1 | //Pins definieren, werden durchgängig mit diesen Namen benutzt
2 | #define SLAVESELECT 10
3 | #define SPICLOCK 13
4 | #define DATAOUT 11 //MOSI
5 | #define DATAIN 12 //MISO
6 | #define UBLB(a,b) ( ( (a) << 8) | (b) )
7 | #define UBLB19(a,b) ( ( (a) << 16 ) | (b) )
8 |
9 | //Register Adressen
10 | #define REVID 0x00 //ASIC Revision Nummer
11 | #define OPSTATUS 0x04 //Operation Status
12 | #define STATUS 0x07 //ASIC Status
13 | #define START 0x0A //Konstante Leserate
14 | #define PRESSURE 0x1F //Druck 3 MSB
15 | #define PRESSURE_LSB 0x20 //Druck 16 LSB
16 | #define TEMP 0x21 //16 bit Temperaut
17 |
18 | char rev_in_byte;
19 | int temp_in;
20 | unsigned long pressure_lsb;
21 | unsigned long pressure_msb;
22 | unsigned long temp_pressure;
23 | unsigned long pressure;
24 |
25 | void setup()
26 | {
27 | byte clr;
28 | pinMode(DATAOUT, OUTPUT);
29 | pinMode(DATAIN, INPUT);
30 | pinMode(SPICLOCK,OUTPUT);
31 | pinMode(SLAVESELECT,OUTPUT);
32 | digitalWrite(SLAVESELECT,HIGH); //Sensor ausschalten und neue Konfiguration übernehmen
33 |
34 | SPCR = B01010011; //MPIE=0, SPE=1 (on), DORD=0 (MSB first), MSTR=1 (master), CPOL=0 (clock idle when low), CPHA=0 (samples MOSI on rising edge), SPR1=0 & SPR0=0 (500kHz)
35 | clr=SPSR;
36 | clr=SPDR;
37 | delay(10);
38 | Serial.begin(9600);
39 | delay(500);
40 |
41 | Serial.println("Initialisiere hohe Leserate");
42 | write_register(0x03,0x09);
43 | }
44 |
45 | void loop()
46 | {
47 |
48 | rev_in_byte = read_register(REVID);
49 |
50 | pressure_msb = read_register(PRESSURE);
51 | pressure_msb &= B00000111;
52 | pressure_lsb = read_register16(PRESSURE_LSB);
53 | pressure_lsb &= 0x0000FFFF;
54 | pressure = UBLB19(pressure_msb, pressure_lsb);
55 | pressure /= 4;
56 |
57 | Serial.print("Druck in Pascal [");
58 | Serial.print(pressure, DEC);
59 | Serial.print(" P");
60 | Serial.print("");
61 | Serial.println("]");
62 |
63 | Serial.print("Druck in Hekto-Pascal [");
64 | Serial.print(pressure/100, DEC);
65 | Serial.print(" hPa");
66 | Serial.print("");
67 | Serial.println("]");
68 |
69 | temp_in = read_register16(TEMP);
70 | temp_in = temp_in / 20;
71 | Serial.print("Temperatur in Grad Celcius ["); //Direkte Ausgabe
72 | Serial.print(temp_in , DEC);
73 | Serial.println("]");
74 |
75 | Serial.println("");
76 | delay(1500);
77 |
78 | }
79 |
80 | char spi_transfer(volatile char data)
81 | {
82 | SPDR = data; // SPDR auf Datenübergabe vorbereiten
83 | while (!(SPSR & (1<<SPIF))) // Solange warten bis alle Bytes übertrage wurden
84 | {
85 | };
86 | return SPDR; // return the received byte
87 | }
88 |
89 |
90 | char read_register(char register_name)
91 | {
92 | char in_byte;
93 | register_name <<= 2;
94 | register_name &= B11111100; //Register lesen
95 |
96 | digitalWrite(SLAVESELECT,LOW); //SPI auswählen
97 | spi_transfer(register_name); //Datenbyte "in" SPI schreiben
98 | in_byte = spi_transfer(0x00); //Nichts senden. Gibt Register-Variable aus
99 | digitalWrite(SLAVESELECT,HIGH);
100 | delay(10);
101 | return(in_byte);
102 |
103 | }
104 |
105 | float read_register16(char register_name)
106 | {
107 | byte in_byte1;
108 | byte in_byte2;
109 | float in_word;
110 |
111 | register_name <<= 2;
112 | register_name &= B11111100; //Register lesen
113 |
114 | digitalWrite(SLAVESELECT,LOW); //SPI auswählen
115 | spi_transfer(register_name); //Datenbyte "in" SPI schreiben
116 | in_byte1 = spi_transfer(0x00);
117 | in_byte2 = spi_transfer(0x00);
118 | digitalWrite(SLAVESELECT,HIGH);
119 | in_word = UBLB(in_byte1,in_byte2);
120 | return(in_word);
121 | }
122 |
123 | void write_register(char register_name, char register_value)
124 | {
125 | register_name <<= 2;
126 | register_name |= B00000010; //Register lsen
127 |
128 | digitalWrite(SLAVESELECT,LOW); //Datenbyte "in" SPI schreiben
129 | spi_transfer(register_name); //Send register location
130 | spi_transfer(register_value); //Send value to record into register
131 | digitalWrite(SLAVESELECT,HIGH);
132 | }
