1 | int main(void)
2 | {
3 | unsigned char ret;
4 |
5 |
6 | DDRB = 0xff; // use all pins on port B for output
7 | PORTB = 0xff; // (active low LED's )
8 |
9 | i2c_init(); // init I2C interface
10 |
11 | /* write 0x75 to eeprom address 0x05 (Byte Write) */
12 | ret = i2c_start(Dev24C02+I2C_WRITE); // set device address and write mode
13 | if ( ret ) {
14 | /* failed to issue start condition, possibly no device found */
15 | i2c_stop();
16 | PORTB=0x00; // activate all 8 LED to show error */
17 | }else {
18 | /* issuing start condition ok, device accessible */
19 | i2c_write(0x05); // write address = 5
20 | i2c_write(0x75); // ret=0 -> Ok, ret=1 -> no ACK
21 | i2c_stop(); // set stop conditon = release bus
22 |
23 | /* write ok, read value back from eeprom address 0x05, wait until
24 | the device is no longer busy from the previous write operation */
25 | i2c_start_wait(Dev24C02+I2C_WRITE); // set device address and write mode
26 | i2c_write(0x05); // write address = 5
27 | i2c_rep_start(Dev24C02+I2C_READ); // set device address and read mode
28 | ret = i2c_readNak(); // read one byte
29 | i2c_stop();
30 |
31 | PORTB = ~ret; // output byte on the LED's
32 |
33 | /* write 0x70,0x71,072,073 to eeprom address 0x00..0x03 (Page Write),
34 | wait until the device is no longer busy from the previous write operation */
35 | i2c_start_wait(Dev24C02+I2C_WRITE); // set device address and write mode
36 | i2c_write(0x00); // write start address = 0
37 | i2c_write(0x70); // write data to address 0
38 | i2c_write(0x71); // " " " " 1
39 | i2c_write(0x72); // " " " " 2
40 | i2c_write(0x74); // " " " " 3
41 | i2c_stop(); // set stop conditon = release bus
42 |
43 | /* write ok, read value back from eeprom address 0..3 (Sequencial Read),
44 | wait until the device is no longer busy from the previous write operation */
45 | i2c_start_wait(Dev24C02+I2C_WRITE); // set device address and write mode
46 | i2c_write(0x00); // write address = 0
47 | i2c_rep_start(Dev24C02+I2C_READ); // set device address and read mode
48 | ret = i2c_readAck(); // read one byte form address 0
49 | ret = i2c_readAck(); // " " " " " 1
50 | ret = i2c_readAck(); // " " " " " 2
51 | ret = i2c_readNak(); // " " " " " 3
52 | i2c_stop(); // set stop condition = release bus
53 |
54 | PORTB = ~ret; // output byte on the LED's
55 | }
56 |
57 | for(;;);
58 | }
