){ // if sending possible
89 |
90 | if(index_txBuf_R == index_txBuf_W){ // no new data => return
91 | return;
92 | }
93 | if(index_txBuf_R == txBuf_max){ // ringbuffer
94 | index_txBuf_R = 0;
95 | }
96 | else{
97 | index_txBuf_R ++;
98 | }
99 |
100 | DATA_out(txBuf[index_txBuf_R]); // write datas to the ftdi
101 | output_high(WR); // new data available
102 | output_low(WR);
103 | }
104 | }
105 | void txBuf_write(int8 parameter){ // TX buffer handling
106 | if(index_txBuf_W == txBuf_max){ // ringbuffer
107 | index_txBuf_W = 0;
108 | }
109 | else{
110 | index_txBuf_W ++;
111 | }
112 | txBuf[index_txBuf_W] = parameter;
113 | }
114 | //=========== RX ====================================
115 | // need to calls in the main
116 | void usart_rx(void){ // read function (polling)
117 | if(input_state(RX) == 0){ // if new data in the FTDI buffer
118 | if(index_rxBuf_W == rxBuf_max){ // ringbuffer
119 | index_rxBuf_W = 0;
120 | }
121 | else{
122 | index_rxBuf_W ++;
123 | }
124 |
125 | // take datas and set it dynamic in the buffer
126 | DDR_in;
127 | output_low(RD); // read data
128 | rxBuf[index_rxBuf_W] = DATA_in; // store data
129 | output_high(RD); // read finished
130 | DDR_out;
131 | }
132 | }
133 |
134 | void RS232(void){
135 | static unsigned int8 RS232_state = 0; // Protokollstatus
136 | static unsigned int16 index_par = 0; // Array-Variable für Parameters
137 | static unsigned int16 NUM = 0; // Anzahl zu übertragenden Werte
138 | static unsigned int1 num_teil = 0; // 16Bit Anzahl zusammensetzen
139 | static unsigned int16 k = 0; // Speichervariable für Steuerung
140 | static unsigned int8 PAR_state = 0;
141 | static unsigned int8 temp_cmd = 0;
142 | unsigned int16 a,i;
143 | usart_tx(); // Wenn Daten im TX-Buffer, senden
144 | usart_rx(); // Wenn Daten im FTDI-Buffer, entgegennehmen
145 |
146 | if(index_rxBuf_W == index_rxBuf_R){ // Buffer Error abgleichen
147 | return; // Wenn keine neuen Daten => aus Funktion heraus springen
148 | }
149 | if(index_rxBuf_R == rxBuf_max){ // Erhöhen
150 | index_rxBuf_R = 0;
151 | }
152 | else{
153 | index_rxBuf_R ++;
154 | }
155 |
156 | switch (RS232_state){
157 | case waitENQ:
158 | switch (rxBuf[index_rxBuf_R]){
159 | case '?': // Suche der LCU
160 | printf(txBuf_Write,"USB LCU");
161 | output_high(LED_green);
162 | break;
163 |
164 | case ENQ:
165 | RS232_state = waitSOH; // In nächsten State wechselnd
166 | txBuf_Write(ACK);
167 | break;
168 |
169 | default:
170 | txBuf_Write(rxBuf[index_rxBuf_R]); // Unbekanter Befehl zurückgeben
171 | break;
172 | }
173 | break;
174 |
175 | case waitSOH: // Header der Übertragung
176 | switch (rxBuf[index_rxBuf_R]){
177 | case SOH:
178 | RS232_state = waitCMD;
179 | break;
180 |
181 | default:
182 | RS232_state = waitENQ;
183 | txBuf_Write(NACK);
184 | break;
185 | }
186 | break;
187 |
188 | case waitCMD: // Kommando
189 | switch (rxBuf[index_rxBuf_R]){
190 | case STREAM: // Werte streamen
