Hallo, ich habe eine Cyclone II FPGA und möchte das RAM ( mit dem
one-port Ram von Altera )ansprechen und wieder auslesen.
1 | LIBRARY ieee;
2 | USE ieee.std_logic_1164.all;
3 | USE IEEE.numeric_std.ALL;
4 | use IEEE.STD_LOGIC_ARITH.ALL;
5 | use IEEE.STD_LOGIC_UNSIGNED.ALL;
6 |
7 |
8 | -- Entity Declaration
9 |
10 | ENTITY block_name IS
11 | -- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
12 | -- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
13 | PORT
14 | (
15 | clock : IN STD_LOGIC;
16 | resultim : IN STD_LOGIC_VECTOR(23 downto 0);
17 | ausgang2 : OUT STD_LOGIC_VECTOR(31 downto 0);
18 | summe : out std_logic_vector ( 11 downto 0 );
19 | adresse : buffer std_logic_vector (11 downto 0);
20 | speicher : in Std_logic_vector (31 downto 0);
21 | writeenable : out std_logic
22 | );
23 | -- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
24 |
25 | END block_name;
26 |
27 |
28 | -- Architecture Body
29 |
30 | ARCHITECTURE aufsummiererimaginaerteil_architecture OF block_name IS
31 | signal zaehler : natural range 0 to 12;
32 |
33 | BEGIN
34 | writeenable <= '1';
35 | process (clock )
36 | begin
37 | If clock = '1' and clock'event then
38 |
39 | if zaehler = 12 then
40 | zaehler <= 0;
41 | else zaehler <= zaehler + 1;
42 | end if;
43 |
44 | ausgang2 <= resultim + speicher;
45 |
46 | case zaehler is
47 | when 0 => adresse <= "000000000000";
48 | when 1 => adresse <= "000000001000";
49 | when 2 => adresse <= adresse + "1000";
50 | when 3 => adresse <= adresse + "1000";
51 | when 4 => adresse <= adresse + "1000";
52 | when 5 => adresse <= adresse + "1000";
53 | when 6 => adresse <= adresse + "1000";
54 | when 7 => adresse <= adresse + "1000";
55 | when 8 => adresse <= adresse + "1000";
56 | when 9 => adresse <= adresse + "1000";
57 | when 10 => adresse <= adresse + "1000";
58 | when 11 => adresse <= adresse + "1000";
59 | when 12 => adresse <= adresse + "1000";
60 | end case;
61 | end if;
62 | end process;
63 | END aufsummiererimaginaerteil_architecture;
dabei sind read und write-Adresse gleich, leider wird nur aus der
allersten Adresse gelesen( Speicher gibt den Wert aus dem Ram an). liegt
das am Code oder am Baustein, wie muss ich ihn dann einstellen, damit er
den wert der aktuellen Adrese liest? MfG