191 | RS232_state = waitNUM;
192 | temp_cmd = rxBuf[index_rxBuf_R];
193 | break;
194 |
195 | case STOP: // Projektor aus
196 | command = rxBuf[index_rxBuf_R];
197 | txBuf_Write(ACK);
198 | RS232_state = waitACK;
199 | break;
200 |
201 | case 0x01: // Show 1
202 | command = rxBuf[index_rxBuf_R];
203 | txBuf_Write(ACK);
204 | RS232_state = waitACK;
205 | break;
206 | case 0x02:
207 | for(i=0;i<1000;i++){
208 | printf(txBuf_Write,"%d\n",x_achse_buf[i]);
209 | printf(txBuf_Write,"%d\n",y_achse_buf[i]);
210 | printf(txBuf_Write,"%d\n",red_buf[i]);
211 | printf(txBuf_Write,"%d\n",green_buf[i]);
212 | printf(txBuf_Write,"%d\n\n",blue_buf[i]);
213 | for(a=0;a<10;a++) usart_tx();
214 | }
215 | txBuf_Write(ACK);
216 | RS232_state = waitACK;
217 | break;
218 | default:
219 | RS232_state = waitENQ;
220 | txBuf_Write(NACK);
221 | command = 0;
222 | break;
223 | }
224 | break;
225 |
226 | case waitNUM: // Anzahl zu empfangender Werte in 16 Bit
227 | switch (num_teil){ // 2 8Bit Werte zu 16 Bit Wert zusammensetzen
228 | case 0:
229 | NUM = (rxBuf[index_rxBuf_R] << 8);
230 | num_teil = 1;
231 | break;
232 |
233 | case 1:
234 | NUM |= rxBuf[index_rxBuf_R];
235 | RS232_state = waitPAR;
236 | num_teil = 0;
237 | printf(txBuf_Write,"%d\n",rxBuf[index_rxBuf_R]);
238 | printf(txBuf_Write,"%d\n",NUM);
239 | break;
240 | }
241 | break;
242 |
243 | case waitPAR:
244 | index_par ++;
245 | switch(PAR_state){ // Werte in Ausgabe-Arrays speichern
246 | case waitRED:
247 | red_buf[k] = rxBuf[index_rxBuf_R];
248 | PAR_state = waitGREEN;
249 | output_high(LED_red);
250 | break;
251 |
252 | case waitGREEN:
253 | green_buf[k] = rxBuf[index_rxBuf_R];
254 | PAR_state = waitBLUE;
255 | break;
256 |
257 | case waitBLUE:
258 | blue_buf[k] = rxBuf[index_rxBuf_R];
259 | PAR_state = waitAX1;
260 | break;
261 |
262 | case waitAX1:
263 | x_achse_buf[k] = (rxBuf[index_rxBuf_R] << 4);
264 | PAR_state = waitAX2;
265 | break;
266 |
267 | case waitAX2:
268 | x_achse_buf[k] |= (rxBuf[index_rxBuf_R] >> 4);
269 | y_achse_buf[k] = ((rxBuf[index_rxBuf_R] & 0x0F) << 8);
270 | PAR_state = waitAX3;
271 | break;
272 |
273 | case waitAX3:
274 | y_achse_buf[k] |= rxBuf[index_rxBuf_R];
275 | if(k == (Stream_buf_max - 1)) // Ringbuffer Steuerung
276 | k = 0;
277 | else
278 | k ++;
279 | PAR_state = waitRED;
280 | if(index_par == NUM){
281 | RS232_state = waitACK;
282 | txBuf_Write(ACK);
283 | index_par = 0;
284 | output_low(LED_red);
285 | }
286 | break;
287 | }
288 | break;
289 |
290 | case waitACK:
291 | if(rxBuf[index_rxBuf_R] == ACK){ // ACK empfangen,
292 | RS232_state = waitEOT;
293 | }
294 | break;
295 |
296 | case waitEOT: // Übertragung beendet
297 | if(rxBuf[index_rxBuf_R] == EOT){
298 | RS232_state = waitENQ;
299 | if(temp_cmd == STREAM){
300 | // command = temp_cmd;
301 | temp_cmd = 0;
302 | }
303 | }
304 | break;
305 |
306 | default: // Default
307 | RS232_state = waitENQ;
308 | txBuf_Write(NACK);
309 | break;
310 | }
311 | }
